caramel.pegasus Samba Member
Joined: January 11, 2017 Posts: 16 Location: Columbus, Ohio
Posted: Wed Apr 03, 2019 11:38 pm Post subject: Mismatch engine and transmission. In need of clarification. |
Hi! I want to get my rail running, but im hitting a lot of confusion as to what I need to complete the puzzle. Been reading and many people are trying to do the opposite of where im going.
I'd like to mate a ~1965 40 horse 6-VOLT engine to a 1971 manual bus transmission from a 12v.
I have the engine. Seems to be all stock. Flywheel measures about 7.25" / roughly 184mm on the inside part if im measuring it correctly.
I also have a 002 3 rib bus transmission.
I am missing clutch kit, and starter.
Is it possible for me to just pick up a 6v starter, put it in the 002 transmission, pick up a clutch kit for 1971 bus, and mate the engine w trans? or am I missing something?
I read talks about a bushings, does that also apply in this case? _________________ ---
~Wolfe
My project: https://www.thesamba.com/vw/forum/viewtopic.php?t=716578&postorder=asc
https://twitter.com/aecii_3d
PART WANTED: Bell housing off a bus transmission to make a bench test stand. Preferably from a junked transmission. Message me how much you want for it. Paypal ready.
Last edited by caramel.pegasus on Fri Apr 05, 2019 6:59 am; edited 2 times in total |
don1357 Samba Member
Joined: April 15, 2017 Posts: 384 Location: Palmer Alaska
Posted: Thu Apr 04, 2019 12:36 am Post subject: Re: Mismatch engine and transmission. In need of clarification. |
The starter had to match the flywheel: 6v starter to 6v flywheel, 12v starter to 12v flywheel.
What's the alternator? Even if you have a 6v starter/flywheel combo you can still run a 12v system, the 6v starter is built tough enough to take it. |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Thu Apr 04, 2019 2:24 am Post subject: Re: Mismatch engine and transmission. In need of clarification. |
You could just get a 12v flywheel, clutch and starter and not worry about it. |
joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Thu Apr 04, 2019 8:27 am Post subject: Re: Mismatch engine and transmission. In need of clarification. |
The 6v flywheel is 180mm, the 12 volt is 200mm. You can buy a new 200mm flywheel and bolt that on. You need a matching clutch disk and pressure plate. Make sure you get the correct matching pressure plate and throwout bearing. one style of plate has a disk that the throwout bearing rides on, another does not, also depends if the tranny has a guide tube for the throwout bearing. As mentioned, you can use the 6v starter with 12 volts, it just spins faster. You will have to change the bushing, they make conversion bushings. You can also buy a 12 volt starter for an autostick bug, and it will not use the bushing, its self supporting. you should be able to get one at any auto parts store. Of course you will need a 12 v generator and regulator, and coil, and charging light bulb (idiot light). |
Posted: Thu Apr 04, 2019 8:48 am Post subject: Re: Mismatch engine and transmission. In need of clarification. |
joemama wrote: |
This is the transmission. Is that the guide tube you mention on there?
~Wolfe
Last edited by caramel.pegasus on Thu Apr 04, 2019 9:01 am; edited 1 time in total |
Just thinking about this, I may have given you wrong info wether the 6v starter gear fits the 200mm flywheel, not sure. you might be able to just use all your current 180mm stuff in the bus transaxle, with a bushing change, and the right kind of throwout bearing and throwout shaft. When I went to a bus trans in my buggy, I had to cut the trans input shaft down, as it was too long, wasnt a big deal. |
Posted: Thu Apr 04, 2019 8:54 am Post subject: Re: Mismatch engine and transmission. In need of clarification. |
joemama wrote: |
Id like to use what i have while deciding if to go ecotec route. Keeping expenses down while learning. How much did you have to trim? Would trimming the input shaft hinder future use of a different engine ? Thanks! _________________ ---
~Wolfe
PART WANTED: Bell housing off a bus transmission to make a bench test stand. Preferably from a junked transmission. Message me how much you want for it. Paypal ready. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Apr 04, 2019 9:13 am Post subject: Re: Mismatch engine and transmission. In need of clarification. |
You have late model throw out bearing in transaxle, 71 and later......
Pressure plate will not have ring on it...
Posted: Thu Apr 04, 2019 10:25 am Post subject: Re: Mismatch engine and transmission. In need of clarification. |
What motor was in the rail before? If it was a type 1 vw, then its probably been trimmed already. |
Posted: Thu Apr 04, 2019 11:58 am Post subject: Re: Mismatch engine and transmission. In need of clarification. |
joemama wrote: |
Unknown non-vw. I was told it was a v6 with an adaptor.
Dale M. wrote: |
Dale |
Thanks Dale! Very helpful as always. _________________ ---
~Wolfe
