Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
Posted: Tue Apr 16, 2019 5:17 pm Post subject: Help with 1972 aircleaner vacuum system |
Hi. I picked up a 1972 oil bath air cleaner here on The Samba, and am restoring it.
There is a thermostatic valve in the lid of the air cleaner that is connected to a vacuum servo that operates a flap in the air intake. The vacuum source is off the intake manifold.
I have a Solex 30 PICT-3 carb with the throttle positioner on it that also uses the intake manifold as its vacuum source.
BTW - single port heads and a 205 M distributor in case it's relevant.
I theorize the 72 that the cleaner came off had a 34 on it that had a mechanical advance distributor or an SVDA that got its vacuum from the carb.
I don't have any data on what vacuum is developed at what ports anywhere.
My question is: Do you think I could use the angled vacuum port on the base
of the 30 PICT-3 as a source for the thermostatic valve on the air cleaner?
Thanks,
Jim _________________ Repeat after me "I am smarter than metal!" |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Apr 16, 2019 6:06 pm Post subject: Re: Help with 1972 aircleaner vacuum system |
If the hole in the bore it's attached to is well below the throttle plate then yes, but most of those connected to a nipple on the side of the manifold a few inches below the carb. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
sb001 Samba Member
Posted: Tue Apr 16, 2019 7:40 pm Post subject: Re: Help with 1972 aircleaner vacuum system |
Just use a T connector to split the vacuum signal from the ntake manifold port, one to the air cleaner and one to the throttle positioner. It will be fine. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
