Hyatt181 Samba Member
Posted: Sun Mar 31, 2019 4:24 am Post subject: Lifted spindles from Tweed Designs and disc brakes |
Greetings everyone.
I’ve been sitting on a set of tweed design lifted spindles for several years.
I am working on going from an adjustable beam to a stock beam with the lifted spindles.
Having a problem with the disc brake adapter that I’ve been using and the spindle.
Adapter hits the spindle.
I know Tweeds made a disc brake adapter and I’ve found a set but not sure if that is the correct set and not sure if it will actually resolve my problem.
Has anyone done this set up before?
Have pictures of how you did it?
Tweeds or TI design is no longer around to ask how it’s supposed to be set up.
And searching the forums hasn’t revealed any secrets.
The bug set up that I’ve seen pictures for has the brake adapter at different angles so they would work. |
Posted: Sun Mar 31, 2019 4:39 am Post subject: Re: Lifted spindles from Tweed Designs and disc brakes |
Bug set up with bracket that sticks straight out
Thing set up where bracket is at different angle
Where it is currently
Where it needs to be |
It's a play thing Samba Member
Joined: November 19, 2009 Posts: 575 Location: Dayton, Nevada
Posted: Sun Mar 31, 2019 6:47 am Post subject: Re: Lifted spindles from Tweed Designs and disc brakes |
why cant you just drill and tap a new set of holes ? _________________ It's not the size of your shop, it's what comes out of it that counts.
I've been playing with my thing ever since I got it... |
Posted: Sun Mar 31, 2019 7:00 am Post subject: Re: Lifted spindles from Tweed Designs and disc brakes |
Thought about that
The lowest hole would be off the spindle.
I’m thinking of having a new set of caliper brackets made to clock them back a little to fit correctly.
Just wondering if tweeds made a different bracket or what others had done. |
Posted: Sun Mar 31, 2019 12:05 pm Post subject: Re: Lifted spindles from Tweed Designs and disc brakes |
I like the height.
Put it together quickly to see if I liked the height before having a set of brackets made for it.
Posted: Sun Mar 31, 2019 1:39 pm Post subject: Re: Lifted spindles from Tweed Designs and disc brakes |
I wish you were closer, I could help you out. yes you have the right idea, just make a new set of mounts. _________________ It's not the size of your shop, it's what comes out of it that counts.
joosty_chin Samba Member
Posted: Fri Apr 19, 2019 6:27 am Post subject: Re: Lifted spindles from Tweed Designs and disc brakes |
Does anyone know where a fella could get a set of lifted?raised Thing spindles, or have stock ones modified? |
Posted: Fri May 10, 2019 12:17 pm Post subject: Re: Lifted spindles from Tweed Designs and disc brakes |
I discovered that EMPI makes a disc brake adapter for wilwood brakes that has the holes drilled clocked at the correct angle.
Slightly concerned because the bracket is only 5mm think.
But I get to wilwood calipers without the need of any spacers and off the shelf bracket. |
Bruce Samba Member
Posted: Sun May 12, 2019 4:53 pm Post subject: Re: Lifted spindles from Tweed Designs and disc brakes |
Hyatt181 wrote: |
Slightly concerned because the bracket is only 5mm think. |
My buddy had some brackets that were 1/4" thick. Under heavy braking, the bracket would flex over enough that the caliper was hitting the wheel. I think 3/8" is marginal. The stock VW spindle where the caliper mounts is around ½" thick. _________________
Posted: Sun May 12, 2019 5:41 pm Post subject: Re: Lifted spindles from Tweed Designs and disc brakes |
Yeah after really looking at it I’m not comfortable with the thickness.
But it does give me a pattern to work with and I can take it somewhere to be machines out of 3/8.
I only have 1/2” of space to work with before it hits the rotor but I think 3/8” steel will be fine. |
Bruce Samba Member
Posted: Sun May 12, 2019 7:06 pm Post subject: Re: Lifted spindles from Tweed Designs and disc brakes |
Can you modify the rotors to give you a couple of mm more room? If you can make them from ½", they will not flex, so you don't need very much clearance. With 3/8" you will need the room. _________________
