Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Sun Apr 07, 2019 11:41 am Post subject: Non OE Side Mirror Bracket Design? |
Hi folks.
Picked up these new looking "Pathfinder" (not Nissan) mirrors for $10 CND, still in the box.
They look ~ 2-3" longer than the stock power mirror so maybe not much heavier.
I see the LT mirror bracket design.
Would a bracket mounted only at the stock mirror mount keep this mirror stable at freeway speeds? Make bracket out of aluminum? (would probably use mild carbon steel since I'd likely need to weld it)
Just a rambling "what if" thought if I found a Vanagon requiring an inexpensive mirror upgrade; these would not be attractive, aesthetically speaking.
edit: hypothetically speaking, these mirrors would be used on a Vanagon with early style mirrors.
Neil.
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
jimf909 Samba Member
Posted: Sun Apr 07, 2019 11:50 am Post subject: Re: Non OE Side Mirror Bracket Design? |
What don't you like about the aero mirrors that may require an upgrade? _________________ - Jim
Abscate wrote: |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1884 Location: Montreal
Posted: Sun Apr 07, 2019 12:00 pm Post subject: Re: Non OE Side Mirror Bracket Design? |
I vote, keep what you got mounted. |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Sun Apr 07, 2019 12:05 pm Post subject: Re: Non OE Side Mirror Bracket Design? |
That kind of mirror yo'll really want to build somethingthat suppoots it top and bottom. LT/Syncro16 style, or look up "junior west coast mirror" for inspiration.
You'd be drilling holes most likely... |
Posted: Sun Apr 07, 2019 12:06 pm Post subject: Re: Non OE Side Mirror Bracket Design? |
jimf909 wrote: |
What don't you like about the aero mirrors that may require an upgrade? |
Pic shows mirrors that I like and will stay mounted. Used them as a visual reference.
Was thinking about possibility of mounting the non OE mirror to another Vanagon with old style mirrors. Will edit first post to show that more clearly.
VE7TBN |
Posted: Sun Apr 07, 2019 12:11 pm Post subject: Re: Non OE Side Mirror Bracket Design? |
tristessa wrote: |
Thanks Tristessa.
My plan was to build a two arm bracket to support upper-lower mount and mount that to the stock mount point. Even so, I can see more clearly that the mirror would likely be unstable under certain conditions.
VE7TBN |
