padgett Samba Member
Joined: December 08, 2017 Posts: 141 Location: California
Bobnotch Samba Member
Posted: Mon Apr 15, 2019 12:28 pm Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
If I had to make a guess, I'd say long. I suppose you could check against ISP's site, to see what numbers they use. I know my 65 uses the long style. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Apr 15, 2019 1:45 pm Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
hey again bob
From what I can tell, the real difference is in the spline that the crank handle attaches to. The 'short' one is shorter. But comparing the two it does look like the gear side is taller. I'll take a pic tonight when i get home of how it looks, but it definitely looks like the gear should be higher up in the center guide.
Wouldn't surprise me as I'm finding a lot of parts on my car aren't type 3 but from busses. Previous owner had 3 of em, so it would make sense he slapped on what he had around just to sell it. |
Posted: Tue Apr 16, 2019 9:36 am Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
pics. Note how low the gear sits in the center guide. Granted this is the ISPWest repro, but still. I would think the gear would sit up higher than that.
is this expected?
Posted: Mon Apr 22, 2019 6:38 pm Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
something i thought about. Is this winding gear supposed to sit this far down into the cabin? how its pictured is how it sits with the retaining bolts tightened up. Other pics i've seen have the winding gear assembly almost flush with the headliner. Is this correct? |
Posted: Tue Apr 23, 2019 12:31 pm Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
padgett wrote: |
Mine sits almost flush under the headliner. I'm wondering if there's something spacing yours out to sit on the headliner. Might be worth investigating. You could use the plastic spoon shaped piece to help determine what's going on. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Apr 23, 2019 2:01 pm Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
I snapped a pic of the underside yesterday as well. You can see the dirty outline of where the winding assembly I have sits. And the sunroof 'frame'. I really dont see anywhere for this assembly to fit into.
Its possible I have an assembly from another car, but through some reaserch it seems like the winding gear is pretty much the same across bugs/type 3's of that era. Biggest difference being the long and short shaft that I posted in my 1st reply.
Could be from a bus? But i'll look further. Its great to have confirmation that something strange is going on.
Thanks bob. |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4190 Location: Pasadena CA/DTLA soon China
Posted: Wed Apr 24, 2019 7:59 am Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
It looks like when you replaced your headliner, you forgot to replace the sunroof roof foam. It is a preformed piece that sits opposite the plastic covers. It give the gear a little niche to fit into the headliner.
#42 _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
Posted: Wed Apr 24, 2019 10:04 am Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
ALLWAGONS wrote: |
#42 |
This makes a lot of sense, thanks Allwagons.
Too late to replace that now
That makes sense as to why its sticking down so much. Unfortunately this doesn't get to the root of my initial problem, which is why my gear is so recessed in the center guide. |
Posted: Wed Apr 24, 2019 9:07 pm Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
I didn't see what your winding gears look like but here are pics of a bug VS type 3 for comparison.
Type 3 on bottom
Type 1 on top 2
Type 3 on right
Type 1 on left
Type 1
Type 3 _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Posted: Thu Apr 25, 2019 10:13 am Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
Thanks for posting, its given me a lot to chew on.
I'll take a look at my gear's part number and see.
But eyeballing through those pics, doesn't seem like theres a huge difference in the winding gears except for the crank spline being long or short.
I don't think my issue is with the winding gear...i might not even have an issue. Just looks odd that the gear is so far recessed in the center guide. |
Posted: Thu Apr 25, 2019 12:57 pm Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
If you look at the sunroof FAQ there are more than one sunroof setups. Top and bottoms. I own set #1 of ISP’s aluminium pieces but it sits in my showcase. I don’t know what base they used as a template. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Posted: Mon Apr 29, 2019 6:25 pm Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
just checked my part number
its 117877403
Based on what you posted, its from a bug. I did see some winding assemblies on the T3 classifieds with my part number though, so I'm going to surrender myself to the experts to answer that one. It'd make sense some part numbers would be shared. |
Posted: Tue Apr 30, 2019 9:42 am Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
padgett wrote: |
I snapped a pic of the underside yesterday as well. |
There's something off about this pic, but I can't quite figure it out. It almost looks like the threaded bosses are mushroomed, not allowing the gear base to fit over them. If this is happening, the the gear will sit lower in the cable mixing area. I only say that, because when you look at the 117 gear box, it looks like the holes are slightly counter bored to allow the threaded stand offs to fit inside. I don't know what size the holes are in the 313 gear box, so I can't say they will slip over those threaded inserts or not.
Note, I'm just comparing the 2 from photos, so I can't be sure if it's an optical illusion or not. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu May 02, 2019 11:17 am Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
Bobnotch wrote: |
padgett wrote: |
Note, I'm just comparing the 2 from photos, so I can't be sure if it's an optical illusion or not. |
I'll take a look at the treaded bosses on the center guide, but i can't comprehend why they'd be mushroomed.
I can definitely cut down the bosses or chamfer the winding gear a bit more, but I don't think that'll get me closer to my solution. When everything's mounted up, the winding gear is flush to the frame. Giving it a bit more room to insert, it would still hit against the sunroof frame.
I'm outa ideas. |
Posted: Fri May 03, 2019 9:42 pm Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
You are 100% right, 117 877 403 (beetle part) was used on all type 3 after chassis # 318 000 001. In other words . >'68. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Posted: Fri May 03, 2019 9:47 pm Post subject: Re: Sunroof Gear Assembly. Long or short shaft? |
padgett wrote: |
is this expected?
I also noted you haven't screwed the center piece down into the sunroof sheet metal. That willl bring it closer to the center winding gear. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
