MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Fri Apr 19, 2019 5:17 pm Post subject: Re: Bad Clutch? |
Wow, you don’t screw around. _________________ ☮️ |
Igeo Samba Member
Joined: September 25, 2018 Posts: 888 Location: Oakland, CA
Your images don't work. Try uploading them to the gallery, then insert them.
Was the disk stuck? Hope you didn't go through all that for nuthin...... _________________ 1987 Westfalia 2.1 WBX Manual |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Fri Apr 19, 2019 5:24 pm Post subject: Re: Bad Clutch? |
Am I imagining something?
It seems like only yesterday they wouldn't even change gear oil.
Now they're dropping the whole dang transmission.
Between posts.
A good skill to have,,,, especially those who don't pay attn to gear oil condition. Or choose the wrong rebuilder cuz it's hard to "know".
Hey it's almost like the old days ! !
ACTION on theSAMBA
This is a great place for the Vanagon nut. _________________
....KTMs, GasGas, SPOT mtb |
?Waldo? Samba Member
Posted: Fri Apr 19, 2019 5:43 pm Post subject: Re: Bad Clutch? |
Igeo wrote: |
Was the disk stuck? Hope you didn't go through all that for nuthin...... |
The issue isn't with the hosting site, it is the fact that they posted the hosting page address rather than the image address. IMO, the Samba gallery is worse than Imgur. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Fri Apr 19, 2019 6:17 pm Post subject: Re: Bad Clutch? |
hogan029 wrote: |
Thanks everyone for their response. I had some time today to pull the transmission out and check the clutch, god bless spare time.
Looks like some slippage on the KEP flywheel
Some wearing on the flex Plate
Clutch looks good, a ton of material on it and it doesn't look contaminated from a glance.
The throw out bearing appears to have some grease on it, I will take a photo when I have some light. |
The missing 18½ minutes:
hogan029 Samba Member
Posted: Fri Apr 19, 2019 8:56 pm Post subject: Re: Bad Clutch? |
Sorry about that all, was trying to post from the airport. Everything looks pretty good.. I am thinking the throwout bearing may be the culprit. Any thoughts? |
Sodo Samba Member
Posted: Fri Apr 19, 2019 9:14 pm Post subject: Re: Bad Clutch? |
Maybe a broken clutch fork? You should be able to feel that with your foot on the clutch pedal. _________________
Posted: Sat Apr 20, 2019 6:32 pm Post subject: Re: Bad Clutch? |
Got the throwout bearing out and it looks just fine. Going to replace the rear main and seal the other openings while I'm in there.
I cycled through the gears with the trans removed and it seems to be just fine. Also checked fluid level and changed it while it's out.
I am beginning to think it may just be a rod adjustment or something simple. Any thoughts? |
Posted: Sat Apr 20, 2019 6:52 pm Post subject: Re: Bad Clutch? |
My main thought is that your detailed description/answer for each of the questions that different folks have asked in this thread would have had the diagnosis nailed down a couple days ago and possibly without pulling the transmission/clutch. Going back through the thread and reading the responses people have already posted and addressing each question that you can answer would be step one. |
Posted: Sun Apr 21, 2019 10:34 am Post subject: Re: Bad Clutch? |
Agreed. Through the process I noticed my rear main leaking so I needed to address the possible contamination. |
Posted: Sun Apr 21, 2019 11:15 am Post subject: Re: Bad Clutch? |
Ok, now at this point, if you had taken the time to answer the questions asked of you, the knowledgeable folks on this board who have been trying to help you would be able to definitively inform you whether you could confidently reinstall the current trans (after the seal replacement) or they would be able to tell you that the trans needs to be addressed internally first. Now you will need to reinstall the trans just to find out. Hopefully it works out for you that it doesn't need to come right back out for trans work. |
Posted: Sun Apr 21, 2019 11:44 am Post subject: Re: Bad Clutch? |
Thanks.
So I popped the trans open today while it was out . No signs of contamination, wear or otherwise. Did a complete reseal on the trans while it was out to make sure. Even that 3-4 slider was looking good!
Back together we go! |
Posted: Tue Apr 23, 2019 11:35 am Post subject: Re: Bad Clutch? |
Quote: |
So I popped the trans open today while it was out |
Interesting choice of words. _________________ ☮️ |
Sodo Samba Member
Posted: Tue Apr 23, 2019 11:51 am Post subject: Re: Bad Clutch? |
MarkWard wrote: |
Interesting choice of words. |
I guess its time to pop it back together then!
This whole Samba query has been odd.
Like the doctor asking the patient for help. _________________
Posted: Tue Apr 23, 2019 7:11 pm Post subject: Re: Bad Clutch? |
Bad baked beans? ... Well I got it back mated and will have to wait awhile to do the rest.. have to go for man surgery tomorrow lol better take it easy! |
E1 Samba Member
Joined: January 21, 2013 Posts: 6569 Location: Westfalia, Earth
Posted: Tue Apr 23, 2019 9:53 pm Post subject: Re: Bad Clutch? |
I haven't read all the posts but had a very similar sound last fall. It was accompanied by a vibration in the pedal, I'd best describe the sound as "whirring."
We'd had a clutch replaced with a main seal leak repair, but the slave was never bled, the fluid was filthy and had new air in it, and it warped the clutch and/or plate quickly (like before I even test drove it).
In our case, the depressed pedal was not fully disengaging the clutch. If I pumped the pedal several times, it would work nearly like normal. The whirring sound came and went, though, likely dependent on fluid pressure. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
