Power window motor placement
dgbeatty
dgbeatty is offline
PostPosted: Fri Apr 05, 2019 9:10 pm    Post subject: Power window motor placement Reply with quote
I hope I can explain this clearly.
I want to place the motor up high in the door where the factory speaker would be. My thought is this, and I have read nearly every post regarding power window, could this be accomplised by exchanging the cable housings and swapping the cable end for end. PLEASE tell what I an missing. Perhaps I should just relax and polish the steering gear or perhaps some other useful endeavour.
When all else fails read the instructions. Schau in das Buch
16CVs
16CVs is offline
PostPosted: Fri Apr 05, 2019 9:26 pm    Post subject: Re: Power window motor placement Reply with quote
I don't understand why you would want to, but I'll play along. I am not sure if you could get the motor up past the crash bar.
You would have to Re make the cables and the housing and calibrate exactly how much cable you'd need.
The motor housing has an extra un used hole as well as extra mouning ears which may help you or hinder you.
Forge on, I'm interested in how it turns out.
Stacy
1987 Syncro Multivan Triple knob (bastard)
Samba member # 14980
dgbeatty
dgbeatty is offline
PostPosted: Sat Apr 06, 2019 7:22 am    Post subject: Re: Power window motor placement Reply with quote
Thanks Stacy. Our van, bought new, has manual windows. It also has leather door panels with a nice speaker exactly where the electric window motor would go. Hence my desire to make more work for myself.
The reason for wanting an electric window on the passenger side is that it is increasingly difficult to reach. I retired in 2005 you can do the math on that 😊.
16CVs
16CVs is offline
PostPosted: Sat Apr 06, 2019 9:43 am    Post subject: Re: Power window motor placement Reply with quote
So put an aftermarket unit in. It puts the motor up near the speaker. Their slower and noisier than a stock unit and the door glass does not go all the way down.
I have quite a few of them and will give you agreat price on one.
Stacy
