Kashufo Samba Member
Posted: Sun Mar 31, 2019 7:06 pm Post subject: Brake calipers |
I am trying to get brake calipers for my squareback but there are 2 kinds for 71 and early and 72 up how can i know witch ones i need how can i get part number |
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1876 Location: Feeling, Minnesota
Posted: Sun Mar 31, 2019 9:05 pm Post subject: Re: Brake calipers |
Measure the distance between the caliper mounting bolt holes.
The earlier type has a 2 1/4" (57.15mm) spacing, later type has 3" (76.2mm) spacing. |
Posted: Mon Apr 01, 2019 6:38 am Post subject: Re: Brake calipers |
They are really hard to find some body told me that you can replace them with 83 BMW 320i but I went to autozone or o'reilly they don't have them any more. any advice on what can I do? |
pitargue Samba Member
Posted: Mon Apr 01, 2019 7:29 am Post subject: Re: Brake calipers |
Which calipers do you need? Perhaps you can find some in the classifies? Probably need to be rebuilt though... |
Posted: Mon Apr 01, 2019 8:28 am Post subject: Re: Brake calipers |
I need passenger side but I am thinking to do both sides I try everywhere they only have for early type 3's, and I am trying to get parts but they only have seals and I need pistons. do any one know where I can get them? |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13278 Location: Tejas!
Posted: Mon Apr 01, 2019 9:16 am Post subject: Re: Brake calipers |
No one has the 42mm pistons. (I searched and searched) I believe, the same pistons work on the early calipers as well as the later calipers.
I think Jim Adney can either rebuild your calipers or has some for sale. I do not know if he has just pistons for sale, though. Best to ask him. |
Erik G Samba Member
Erik G Samba Member
Posted: Mon Apr 01, 2019 11:25 am Post subject: Re: Brake calipers |
I try Autozone and they are out of stock does any one know how I can get a hold of Jim Adney? |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Mon Apr 01, 2019 12:12 pm Post subject: Re: Brake calipers |
Kashufo wrote: |
Try [email protected] . He also has an ad in the Samba Classifieds. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Mon Apr 01, 2019 1:28 pm Post subject: Re: Brake calipers |
What is the date on your car. Be specific.
There are three calipers. The bery early ones with the narrow caliper mount holes as described......and the middle years which are UP TO AUGUST OF 1971....and the third that is FROM AUGUST OF 1971 (1972 model year)
Both the middle and late calipers have the same bolt pattern but wirk in different spindles, have different width and differebt pads.
Rock auto lists a centric remanufactured caliper in stock...only one left for $42.
Also check PMB performance. Ray |
Posted: Mon Apr 01, 2019 1:46 pm Post subject: Re: Brake calipers |
date that I have is 01/72 how can I get the chassis number |
Posted: Mon Apr 01, 2019 4:17 pm Post subject: Re: Brake calipers |
Kashufo wrote: |
Also....my apologies. I may be wrong on the dates. It may be TO august of 72 and AFTER August of 1972. I het my type 3s and type 4s mixed up some days....so check the book. Ray |
Tvättbjörn Samba Member
Posted: Mon Apr 01, 2019 8:43 pm Post subject: Re: Brake calipers |
Keep looking for the correct caliper with 42mm piston your car has to have. Do not use a BMW caliper, because the pistons are HUGE and the travel / piston diameter of your master brake cylinder is too small for that combination especially in combination with rear brake drums.
Same for the regular bug / ghia caliper with 40mm piston. You will not have enough pressure on your front brakes , because 42mm piston was matched to the rear brakes! |
Posted: Mon Apr 01, 2019 8:47 pm Post subject: Re: Brake calipers |
raygreenwood wrote: |
Does the 72 also have thicker brake rotors? 1mm thicker ? Like 11mm vs 10mm? |
Posted: Mon Apr 01, 2019 9:33 pm Post subject: Re: Brake calipers |
Tvättbjörn wrote: |
Ok....sorry my memory is crappy today.
There are TWO basic calipers for type 3.....with a couple of differences in the later models that make it look like three.
The early models through 1971....which means they stop at August.....are the smaller 40mm piston and mount. The 1972-1973 used the larger 42mm piston.
My mix up is that the later 42mm piston caliper for type 3.....is the early obe for 411/412/914 cars....and ends in August of 1972....and the wider 42mm piston caliper runs from august of 1972 (1973 model year) through 74 in 412 and 76 in the 914.
The 42mm caliper in the type 3.....for 1972 and 1973. The type 3 disc thickness in the without guesswork book is 11.mm changing to 11mm in the from August of 1971 models (1972 model year).
Here is my thread on rebuilding these calipers if needed. Ray
https://www.thesamba.com/vw/forum/viewtopic.php?t=658176 |
Posted: Mon Apr 01, 2019 9:59 pm Post subject: Re: Brake calipers |
Actually, all type 3 calipers came with 42mm pistons. The later calipers use a larger pad. (wrt 3 types of calipers, search for the differences about the pin in the caliper to guide the piston on the larger calipers.)
But no one makes a 5 lug rotor for the later brakes, if that's a consideration.
Here's something that just popped up on the classifieds.
https://www.thesamba.com/vw/classifieds/detail.php?id=2264002
Dunno what the pistons look like after sitting for years. I bought some calipers that was sitting for years, and the pistons were beyond saving. (Heavy corrosion)
Chris has some type 3 calipers last time I was there. In fact, he's parting out some type 3's.
https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=19586 .
Good luck. |
Posted: Mon Apr 01, 2019 10:32 pm Post subject: Re: Brake calipers |
All Typ3 have 42mm caliper pistons!
I just never did hear about three different caliper versions. I only know about two different version and so the brake rotors.
The early small bolt pattern takes the Bug / Ghia rotor while the later version takes the 411 version which is 1mm thicker.
The early T3 caliper have the same bolt pattern like the Bug / Ghia, but the piston is 42mm and not 40mm. The ATE caliper with two pin look identical on the outside, but the piston diameter is different.
As far as I remember the T3 caliper has also one guide pin inside the caliper were the piston slides over, which I have never seen on any 40mm caliper. Not sure what the reason for that guide pin is.
One way to find out what piston size an early caliper has is if you look at the piston dust seal the original ATE part number will have a 42 as part of the part number on the seal. The Ghia caliper will have a 40 as part of the part number. The part number can be seen after the brake pads have been removed.
The VW installed caliper with 40mm for the Bug / Ghia was made in three different versions:
1st. 2-pin ATE --------- 2nd. 1-pin ATE and the --------- Girling caliper with somewhat oval brake pads.
To the best of my knowledge the Brazilian made VARGA caliper comes only with an 40mm piston and was never installed in German made cars . At least I have never seen any with an 42mm piston. |
Erik G Samba Member
Posted: Tue Apr 02, 2019 7:56 am Post subject: Re: Brake calipers |
add that in the US the beetle never got discs, they were always drum brakes, only the ghia got the discs.
the 42mm pistons are available a number of places, but you need to be looking for a 914 not a volkswagen. the late 914 front calipers are the same as the late type 3, with two bleeder valves. _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
