westcoastbullies Samba Member
Joined: July 02, 2002 Posts: 302 Location: DIABLOS SHADOW
Posted: Mon Apr 15, 2019 9:02 am Post subject: ARFLD Annual Replace Fuel Line Day |
Great weekend for a cruise through the farmlands......sunshine, fresh air, no traffic, and the overwhelming smell of gas.
Another complete break down of a fuel line. Barely 2 years old, purchased from a reputable source. This was a close call, right above heater box. The hose appeared fine, no warning seepage...nothing. Was tank side at the copper pass through line, non-flared.
Photos show how quick these lines are destroyed by modern gas.
"TO FIT VW"
after removing the hose it literally unwind itself
German hose (left) which is maybe 6 years old next to crap hose
So I have declared, besides routine inspection, April 14th will be "Annual Replace Fuel Line Day" regardless. _________________ WWW.WESTCOASTBULLIES.COM
TEAM AUOK 1984 SKATEBOARD CO. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Mon Apr 15, 2019 9:21 am Post subject: Re: ARFLD Annual Replace Fuel Line Day |
Or better yet, stop using fabric covered fuel line. As you can see, it's crap. It used to be the standard. No more.
The problem is finding a suitable replacement. Aeromech from the Bay Forum has had good luck with Honda fuel hose (made for modern gas), fit-wise and durability-wise. FWIW _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Mon Apr 15, 2019 8:51 pm Post subject: Re: ARFLD Annual Replace Fuel Line Day |
I was thinking about posting about this.
I've been using the same regular Gates nylon reinforced fuel line on my bug for over 8 years now, and i regularly check the lines. No cracks around the clamp points whatsoever.
Ditch the cloth covered line and go Gates. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
srfndoc Samba Member
Posted: Mon Apr 15, 2019 9:07 pm Post subject: Re: ARFLD Annual Replace Fuel Line Day |
Flenor 5mm multifuel hose has been great. It's ethanol resistant to E85 and you can get it either braided or not.
https://www.belmetric.com/multifuel-hoseethanol-ap...0olmklnfn6
_________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
volksaddict Samba Member
Posted: Tue Apr 16, 2019 5:32 am Post subject: Re: ARFLD Annual Replace Fuel Line Day |
Ditch the cloth covered line and go Gates. |
Agreed! |
Manfred58sc Samba Member
Posted: Tue Apr 16, 2019 7:23 am Post subject: Re: ARFLD Annual Replace Fuel Line Day |
The latest Gates Barricade offering seems to be holding up better than what they sold 4 years ago (it was dissolving from the inside into a chalky grit). I check mine regularly and so far so good. _________________ Fat chick owner/operator |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Posted: Wed Apr 17, 2019 10:10 am Post subject: Re: ARFLD Annual Replace Fuel Line Day |
Does the Gates 1/4" fit will over the stock fittings on a bus or did you also clamp them? |
Culito 11010101
Posted: Thu Apr 18, 2019 1:10 pm Post subject: Re: ARFLD Annual Replace Fuel Line Day |
matthew henricks wrote: |
I always clamp everything, and safety wire around the carb inlets.
Any Gates hose I use (not the FI stuff) does not crack around the clamps. _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Thu Apr 18, 2019 5:11 pm Post subject: Re: ARFLD Annual Replace Fuel Line Day |
I had to clamp the F out of it since it's larger, 6.3mm instead of 5mm.
It worked fine for years though and still looked perfect when I swapped it out.
Now I have 5mm line from the place above, fits much nicer. _________________ How to Post Photos
Posted: Fri Apr 19, 2019 9:43 am Post subject: Re: ARFLD Annual Replace Fuel Line Day |
thanks, this sounds like the new go to...
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Fri Apr 19, 2019 9:56 am Post subject: Re: ARFLD Annual Replace Fuel Line Day |
Just placed an order for a couple meters. Reasonably priced IMHO. Thanks SRFNDOC.
Posted: Fri Apr 19, 2019 10:04 am Post subject: Re: ARFLD Annual Replace Fuel Line Day |
zozo wrote: |
Happy to help. The last thing we need is to lose another bus to fire due to crappy fuel hose. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2830 Location: West Palm Beach, FL
Posted: Fri Apr 19, 2019 3:11 pm Post subject: Re: ARFLD Annual Replace Fuel Line Day |
Thanks. Just ordered 3 meters _________________
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
House Minutia Militia
Posted: Fri Apr 19, 2019 3:39 pm Post subject: Re: ARFLD Annual Replace Fuel Line Day |
Have had decent luck with the Continental 5mm hose for years, but may have to give that Flennor a try if it is more Ethanol resistant... |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7550 Location: Santa Cruz
Posted: Fri Apr 19, 2019 6:07 pm Post subject: Re: ARFLD Annual Replace Fuel Line Day |
They had some great stuff at my local BMW dealer FWIW.. _________________ Bus Motor Build
What’s That Noise?!? |
Stocknazi Samba Member
Posted: Mon Apr 22, 2019 7:42 pm Post subject: Re: ARFLD Annual Replace Fuel Line Day |
I use 3/8" Gates rubber line and it's a tight fit, unlike the 1/4."
Harder to get off, but that may be a good thing, especially if you are not using clamps. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
zozo Samba Member
Posted: Tue Apr 23, 2019 5:09 am Post subject: Re: ARFLD Annual Replace Fuel Line Day |
srfndoc wrote: |
zozo wrote: |
Happy to help. The last thing we need is to lose another bus to fire due to crappy fuel hose. |
Got this in the mail yesterday. If looks and feel count for anything, it's VERY nice stuff. I'll replace my lines this weekend and provide feedback accordingly. |
Posted: Wed Apr 24, 2019 8:48 pm Post subject: Re: ARFLD Annual Replace Fuel Line Day |
Got mine today.
Culito 11010101
Posted: Wed Apr 24, 2019 9:03 pm Post subject: Re: ARFLD Annual Replace Fuel Line Day |
Seems like this is a good place for this PSA:
Safety wire your carb inlets! Or, replace the pressed in brass fitting with a threaded one. _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
Posted: Thu Apr 25, 2019 1:24 pm Post subject: Re: ARFLD Annual Replace Fuel Line Day |
Wow, super nice.
I did mine like this.
