matthewl Samba Member
Posted: Wed Apr 17, 2019 10:48 pm Post subject: Six seater buggy build ( long term project) |
So been going with my friends in there bajas and buggy's, and now it's time to have one again. Only thing is my family has grown quite substantial since my last two seater buggy, even a Baja is not big enough. So I bit the bullet and had a custom chassis made to fit all six of us. It uses two bench seats to keep the cost sum what under control lol.
This is a long term project and will take quite awhile to finish. But I thought I would document it here in case someone else wants some ideas lol.
The chassis is custom made by Fisher Buggies in Tampa FL.
They said it is the largest one they have built to date.
Also I will try to post video ever now and again on my YouTube channel https://www.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
Cody Loren Samba Member
Joined: April 23, 2018 Posts: 118 Location: Cucamonga ca
Posted: Thu Apr 18, 2019 7:50 am Post subject: Re: Six seater buggy build ( long term project) |
That frame sure looks monster big! What are your plans for power? Where are you going to use it? |
PhillipM Samba Member
Posted: Thu Apr 18, 2019 9:17 am Post subject: Re: Six seater buggy build ( long term project) |
Please tell me there's some triangulation left to go in the roof and hoops?
It'll fold like a domino run in an accident atm. |
Posted: Thu Apr 18, 2019 10:05 am Post subject: Re: Six seater buggy build ( long term project) |
Yes it is huge 14' long so far. The plan is to just do some trail riding as that's all we really have in Florida. For now it will be stock suspension ( IRS and link pin) and air-cooled VW power. As for the frame I'm going to add more bracing to the roof and put an x in the top of the cage. Much cheaper for me to do than the shop to do it. _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
Posted: Sat Apr 27, 2019 2:41 pm Post subject: Re: Six seater buggy build ( long term project) |
Well got some time to work on the buggy for a little bit. Was pricing things out and decided to make the floor tabs myself as they are kind of expensive for the amount I will need. Made them out of some flat stock, they did not come out to bad.
Here's a small video of them
https://youtu.be/m0k37W0f8y0
Going to mount the floor and roof first as I have those pieces. Plus with out the torsion housing it is light enough to flip over with two people lol. _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
Posted: Wed May 08, 2019 11:28 am Post subject: Re: Six seater buggy build ( long term project) |
Got the bolt holes drilled in the floor, and once I get the nuts will have the floor bolted in.
So now I'm going to make some side panels out of my leftovers. But I have a question for you guys. I bought a gusset kit that had some body tabs and small gussets with holes in them from speedway motors. I would like to use the gusset in some places to save on using so many body tabs.
So my question is where on the tube should I place the gusset for the most strength? On the center line of the tube or flush with the outer side? Would seem to me the center line would be best but I'm not sure.
center line of tube
Offset to the out side
The kit I bought, yes the gussets are small
Video of progress https://youtu.be/SfN_vVHWDg8 _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
Posted: Fri May 10, 2019 9:15 pm Post subject: Re: Six seater buggy build ( long term project) |
Welded on the tabs for the side panels. Should be enough to hold them on, if not I can always weld on some more. I did not line them up square with each other as the bracing is kinda In the way. But now I wish I did as it would look more pleasing to the eye once the panels or on. O well live and learn and move on.
Video
https://youtu.be/tz76oRlZMks _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
Posted: Sun May 12, 2019 7:50 pm Post subject: Re: Six seater buggy build ( long term project) |
Cut the side panels out today. Used the left overs from the floor/roof material, it's kind of thick for the sides at 1/8" but I already had it so minuses well use it. The panels are 9' x 16" and will need more trimming as the sides go from 12" to 16" in the back. Sorry no photos this time ☹️ forgot to take them. But I did video some of it , if you care to watch.
https://youtu.be/6-24hAgNQjg
Now I got to find a way to bend it so it will follow the chassis in the front. I have an idea or two but will see what works. Really don't want to cut it if I don't have too, I really like the look of a one piece side panel. _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
Posted: Mon May 13, 2019 7:13 pm Post subject: Re: Six seater buggy build ( long term project) |
Well bending the side panels is done. My first thought was to heat the aluminum panel up where it needed to bend, failed lol. The aluminum just dissipated the heat too quickly. So went on to plan B, bent it in my 20ton press. Used an old black iron pipe and used lifter to be the arbor. Came out pretty good and was easier to do than I thought it would be. Now just got to trim the panels down to the correct size, and wait for the boat to get here with the hardwares LOL.
Here is a video of bending it and the tool I use to do it.
https://youtu.be/FDiuecVC5Sk _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
Posted: Thu May 16, 2019 8:53 pm Post subject: Re: Six seater buggy build ( long term project) |
On to cutting the side panels down to follow the top rails. The height of the the side rails taper from 12" to 16" in the rear approximately. So this time instead of using the old jig saw I bought some cut off wheels for my angle grinder. Was hoping to make faster and straighter cuts. Unfortunately that failed on both accounts lol. The most surprising thing was how fast it went through the wheels. Was hoping that one wheel would do both panels, but it took one wheel per panel.( And took longer than the jig saw). O well when we do the roof panels, it back to the jig saw lol.
Video of progress
https://youtu.be/9ePcbRRmfXs _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
Posted: Thu May 16, 2019 8:59 pm Post subject: Re: Six seater buggy build ( long term project) |
Don’t be scared get out the skill saw! Set up a guide and clamp it all to a good set of saw horses it will be fast and super straight. Clean it up with a file and some scotch brute after |
Wulfthang Samba Member
Posted: Thu May 16, 2019 9:30 pm Post subject: Re: Six seater buggy build ( long term project) |
You can get an 8" cut off wheel at most any hardware store to mount on your circular saw. Then just cut it like a piece or plywood! It's a little slower than cutting wood but it works and will give you straight cuts. I cut a heavy steel 2 foot diameter culvert in half and only used one blade. I strongly suggest that you use ear protection though. It's loud!! |
Posted: Thu May 16, 2019 9:34 pm Post subject: Re: Six seater buggy build ( long term project) |
Cody Loren will do that for the roof for sure, it's all straight cuts. Was just blown away how quickly the abrasive cut off wheels wore out. Would have expected that from cheap wheels or on steel but not aluminum. Straight edge next time will be used,thanks for the tip. _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
Posted: Thu May 16, 2019 9:40 pm Post subject: Re: Six seater buggy build ( long term project) |
Wulfthang will do the circular saw next time for sure as I want the roof panels to look good. Been wearing ear protection, got to preserve what I have left lol. _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
Mike E. Samba Member
Joined: April 22, 2019 Posts: 110 Location: Torrance, California
Posted: Thu May 16, 2019 10:05 pm Post subject: Re: Six seater buggy build ( long term project) |
Wulfthang wrote: |
If you're cutting aluminum sheet with your Skill saw just put on a new carbide tooth blade and go to town using a straight edge as a guide. I would not recommend a cut-off wheel for any aluminum as I have never had good luck with that program. I use my wood 10" miter saw with a carbide blade for cutting aluminum stock quite often.
Good work and it looks nice. Should be able to make lots and lots of memories along the way, both in the building and the enjoying after its done. |
Posted: Fri May 17, 2019 1:34 am Post subject: Re: Six seater buggy build ( long term project) |
Mike E. wrote: |
Wulfthang wrote: |
Yeah, I've heard that and heard that it works very well but I've never tried it. I saw a guy (on tv) cut a 2 inch thick block of Aluminum with a carbide blade. He said it "gummed up" the blade and he had to chip it off but otherwise, it worked fine. |
