earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sun Apr 14, 2019 11:03 pm Post subject: Bilstien VW jack for play car |
I have a Bilstien VW jack I was thinking about modifying to work with my car but I don't want to cut it up if they are worth any thing.
I need to make it about 4" longer to get the back tire off the ground, I was think about cutting it off about 2" from the bottom and sleeve the outside with a 8" tube and welding it back together with a 2" overlap. I also want to change the socket on the car with something a bit stronger.
I have a couple of 48" Hi-Lift's but the are so heavy and if you don't build a HD mount they are a pain to deal with.
Any body have any pictures or ideas for modifying and mounting them?
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
dustymojave Samba Member
Posted: Mon Apr 15, 2019 3:36 am Post subject: Re: Bilstien VW jack for play car |
I use a now old-school American car bumper jack.
It;s the horizontal gray bar. Wing nut holds it on a bolt welded to a bracket. Tab on the back end with a rod that has a shock mount rubber holds the top. Base plate mounts below. Handle stows inside the jack.
Mine is a Ford (like a Lincoln) from a wrecking yard. It has an extra large base plate. Weight is a tiny fraction of the High lift for my prerunner truck. I mounted mine inside off the cage.
You could make a stand to set the Bilstein jack in without modifying the original jack in case it ever becomes valuable if it isn't now. It could even fold up for stowage.
Is yours the kind that uses friction on the smooth shaft? Or is it one of the rotating handle screw type jacks? _________________ Richard
SoCalBajas Member
don1357 Samba Member
Joined: April 15, 2017 Posts: 387 Location: Palmer Alaska
Posted: Mon Apr 15, 2019 7:24 am Post subject: Re: Bilstien VW jack for play car |
If you only need 4", why not stash a 4" piece of wood and call it a day? |
Posted: Mon Apr 15, 2019 7:26 am Post subject: Re: Bilstien VW jack for play car |
Also a bus jack would do it. |
Posted: Mon Apr 15, 2019 5:07 pm Post subject: Re: Bilstien VW jack for play car |
After you mentioned the screw jack type I forgot I had one of those too, I think it will be easier to modify. It has a square tube that is about 1 1/4" square and a piece of 1 1/2" x .125 sq tube should fit over it, I will cut the foot off and section in a piece of tube and weld the foot back on.
I am not going to mess with the friction jack, It may the type used with Porsche 356's, at least that what some of the pictures I have seen online look like.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Posted: Mon Apr 15, 2019 9:49 pm Post subject: Re: Bilstien VW jack for play car |
Note that my bumper jack has a short piece of 1/2 tube welded to the lift. That's so it hooks on a Baja bumper. It's a little difficult to see in that picture because it's bright blue in front of bright blue. Interestingly, the jack body and base were pretty close to that blue from the factory.
I've also built them with a flat piece there. A piece of angle iron like 2" x 1/8" works for that.
Is that crank-type jack from a split window bus? If it's from a Porsche...Those folks just might spend stupid money for anything related to one. I remember right out of high school passing over a 356 ex road race car running and with American Mag wheels for $500. Now a car like that in the same condition would go for 6 figures. _________________ Richard
SoCalBajas Member
Posted: Fri Apr 19, 2019 11:50 am Post subject: Re: Bilstien VW jack for play car |
Well I finished my jack and I even Painted it in honor of DustyMojave...
[Actually it was the only paint to survive the heat in my shop]
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Posted: Fri Apr 19, 2019 6:59 pm Post subject: Re: Bilstien VW jack for play car |
earthquake wrote: |
Casey |
Hahahhahah. I like it
The extension looks well done. I like the slash cut to relieve stress at the joint that a straight cut would create. _________________ Richard
SoCalBajas Member
