candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Mon Apr 15, 2019 2:15 pm Post subject: Oil pressure gauge pegs |
Hey all,
So i am bench testing a new vdo op gauge using a oil filter sandwich adapter for the sending unit install. I run a wire from the G on the sender to the gauge signal peg. I am just holding this gauge in the engine compartment as a bench test. So i run a negative from gauge to ground strap and then run a positive from gauge to alternator 12v source. What happens is the gauge pegs all the way. What am I doing wrong? I had the same issue with a cheapo chinese gauge and sender a couple of weeks ago but wrote it off as crap. Same thing is happening with this brand new vdo so it is clearly something that I am doing wrong. Any clues here?
As far as gloshift adapter plate, i have read of those not grounding right. Could something be going on here? |
jberger Samba Member
Posted: Mon Apr 15, 2019 2:42 pm Post subject: Re: Oil pressure gauge pegs |
candyman wrote: |
Hey all,
Run a temporary ground to the sender itself.
J |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1491 Location: Victoria,B.C.Canada
Zeitgeist 13 Samba Member
Posted: Mon Apr 15, 2019 2:46 pm Post subject: Re: Oil pressure gauge pegs |
Before I hooked up the sender on my VDO oil pressure gauge, it would peg whenever the key was on. I drove around like that for months. Once I hooked up the sender, it functioned as expected. As mentioned, you need to ground the base of the sending unit. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Mon Apr 15, 2019 3:31 pm Post subject: Re: Oil pressure gauge pegs |
Grounded the base of the sender and no change, still pegs out. Super frustrated here. Sender is ground, gauge is grounded and with a 12 v source from alternator. What am i doing wrong here? For the sender, I ran a ground from one of the unused ports on the glowshift adapter to the engine itself, tested for continuity and there is between the sender and the engine, therefore sender is grounded correct? It is clearly something that I am doing wrong as I got the same exact results with a different set of gauges and senders |
Posted: Mon Apr 15, 2019 3:38 pm Post subject: Re: Oil pressure gauge pegs |
Did you check continuity between gauge and sender? I've had visually perfect crimped fittings that did not convey continuity in the past. This is clearly an issue between ground the sender and the gauge. _________________ Casey--
y u rune klassik? |
Posted: Mon Apr 15, 2019 3:49 pm Post subject: Re: Oil pressure gauge pegs |
Zeitgeist 13 wrote: |
Did you check continuity between gauge and sender? I've had visually perfect crimped fittings that did not convey continuity in the past. This is clearly an issue between ground the sender and the gauge. |
Thanks for that, just double checked and yes all good there. I got to reverse engineer this. Anyone have issues with the glowshift adaptor? |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9935 Location: Orbiting San Diego
Posted: Mon Apr 15, 2019 3:54 pm Post subject: Re: Oil pressure gauge pegs |
Is it only with the engine running or is just having the key on enough?
Mark |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4789 Location: Bemidji, MN
Posted: Mon Apr 15, 2019 4:01 pm Post subject: Re: Oil pressure gauge pegs |
Glowshift adapters are anodized aluminum. anodize coatings are non-conductive. you must scratch thru the pretty coating at both the nut and the sender threads to make it functional. _________________ -dan
www.thefixitworkshop.com |
Posted: Mon Apr 15, 2019 4:06 pm Post subject: Re: Oil pressure gauge pegs |
crazyvwvanman wrote: |
Mark |
Since im mocking it up im using the the alternator b+ As 12v source. Key on or off no difference |
Posted: Mon Apr 15, 2019 4:08 pm Post subject: Re: Oil pressure gauge pegs |
DanHoug wrote: |
Glowshift adapters are anodized aluminum. anodize coatings are non-conductive. you must scratch thru the pretty coating at both the nut and the sender threads to make it functional. |
Im running a temp ground from one port to the engine. With that connected i got continuity from sender body to ground. Im presuming that means its grounded correctly right? |
Posted: Mon Apr 15, 2019 4:24 pm Post subject: Re: Oil pressure gauge pegs |
Not sure if this is a clue or not, with sender disconnected but gauge still grounded and 12v, it still pegs |
tjet Samba Member
Posted: Mon Apr 15, 2019 4:28 pm Post subject: Re: Oil pressure gauge pegs |
candyman wrote: |
Your problem is at the gauge.
Recheck all your wires
Posted: Mon Apr 15, 2019 4:29 pm Post subject: Re: Oil pressure gauge pegs |
tjet wrote: |
Are you sure it's on the G lug? I think the other one is W. |
It is, i tried to take a vid of my setup, but cant upload it here for whatever reason |
tencentlife Samba Member
Posted: Mon Apr 15, 2019 4:40 pm Post subject: Re: Oil pressure gauge pegs |
candyman wrote: |
Then ground the sender wire to same ground point, if gauge goes to zero, all is well with the gauge.
Then remove sender and test resistance by itself, G-pin to nipple. It's probably a 10-180ohm sender, so going by the way VDO gauges respond (opposite of most built-in gauges) it should be 10 ohm at rest.
If sender has the idiot light function as well the W pin to nipple should be 0 ohm. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Paulbeard Samba Member
Posted: Mon Apr 15, 2019 5:04 pm Post subject: Re: Oil pressure gauge pegs |
I had to send back a gauge (VDO as well) that did the same thing.
Mine grounded to the block (actually, the heat exchanger it screws into) and used the G peg for signal, as yours seems to. It worked fine, the second time. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Posted: Mon Apr 15, 2019 5:08 pm Post subject: Re: Oil pressure gauge pegs |
tencentlife wrote: |
candyman wrote: |
If sender has the idiot light function as well the W pin to nipple should be 0 ohm. |
Bingo! Thanks 10c, no resistance when testing sender by itself. G nor W. Bad sender :/ |
Posted: Mon Apr 15, 2019 5:27 pm Post subject: Re: Oil pressure gauge pegs |
No resistance as in zero ohms? If the sender was bad, as in open circuit, you would see infinite ohms. Is that what you meant? _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Mon Apr 15, 2019 6:09 pm Post subject: Re: Oil pressure gauge pegs |
No resistance as in zero ohms? If the sender was bad, as in open circuit, you would see infinite ohms. Is that what you meant? |
As in no change to resistance whatsoever ever with engine running. No ohms values at all, hot cold, engine on or off. I notice the sender body has some damage to it, like a soup can that get a dent in it, so this may be the cause |
