Cainibus Samba Member
Joined: September 10, 2018 Posts: 22 Location: Pennsylvania
Posted: Tue Apr 09, 2019 2:31 am Post subject: Help! Not such a great engine stand deal. |
Purchased an engine stand that I thought had the correct adapter......whhhaa, whhhhaaa. No bueno, the mounting holes are about a 1/4 inch short. Please understand still kinda new at air cools. It seems that the diameter of the adapter base is only 1 7/8” pipe. Here lies the problem, the stand looked professional built(probably as old as my bus), but now I cannot find an adapter that fits. Please HELP.!!!!! Note the engine is a dual 1600, not OG. Just wanted to give all the info. Thanks for any help!
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1658 Location: Budapest, Hungary
Posted: Tue Apr 09, 2019 4:42 am Post subject: Re: Help! Not such a great engine stand deal. |
Did you try mounting the stand to the upper and lower mounting points on the engine, or just with the lower mounting points? They are designed to use the upper and lower mounting points on one side of the engine, so that you can split the case halves. |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Tue Apr 09, 2019 5:09 am Post subject: Re: Help! Not such a great engine stand deal. |
Drill a new hole? ... _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
74 Thing Samba Member
Posted: Tue Apr 09, 2019 6:41 am Post subject: Re: Help! Not such a great engine stand deal. |
npbusguy wrote: |
Ditto-you are using the side to side ones not upper and lower. |
don1357 Samba Member
Joined: April 15, 2017 Posts: 387 Location: Palmer Alaska
Posted: Tue Apr 09, 2019 6:51 am Post subject: Re: Help! Not such a great engine stand deal. |
What they said.
The engine splits down the middle. If you were to bolt the stand arms across the bottom of the engine you wouldn't be able to split the case open. It mounts to one side and in specific the side with the distributor and fuel pump. |
Posted: Tue Apr 09, 2019 7:32 am Post subject: Re: Help! Not such a great engine stand deal. |
npbusguy wrote: |
I did and they don't line up. I was wondering because of the small base pipe diameter, I am struggling to find find one that will work. So was wondering if someone had one, one for sale, or where I can find one. Not sure if the stand is a frankensteiner. Thanks
Spike0180 wrote: |
Drill a new hole? ... |
There is not enough material left to drill into, if it where that simple I wouldn't have asked. Thanks though, have to ask the obvious first. Just trying to save this stand and not have to buy a new set up.
Thanks |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Tue Apr 09, 2019 7:36 am Post subject: Re: Help! Not such a great engine stand deal. |
I’m sure you can still buy a “bench mounting” stand in any of the VW specialty shops around. Then have the base welded to your stand. _________________ Some people are so busy being clever they don't have time enough to be wise. |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Clara Samba Member
Posted: Tue Apr 09, 2019 9:12 am Post subject: Re: Help! Not such a great engine stand deal. |
Erik G wrote: |
like this, and yes, bend if needed
That is an obvious solution I didn't think of, see if I can even pull this off. Sorry sometimes the obvious is.missed. Give it a shot tonight. Thanks! If I can bend big duh on me! |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Tue Apr 09, 2019 9:54 am Post subject: Re: Help! Not such a great engine stand deal. |
Notes on engine stand yokes:
- I like the ones from VW Alley. They fit a Harbor Freight stand.
- The 3 arm one works well for engine assembly, but the center arm can interfere with the engine sheet metal. The 4 arm unit is better because you can trim the center area to clear the sheet metal, in needed.
- the important point of any yoke is to have sufficient steel area against the engine case to distribute the load out, so that it isn't all concentrated at the mounting holes. More area is better! Do avoid using generic adjustable arm yokes. They're designed for cast iron engine blocks. No load spreading whatsoever. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Erik G Samba Member
Posted: Tue Apr 09, 2019 11:15 am Post subject: Re: Help! Not such a great engine stand deal. |
Clara wrote: |
FWIW, 25hp through 2 l engine bolt up to a tranny the same.
or bigger
I like a 4 wheel stand better, no problems with a drain pan, and feels better when working on something more expensive _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Tue Apr 09, 2019 11:39 am Post subject: Re: Help! Not such a great engine stand deal. |
What is that extra thing near the left (in the original posted photo) flange?
That looks correct just (like they^^^said) bent 1/4". It is a pretty common 3-point stand. It knocks down for storage. They are tippy but work. I have that same one. |
Posted: Tue Apr 09, 2019 4:01 pm Post subject: Re: Help! Not such a great engine stand deal. |
One vice + one torch + 2 cinch straps = Fixed!!!!
Thanks again for the advice!
Posted: Tue Apr 09, 2019 4:10 pm Post subject: Re: Help! Not such a great engine stand deal. |
BarryL wrote: |
It's a latch to lock in the flywheel
