Joe71885 Samba Member
Posted: Tue Apr 02, 2019 2:29 pm Post subject: Windshield Window Wiper Hole Placement |
Hello all,
I bought a bus and the previous owner had the window wiper holes filled and I am going to have them redrilled out for window wipers (have to get the vehicle inspected and it needs wipers). I was trying to find out if there were exact measurements out there. I couldn't find anything and was wondering if anybody had anything or knows where it is. I spent the last couple hours looking through forums but couldn't find any. Any help would be appreciated.
thanks guys
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51148 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Apr 02, 2019 3:39 pm Post subject: Re: Window Hole Placement |
How were the holes filled?, try looking at the back side of them, you'll either see some welding, or a long curly turd of filler ooozing out of the former hole, if it's filler grab it with pliers and break it off from the back.
If it's welded measure from the bottom edge of the depression towards the center as well as from each side equally, there's where the hole goes.
Another way is to find a washer that just fits into the depression, the hole in the middle is where the wiper hole should be. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Apr 02, 2019 3:45 pm Post subject: Re: Window Hole Placement |
I checked, it has a metal tab there now where the oozy stuff would be coming out. |
Posted: Tue Apr 02, 2019 3:51 pm Post subject: Re: Window Hole Placement |
Here is a photo
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Apr 02, 2019 4:18 pm Post subject: Re: Window Hole Placement |
That looks like a two person weld to me. a buddy held that scrap of galvanized (yum) tin up there on the backside while the welder tacked in the hole.
You just have to have a little trust that your wiper holes remain somewhere centered in their wells. These wells are approx. 27mm in circumference, with the shaft holes approx. 13 mms. in dead center. I'd do as busdaddy suggests. Slap something 27mm round in there and mark the center. Then drill it out. I'd start with small bits to establish a good center and use step bits until the metal tin backer snaps loose of the backside or when I hit 13mm, whichever happens first. There are two layers of aligned VW metal there- and one layer of PO jacknard's metal scrap.
If your seams are fully filled with bondo (you should have a full width, visible overlapping seam from the windshield frame metal over the nose sheet metal) then actual measurements from us to you are useless. _________________
EverettB wrote: |
FU#5 |
Posted: Tue Apr 02, 2019 6:51 pm Post subject: Re: Window Hole Placement |
hitest wrote: |
If your seams are fully filled with bondo (you should have a full width, visible overlapping seam from the windshield frame metal over the nose sheet metal) then actual measurements from us to you are useless. |
Thanks guys |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Tue Apr 02, 2019 8:30 pm Post subject: Re: Window Hole Placement |
To make this thread accessible to someone using the search function in the future... maybe edit the title to read: Windshiled Wiper Pivot Hole Location
0.4” or 10 mm from edge of lower lip to center of hole.
Or... since you apparently have wiper pivot washers handy... lay rubber washer on the metal (where you can tell from my paint exposure)... and mark the center.
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Apr 03, 2019 9:00 am Post subject: Re: Window Hole Placement |
Joe71885 wrote: |
Here is a photo
Probably those sheet metal patches were just tacked welded into place so a glob of bondo could be slathered over the holes. Might try Dremil to grind off the sheet metal patches from inside and then see if you can push something fairly sharp like a nail thru the bondo. _________________ In Stereo, Where Available! |
hitest Samba Member
Posted: Wed Apr 03, 2019 11:05 am Post subject: Re: Windshield Window Wiper Hole Placement |
Hold the phone, you want to be EXTREMEMELY careful if suggesting you punch through it in or out- even with a small nail. Without knowing exactly how everything was mudded- you could easily punch out a piece of paint and bondo the size and shape of a puzzle piece of Saskatchewan. As discussed earlier, if your seams have been filled- there is more sculpture happening here than what is being photographed.
In other words, you don't want to do this. And I rarely disagree with Eric&Barb advice. _________________
EverettB wrote: |
FU#5 |
Posted: Wed Apr 03, 2019 4:36 pm Post subject: Re: Windshield Window Wiper Hole Placement |
Definitely push inward with a nail should not break out a huge area. Did this with my 1963 K Ghia that the body shop covered ALL the drain holes in the lower part of the body. No problem doing that if one is careful. _________________ In Stereo, Where Available! |
Posted: Wed Apr 03, 2019 5:30 pm Post subject: Re: Windshield Window Wiper Hole Placement |
I'd rather start from outside the bus with a small drill and then file outwards till you hit metal lifting the file on withdrawl, you may have gotten away with it once, but I've cracked or chipped too many "bondo surprises" to trust the last guys prep work. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Thu Apr 04, 2019 7:11 am Post subject: Re: Windshield Window Wiper Hole Placement |
Use a step drill from the outside. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
