cmonSTART Samba Member
Posted: Sat Apr 13, 2019 3:53 pm Post subject: Paint with a roller - fail! Help? |
Hey Folks, so while I'm going through the bus and doing body work here and there I am repainting with a good Alkyd paint that matches the original color. Sure it's messy and you can see brush marks and such, but things are protected and really it's just temporary.
Well, I tried a roller today and it was a disaster - I ended up removing it all and just dealing with the brush. Post-roller, the paint had lots of roller lint stuck in it - a lot! Plus there were air bubbles everywhere and it was extremely.... textured? I've seen some decent roller jobs on here and for the life of me can't find the thread I'm looking for right now.
The Alkyd paint I'm using is a bit on the thick side so I splashed a bit of thinner in it - maybe I didn't use enough. Is there a different type of roller I should be using rather than the standard Ace Hardware special?
I'm not looking for show quality right now - just not a train wreck. Anyone have any input? _________________ '78 Bus 2.0FI
de K1IGS |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Sat Apr 13, 2019 4:05 pm Post subject: Re: Paint with a roller - fail! Help? |
cmonSTART wrote: |
I'm not looking for show quality right now |
Yeah, you don't have to worry about it.
Years ago a friend bought a old Ford F1 pickup that was painted with house point. Once media blasted the metal was in perfect condition. The house paint saved the body.
Have you put any thought into how to remove it when you want a good paint job? _________________ Glenn
Member #1009
#BlueSquare |
Darn it - found the thread! I should have used a foam roller!
de K1IGS |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Sat Apr 13, 2019 4:09 pm Post subject: Re: Paint with a roller - fail! Help? |
Search "roll and tip" paint method _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
Posted: Sat Apr 13, 2019 4:13 pm Post subject: Re: Paint with a roller - fail! Help? |
How it should look:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
Glenn, I will likely just take some time and sand it down - not too bad with power tools. Either way that's likely a few years out.
I think I'm going to give this another shot. I was going to stick with stock colors but I might do something radical. _________________ '78 Bus 2.0FI
de K1IGS |
Glenn Mr. 010
Posted: Sat Apr 13, 2019 4:18 pm Post subject: Re: Paint with a roller - fail! Help? |
cmonSTART wrote: |
I was going to stick with stock colors but I might do something radical. |
Stock colors will look better. Anything too off will look odd. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Apr 13, 2019 4:20 pm Post subject: Re: Paint with a roller - fail! Help? |
Probably won't be too off - I really like the Dakota Beige color on the top of the bus - I might just do the whole thing that color. _________________ '78 Bus 2.0FI
de K1IGS |
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Sat Apr 13, 2019 5:48 pm Post subject: Re: Paint with a roller - fail! Help? |
last time I had to remove hose paint from a car I wanted to hunt the guy down and speedbag his ballsack.
house paint clogs sand paper like you can't imagine. the only sane way to remove is media blasting _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Sat Apr 13, 2019 7:39 pm Post subject: Re: Paint with a roller - fail! Help? |
skills@eurocarsplus wrote: |
house paint clogs sand paper like you can't imagine. the only sane way to remove is media blasting |
Citrus Strip did ok on the house paint on my Boston Theatre bus. Can't say the same for the bondo they used to "build" the rear corners.. _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
Posted: Sat Apr 13, 2019 7:48 pm Post subject: Re: Paint with a roller - fail! Help? |
I'm sure there are products to remove it. when I do something it's a time=money thing, and I don't like to cross pollinate products when I'm doing body work. 99% of the time I media blast. far faster than hand stripping and cheaper than buying sand paper.
I can have a whole bus naked in about 2-3 hours for 1k. learned my lesson a long time ago...spend your time, or spend your money...don't spend both _________________
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Posted: Sat Apr 13, 2019 7:52 pm Post subject: Re: Paint with a roller - fail! Help? |
I can have a whole bus naked in about 2-3 hours for 1k. learned my lesson a long time ago...spend your time, or spend your money...don't spend both |
Why spend another $1000 to remove paint now? .... he can buy a gallon of exterior house paint on sale for $25, and doesn't need the bus to look good, only needs to hide the rust and bondo until he flips it when he is done with it. Use newspaper and cheap masking tape to cover the windows while painting. Pull a couple old tee shirts over the front seats as upholstery, find some carpet ripped out of a home or commerce for the back floor, throw a couple of dryer fabric sheets in the bus for scent & poof - Done!
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun Apr 14, 2019 7:39 pm Post subject: Re: Paint with a roller - fail! Help? |
SGKent wrote: |
Worked for me! I better stay the hell out of Connecticut I guess or wear a codpiece when passing through...... _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Mon Apr 15, 2019 2:07 am Post subject: Re: Paint with a roller - fail! Help? |
Penetrol will help to get prevent both brush and roller marks, while adding hardner will speed up the curing time.
It is my understanding that there are at least two basic kinds of alkyd paints. The one I used on my 77 14'ish years ago shows no scratching after having driven many miles of brushy dirt roads and having been generally mistreated. I don't know enough about the different alkaloid paints to say which kind works best, don't even know which kind I used as I didn't know that were different kinds of alkyd paints when I bought it.
Gregg in the 603 Samba Member
Joined: April 13, 2013 Posts: 404 Location: New Hampshire, USA
Posted: Mon Apr 15, 2019 6:29 am Post subject: Re: Paint with a roller - fail! Help? |
Quote: |
speedbag his ballsack |
I don't Lol much. I just did _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Mon Apr 15, 2019 8:51 am Post subject: Re: Paint with a roller - fail! Help? |
TomWesty wrote: |
SGKent wrote: |
Worked for me! I better stay the hell out of Connecticut I guess or wear a codpiece when passing through...... |
Please see my ad in classifieds for OG codpieces.
Steve and Don make any thread worth reading.... _________________ .ssS! |
SGKent Samba Member
Posted: Mon Apr 15, 2019 9:36 am Post subject: Re: Paint with a roller - fail! Help? |
Abscate wrote: |
Steve and Don make any thread worth reading.... |
Are still trying to get $650 each for those smelly old things, or have you come to your senses? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
jlrftype7 Samba Member
Posted: Mon Apr 15, 2019 10:50 am Post subject: Re: Paint with a roller - fail! Help? |
Although you're set with the Media Blasting, as a tip, use Festool Granat Abrasive for Removing Paint from something. It was developed with the Automotive World in mind, and is now being used as their Go-To abrasive for almost any material that's common like Wood, Metal, Paint, Plaster, Film Finishes etc. So much so that Festool discontinued 2 other abrasives since Granat sales tanked those other 2 abrasives with Commercial Users switching out entire shops to Granat since it greatly simplified buying Abrasives with only 1 type needed, in what ever grits are useful for the user.
If you don't want to spend the money on one of their Sanders to mount Granat Discs onto, you can still buy Granat in rolls of different Grits that have a foam backing, so they're flexible for tight spots and other hard to reach places. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Mon Apr 15, 2019 6:30 pm Post subject: Re: Paint with a roller - fail! Help? |
Wow... this thread went all... Samba.
de K1IGS |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Tue Apr 16, 2019 7:36 am Post subject: Re: Paint with a roller - fail! Help? |
Alkyd paint is not house paint. Alkyd will be fine on the exterior of your Bus though it could be improved with the use of a hardener and still be rolled on, if that is your only option.
I would suggest that you find a local automotive paint supplier for supplies and advice. The alkyd paint I buy through my supplier is cheaper than Rustoleum at the hardware store and I use it with a hardener made to go with the product. They could make it up in whatever color and sheen you want. For a roller paint job I wouldn't make it too glossy. Try satin.
I use this on tin, suspension parts, wheels, etc..
_________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Wed Apr 17, 2019 11:38 am Post subject: Re: Paint with a roller - fail! Help? |
Make sure the runs are included, they add character.
I get it, especially for you as that is your business time\money. When I lived near people in southern NH, would go for blasting (even as a hobbyist) over doing it myself. Now, 40 miles south of Canada, it is a time thing too. It takes 75 minutes in good weather to get to a grocery store so I did a search for "media blasting" near me. Only a 6.5 hour tow one way . _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
