Reduction box cruising engine.
deltabrent
deltabrent is offline
PostPosted: Fri Apr 12, 2019 11:29 am    Post subject: Reduction box cruising engine. Reply with quote
I posted a question in the engine forum awhile ago about building an engine and it got really confusing really fast. I have several engine, carbs, parts, pieces and most of what I need to build an engine for my 62 bus with Reduction Boxes. I want a good reliable cruising engine that isn't going to break a land speed record, require advanced building skills and won't break the bank.
I have a 1500cc that needs a crank grind, a couple other single ports in unknown condition, a 1600DP I haven't looked at, a Zenith NDIX, 2 Bug sprays, 3 early Bosch mechanical Distributors and lots of other smaller parts.
Whats a good no machining required torquey engine I could put together that a new builder could cobble together? (I"m not going to build a 2000cc+ dual carb, super engineered engine!)
Culito
11010101
Culito is offline
PostPosted: Fri Apr 12, 2019 12:15 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
I liked my 1600 single port I had in my SC with big nut RGBs.
Copyright CJ Industries, Inc.
'64 standard
'62 bug
johnnypan wrote:
Erik G
Erik G is offline
PostPosted: Fri Apr 12, 2019 12:38 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
yep, a 1500 or 1600 single port 30pict and big nut redux boxes are great.
Bruce Amacker
Bruce Amacker is offline
PostPosted: Fri Apr 12, 2019 12:58 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
1600DP
New Chinese counterweighted crank
CB 2280 cheater cam
Whatever carb you like, I'd do a 34Pict. I have another engine with a 32NDIX but I like simplicity, the throttle linkage setup on that was not simple.
I've run several different SP and DP engines in busses, I'll never do a SP again.
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
62DoKaGuy Premium Member
62DoKaGuy is offline
PostPosted: Fri Apr 12, 2019 1:46 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
This is exactly what I'm considering putting in my '59 SC. Stock big-nut and a single-port 1600 from our Thing. How was it on hills vs. flat-land?
Wenige Menschen denken, und doch wollen alle entscheiden.
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there...
4/62 Double Cab
4/59 Single Cab
Erik G
Erik G is offline
PostPosted: Fri Apr 12, 2019 2:05 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
I daily drove mine from sacramento to the motorcycle shop that used to be on 49 in auburn. I did fine around sacramento, would have to floor it getting close to auburn on the freeway to get up, but then once in auburn driving around at normal speeds was fine. It's the "get around the slow vw" mentality other people have that will get you.
PostPosted: Fri Apr 12, 2019 2:14 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
Perfect, you know what hills I meant! Going up towards Auburn and then out 50 East to Placerville...and beyond.
4/62 Double Cab
4/59 Single Cab
Culito
11010101
Culito is offline
PostPosted: Fri Apr 12, 2019 3:20 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
Mine was fine on the flats but big hills were 40-ish mph (sometimes top of 3rd gear) while giving apology waves to the people behind / passing me.
It's the VW way...
Also why I'm building a 2.0L type 4.
'64 standard
'62 bug
johnnypan wrote:
notchboy
notchboy is offline
PostPosted: Fri Apr 12, 2019 4:06 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
It's the VW way...
Just go bay and build a 2.3 Wink Cool
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
deltabrent
PostPosted: Fri Apr 12, 2019 4:08 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
This was so reasonable and straightforward. Thanks. I instantly was overwhelmed with endless custom ideas on the engine thread. No offence to them but I was lost. Maybe I'll sell the NDIX to fund a crank grind and just rebuild the 1500, put a 30pict1 on there (I like those), maybe a bit more interesting cam and a simple header exhaust.
Manfred58sc
Manfred58sc is offline
PostPosted: Fri Apr 12, 2019 4:19 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
I love a 1500 with OG [email protected], cool running, plenty of torque, PICT 30-1, 009, some type of free flow exhaust. Everything just lines up perfect,reliable,durable. Roll an enormous fake spliff and have it hanging out of your mouth as people pass you and wave weakly....
Drivin' a split and a fat chick!!
zozo
zozo is offline
PostPosted: Fri Apr 12, 2019 5:19 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
What distributor are y’all using?
Culito
11010101
Culito is offline
PostPosted: Fri Apr 12, 2019 5:59 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
I used a Bosch 010 with a H30/31. Good combo. Have that on my bug, too.
'64 standard
'62 bug
johnnypan wrote:
cdennisg
cdennisg is offline
PostPosted: Sat Apr 13, 2019 9:22 am    Post subject: Re: Reduction box cruising engine. Reply with quote
Bruce Amacker wrote:
1600DP
CB 2280 cheater cam
I have had much good luck with a stock 1600 SP and big nut trans. I have also run many miles with a similarly set up DP. Curious about your SP issues.
Balancing is the key. Make things smooth while spinning, and everything just works better.
Organization, although not always present, is unique to one's own perspective.
-AvE
deltabrent
PostPosted: Sat Apr 13, 2019 11:19 am    Post subject: Re: Reduction box cruising engine. Reply with quote
I have a small nut reduction box setup. I think? Isn't that whats in a 62? I'm guessing it doesn't make a huge difference?
Joey
Joey is offline
PostPosted: Sat Apr 13, 2019 12:04 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
At 60 mph your engine would spin close to 275 RPMs less if you changed just your small nut reduction boxes to big nut reduction boxes.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '56 Beetle - '65 Beetle
cdennisg
cdennisg is offline
PostPosted: Sat Apr 13, 2019 12:37 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
A slightly taller tire would have a similar effect, if available.
-AvE
deltabrent
PostPosted: Sat Apr 13, 2019 5:22 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
I just rebuilt my reduction box rear end. I'm not switching it out.
Erik G
Erik G is offline
PostPosted: Sat Apr 13, 2019 5:31 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
you'll be much happier at 60mph with small nut redux boxes. Big nuts are comfortable at 65
cdennisg
cdennisg is offline
PostPosted: Sat Apr 13, 2019 5:35 pm    Post subject: Re: Reduction box cruising engine. Reply with quote
Agreed.
-AvE
