Another sacrilegious idea I had
thom
thom is offline
PostPosted: Tue Apr 02, 2019 10:33 am    Post subject: Another sacrilegious idea I had Reply with quote
At the SOTO meet this weekend, in the broiling 70° sun, the most happening spots were at the buses with tents. I have one of the repo westfalia tents and have toyed with the idea of installing the roof mounts on my 23-window so I could provision some shade when needed. I use this tent on the panel and it's awesome. My idea is to install the root mounts with welded nuts underneath, so I don't have to worry about access through the headliner.
Thoughts? Has anyone ever done this on a roof-window bus?
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
srfndoc
srfndoc is offline
PostPosted: Tue Apr 02, 2019 10:43 am    Post subject: Re: Another sacriligious idea I had Reply with quote
Westfalia used plain old screws on most of the smaller mounts (minus the foward mount) so you don't need access to other side for those. Seen here:
For the front mount you could use a rivnut (http://rivetnuts.com) if you didn't have access to the back side or just secure it with screws as well like Westfalia did on buses with a headliner (SO22 here):
thom
thom is offline
PostPosted: Tue Apr 02, 2019 11:21 am    Post subject: Re: Another sacriligious idea I had Reply with quote
So what would happen if you removed one of those screws? Is there a nut on the other side? IIRC, on my '55 Westfalia there was.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
crofty
Judas of the North
crofty is offline
PostPosted: Tue Apr 02, 2019 11:31 am    Post subject: Re: Another sacriligious idea I had Reply with quote
Self tapping screws go through the rear mount , through the roof and through a backing plate.
The front mount uses carriage bolts or the same screws as the rear mount.
HamburgerBrad wrote:
notchboy
notchboy is offline
PostPosted: Tue Apr 02, 2019 11:56 am    Post subject: Re: Another sacriligious idea I had Reply with quote
Why not. It gives you that option to remove the brackets if needed - except for the bolt holes and what ever you decide to cap the holes with.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
npbusguy
npbusguy is offline
PostPosted: Tue Apr 02, 2019 12:09 pm    Post subject: Re: Another sacriligious idea I had Reply with quote
The rear mount on my '60 SO23 uses carriage bolts, just like the front mount.
crofty
Judas of the North
crofty is offline
PostPosted: Tue Apr 02, 2019 12:11 pm    Post subject: Re: Another sacriligious idea I had Reply with quote
hmm. backing plate?
srfndoc
srfndoc is offline
PostPosted: Tue Apr 02, 2019 12:35 pm    Post subject: Re: Another sacriligious idea I had Reply with quote
Never seen a backing plate used, just bolts:
No way Westfalia could have got to the back side of a bus with a headliner like an SO22 so I'm guessing they just rocked the screws by themselves.
thom
thom is offline
PostPosted: Tue Apr 02, 2019 12:46 pm    Post subject: Re: Another sacriligious idea I had Reply with quote
Unless the mounts went in before the headliner, or someone very carefully removed said headliner to install the mount (is that even possible?)
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
srfndoc
srfndoc is offline
PostPosted: Tue Apr 02, 2019 12:51 pm    Post subject: Re: Another sacriligious idea I had Reply with quote
Certainly possible. I would love to see a pic of the backing plate Crofty mentioned as I've never seen one. It would definitely provide for additional holding strength if normal self tapping screws were used.
Braukuche
Braukuche is offline
PostPosted: Tue Apr 02, 2019 12:58 pm    Post subject: Re: Another sacriligious idea I had Reply with quote
I wonder if there was a difference between the six vs four mounting hole brackets.
My '62 SO22 had the mounts missing, and the six holes for both were welded up so no idea if they used carriage bolts for both, like on my 59 SO23, or if they used metal screws. The holes were pretty damn small indicating screws but can't say for sure.
I don't think they would mess with headliner installation, that wasn't their thing and removing the headliner to install the rear would be very difficult to do without damaging the headliner.
There has to be someone out there with a mosaic or 22 who should know.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
easy e
easy e is offline
PostPosted: Tue Apr 02, 2019 1:09 pm    Post subject: Re: Another sacriligious idea I had Reply with quote
NOS rear roof mounts (only pic I've taken of them):
aka: Evan
notchboy
notchboy is offline
PostPosted: Tue Apr 02, 2019 1:12 pm    Post subject: Re: Another sacrilegious idea I had Reply with quote
Ha! I was just going to post your pic!
1964 1500 S
easy e
easy e is offline
PostPosted: Tue Apr 02, 2019 1:21 pm    Post subject: Re: Another sacrilegious idea I had Reply with quote
Razz
aka: Evan
srfndoc
srfndoc is offline
PostPosted: Tue Apr 02, 2019 1:29 pm    Post subject: Re: Another sacrilegious idea I had Reply with quote
Evan to the rescue (thanks for the pic). I wonder if that is something that was an early or late thing.
Not much help for Thom and I'm still curious what they did on a headliner bus. I'm sure Greg or Clara could add more knowledge to this discussion.
hitest
hitest is offline
PostPosted: Tue Apr 02, 2019 4:26 pm    Post subject: Re: Another sacrilegious idea I had Reply with quote
As long as everybody's comfortable with sacrilege and all...
Could a guy get creative using two of the skylight windows? I mean, getting two cut/molded in Plexiglas and run bolts and brackets through those? That's definitely what I would do in your shoes. Zero affect to body.
Along those lines, thin, stainless bases could be arched to match the windows- then inserted under the rubber lip to support welded-on brackets. Think of the metal louvers from every hatchback car in the 80s. They were held by brackets you shoved under the rubber window seal. Very quickly removed and replaced- but protects everything.
FU#5
easy e
easy e is offline
PostPosted: Tue Apr 02, 2019 5:02 pm    Post subject: Re: Another sacrilegious idea I had Reply with quote
Maybe consider getting a grutter-mount one from member Jonce.
I bought one for my panel & it works great.
Can order them with walls, windows w/roll-up covers in the inside, etc.
My tent is the next to last pic... 3/4 front shot of a cream colored Vanagon w/grey/yellow/white tent.
https://www.thesamba.com/vw/classifieds/detail.php?id=733607
aka: Evan
notchboy
notchboy is offline
PostPosted: Tue Apr 02, 2019 5:37 pm    Post subject: Re: Another sacrilegious idea I had Reply with quote
I love it when people cringe at the idea of drill a hole in your VW. God forbid you accessorize it Rolling Eyes And yeah, yeah, I don't need to hear the reasons why y'all wouldnt do it.
I still like the welded capture nut idea. But then again why would you take the brackets off? You will always have the holes. Think Then that lends itself to just installing them now while the bus is in primer. It is in primer, yes?
After all that, there is this.
https://www.busdepot.com/A9013
1964 1500 S
ryans65
ryans65 is offline
PostPosted: Tue Apr 02, 2019 6:19 pm    Post subject: Re: Another sacrilegious idea I had Reply with quote
What about attaching the mounts to a large magnet like you would find on one of those magnetic tool dish things? I think a decent magnet would be plenty strong enough to hold on some tent brackets.
smoothfinishes
smoothfinishes is offline
PostPosted: Tue Apr 02, 2019 9:09 pm    Post subject: Re: Another sacrilegious idea I had Reply with quote
Not a bad idea to use magnets.
But if you want the mounts somehwat permanent and the headliner is in place.
Use some rivets, no welding, backing to mess with etc.
4 cylinders of smiles..
