Undis Samba Member
Joined: October 24, 2006 Posts: 1396 Location: Riga, Latvia & Sydney, Australia
Posted: Sat Mar 30, 2019 10:15 pm Post subject: Replica of 1935 scale model |
Two wooden scale models were made by the Porsche company sometime in March 1935 to get a visual feel for the design of the new Volkswagen. These models were later used as reference in construction of the very first two Volkswagen bodies in June 1935. I decided to make a replica of one of the models.
The models were photographed at the family home of Ferdinand Porsche in March/April 1935.
The scale model that represented the full sized car the most.
This sketch was made in February 1935. I decided to use it blown up to scale of 1:10 of the full size car. Chris Barber in his book states the scale was 1:5 but I have my doubts about the accuracy of that. Looking carefully at the background such as grass, stones and pebbles it seems the scale was smaller. I decided to go with 1:10 for convenience as the model will be just under 400mm long. Also I chose to use this early sketch because it perfectly shows the lines and proportions of the V1 cars. I just have to be careful with some of the details which were not carried over to the wooden models and the real cars.
Undis Samba Member
Posted: Sat Mar 30, 2019 10:17 pm Post subject: Re: Replica of 1935 scale model |
And the fun can begin.
Undis Samba Member
Posted: Sat Mar 30, 2019 10:24 pm Post subject: Re: Replica of 1935 scale model |
After some shaping with a belt sander.
Undis Samba Member
Posted: Sat Mar 30, 2019 10:35 pm Post subject: Re: Replica of 1935 scale model |
Coming along nicely.
René R. Samba Member
Joined: July 06, 2015 Posts: 1712 Location: No. Calif.
Posted: Sun Mar 31, 2019 6:34 am Post subject: |
That is seriously impressive! I look forward to seeing further progress -- and the finished model. _________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
Hacksaw-BoB Samba Member
Posted: Sun Mar 31, 2019 1:22 pm Post subject: Re: Replica of 1935 scale model |
[size=18]Hi Undis . . . WoW :!: :!: :!:
That is quite an interesting project that you have decided to create.
So far, you are off to a GREAT start and look forward to seeing your progress. :popcorn:
Many Thanks for posting Undis[/size] :!: :!: :!: _________________ Hacksaw BoB
http://www.VintageVolkswagenModels.com
Collector of Vintage VW Toys
BoB's Restor-Version Shop |
Undis Samba Member
Posted: Mon Apr 01, 2019 12:26 am Post subject: Re: Replica of 1935 scale model |
Thanks guys. It is a fun project an most importantly to me it takes me back to the earliest beginnings of the Volkswagen. Early 1935 was a time when the a relatively definite image was penned in the sketch I posted above and the two scale models provided a visual cue to the full sized bodies that were shortly made by Daimler-Benz in their Sindelfingen factory. |
Undis Samba Member
Posted: Mon Apr 01, 2019 12:36 am Post subject: Re: Replica of 1935 scale model |
Small update: getting the main body lines dialed in.
Undis Samba Member
Posted: Mon Apr 01, 2019 2:37 am Post subject: Re: Replica of 1935 scale model |
Working on the windscreen. I decided instead of cutting into the wood, build up the windscreen surround. This area is quite complex consisting of three layers so I thought this approach would give a better result.
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24131 Location: Southeast USA
Posted: Tue Apr 02, 2019 9:17 pm Post subject: Re: Replica of 1935 scale model |
As the old wood carver's saying goes …
Just cut away whatever isn't a V1 Volkswagen. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
Undis Samba Member
Posted: Wed Apr 03, 2019 1:24 am Post subject: Re: Replica of 1935 scale model |
That's so true BB! Sculptors have worked by that adage for thousands of years. In my case I'll also need to add material in some areas. |
Undis Samba Member
Posted: Wed Apr 03, 2019 1:31 am Post subject: Re: Replica of 1935 scale model |
Sadly I don't have a lathe so the next best thing is a drill press. One headlight almost done and the other waiting its turn.
Both headlights finished! They will be test fitted up later.
I did the wheels the same way. Files and a chisel work well.
Those wheels are 17" scaled down 1:10. That was the size used back in 1935.
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Apr 03, 2019 10:31 am Post subject: Re: Replica of 1935 scale model |
Not your first 'Rodeo' at wood carving/turning it doesn't look like! You've got our attention for sure. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Fish Samba Member
Joined: December 05, 2000 Posts: 5563 Location: OB. It's beside the point.
Posted: Wed Apr 03, 2019 1:08 pm Post subject: Re: Replica of 1935 scale model |
Excellent work. I'm curious about the final touch, will you stain or paint? _________________ Prosit!
# 303 and #156
Undis Samba Member
Posted: Wed Apr 03, 2019 11:52 pm Post subject: Re: Replica of 1935 scale model |
Mike Fisher wrote: |
Not your first 'Rodeo' at wood carving/turning it doesn't look like! You've got our attention for sure. |
No it's not. I have built scale models before but those all were kits. I did do plenty of modifications to them so I have some experience in several techniques. This one however is the first I'm building entirely from scratch.
Wood work is in my genes too as my dad is a carpenter.
This is a very interesting project to me as I can explore most of my previous experience plus go into uncharted territory as well. |
Undis Samba Member
Posted: Wed Apr 03, 2019 11:56 pm Post subject: Re: Replica of 1935 scale model |
Fish wrote: |
Excellent work. I'm curious about the final touch, will you stain or paint? |
Thanks. The original model was painted in a very dark color, presumably black so I'm going with that. The wood is pine so not too good for quality carving and finish. It only acts as a base with all the details done in body filler. Yes, it's gonna be finished in bondo! I guess I'm not the only guy to do that! |
Undis Samba Member
Posted: Thu Apr 04, 2019 12:21 am Post subject: Re: Replica of 1935 scale model |
Some more work done. I cut in the side windows with a router (was too much concentrated on the job to take photos of the process).
I also machined the headlight holes with a rotary rasp. Test fitted the headlights but they'll have to go in a little deeper.
It's really starting look the business.
From the front it looks like a surprised frog. My wife thought it's face was like that of a sex doll! I just love that dirty-minded woman!
Undis Samba Member
Posted: Fri Apr 05, 2019 2:09 am Post subject: Re: Replica of 1935 scale model |
First coat of primer. Note the "fence chicken" keeping an eye on the process.
Posted: Sat Apr 06, 2019 5:37 pm Post subject: Re: Replica of 1935 scale model |
[size=18]
WoW . . . Project is looking GREAT Undis :!: :!:
Like going back in time . . . .
Just waiting for Dr. Porsche to stop by and have a look[/size] :popcorn: _________________ Hacksaw BoB
Undis Samba Member
Posted: Sun Apr 07, 2019 3:11 am Post subject: Re: Replica of 1935 scale model |
Hacksaw-BoB wrote: |
Just waiting for Dr. Porsche to stop by and have a look |
So true Bob. I can just imagine old Ferdinand looking over the model and making notes for changes to be implemented for he full scale bodies. |
