jlrftype7 Samba Member
Posted: Tue Apr 23, 2019 7:22 am Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
THIS...^^^^^^ Made me laugh... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Tue Apr 23, 2019 10:52 am Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
My rig started life as a tin-top Syncro with factory rear locker only. When having the transaxle rebuilt, I decided to have the front diff machined to accept a front locker and added a decoupler. I did the front locker install because of memories of several times climbing very steep muddy grades with a Toyota 4-runner with a rear locker, but no front locker. The one guy in that group with a front locker got up the hill. Some "redneck" front lockers were installed on Chebby/Ford 4x4's with a stick-welded diff, (using hub locks unlocked on the highway) and those rigs also got up the hills.
Knowing what I now know, if I had to do this all over again, I would probably not install the front locker. There are no real negatives except cost as it is totally "plug and play", but I have very rarely had to use the front locker.
On the occasions that I have used the front locker, it was, realistically, in places I had no business going in an antique with no winches and no friends along to assist. The impact on steering, even in the slipperiest mud, is dramatic. You really need to hold the steering wheel tight when engaging the front diff lock. For those occasions when one front wheel is off the ground or otherwise slipping, the front diff lock is excellent.
For this same reason, I cannot see any good coming from a Peloquin or similar Torque biasing front diff because once one wheel is off the ground altogether, the TBD cannot bias the torque. With careful application of brakes, sure, the TBD starts to provide torque to the slipping wheel, but I hasten to add that the hairy conditions that require a front diff lock are usually so hairy that you will not have the ability to apply brakes "just right" to force the TBD to work.
So . . . that is my data point and I hope it is of assistance to the OP. _________________ '86 Syncro Westy SVX |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9606 Location: Western WA
Posted: Tue Apr 23, 2019 11:35 am Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
Excellent real life feedack.
Howesight wrote: |
On the occasions that I have used the front locker, it was, realistically, in places I had no business going in an antique with no winches and no friends along to assist. |
I think this would be the case for me. Realistically I should decline to go 4-wheeling with folks
who HAD "winches and friends and knobs", for the very simple reasons that those are red flags signaling
invevitable "antique RV damage".
Howesight wrote: |
What if the locker then automatically unlocked, (instantly !) each time ~equal~ traction was achieved?
Where steering was "normal" during this time (which is probably "most of the time")?
So, "most of the time" you are getting little "front locker assists" without even knowing it's locking.
Consequently; you wouldn't even know that knob#3 was necessary (to pull).
I'm pretty sure knob #3 CAN be setup to fully lock a Peloquin if somebody wanted to go whole-hawg.
Howesight wrote: |
For this same reason, I cannot see any good coming from a Peloquin or similar Torque biasing front diff because once one wheel is off the ground altogether, the TBD cannot bias the torque. With careful application of brakes, sure, the TBD starts to provide torque to the slipping wheel, but I hasten to add that the hairy conditions that require a front diff lock are usually so hairy that you will not have the ability to apply brakes "just right" to force the TBD to work. |
For how long would this "tire above-ground" event exist ----->that required adding a little braking?
Could it be a duration of 1 second, or maybe 2 feet ground distance until the raised wheel regained contact to the ground?
----->and the Peloquin resumes it's normal 'locking'.
That seems reasonable..... but I'd like to experience it somehow.
In someone else's van who has the eqpt and the desire to prove it.
So with the Peloquin, the van stops, and then you drag the brake to get it moving again.
If you can get moving again - cuz note you are "stopped" now, zero momentum.
Whereas with a locked diff, you don't stop, you don't ever lose the forward momentum.
The difference is not lost on me.
But I'd like to experience it.
Note that during this event that tasked you with stopping the spinning wheel with the footbrake.....
.....the REST of the time in this dicey terrain, you arenot tasked with strenuous locked-diff steering.
These are my curiosities WRT the PELOQUIN as a front locker. _________________
....KTMs, GasGas, SPOT mtb |
tjet Samba Member
Posted: Tue Apr 23, 2019 1:43 pm Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
Here's a good video on the benefit of air lockers. I'm curious to see how a torque biasing diff would behave in a similar situation. If you google "Detroit Locker in front", you will see some people with Jeeps that put them in the front.
elizer Samba Member
Joined: May 02, 2016 Posts: 1462 Location: Northern Virginia
Posted: Tue Apr 23, 2019 4:12 pm Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
I used to have a 2016 jku Rubicon hard rock. It comes standard with front and rear diff locks. They really really help in many different situations. But I would never be in any of those places with the westy. Well I wont say never. My westy is at Fas it is getting the 2nd and 3rd knob. I only did it because I had the front diff rebuilt and just said the hell with it. |
BavarianWrench Samba Member
Joined: January 18, 2004 Posts: 1045 Location: Oceans Edge
Posted: Tue Apr 23, 2019 9:01 pm Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
I have a triple knob story. I was so excited to finally have the holy grail, Three Knobs.
I start up a fairly steep snow covered hill. Open diff, rear wheel drive. I notice it just starting to slip and engage the driveshaft quieting the pans that had started to rattle. Onward and upward. The grade increases and the pots and pans rattle a bit as the tire loosing traction hops. I lock in the rear diff and continue to climb. I can not believe how well the rig is pulling. Slight turn, and another increase in the grade. The pots rattle, and I engage the front diff quieting them. Once again the tires are pulling me up with no lost energy bouncing a traction-less tire. I'm in awe as the pitch increases and I remain climbing.
Then it happens. I find the limit, and the van starts to rattle the pans again. As the tires slip I realize my fun is over. I have reached as far as I am going to climb. The pitch had once again increased.
I cover the brake. Then gently apply it as I depress the clutch. At that moment I realize, I'm in a must make it to the top situation. I didn't catch that in time. There was no traction to hold the wheels locked by the brakes. I almost totaled my van as it accelerated down the face of the mountain side searching for level. I did some pumping of the brake and some crazy attempts at steering. I was really just lucky. the Van slid down the mountainside. Part of the slide was off the trail. I missed trees, some by steering, others by luck. A triple locker can get you out of a mess. It can also get you into some very dangerous territory. I want another one.
Last edited by BavarianWrench on Tue Apr 23, 2019 9:48 pm; edited 1 time in total |
tjet Samba Member
Posted: Tue Apr 23, 2019 9:30 pm Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
Good story. What's your ring & pinion gearing and tire size? |
Posted: Tue Apr 23, 2019 9:39 pm Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
tjet wrote: |
Sold the van a few years back. It was an Imported Diesel 1987 Syncro. I forget but I'm thinking 5.43s? with 14" steel rims and 27" tires |
tjet Samba Member
Posted: Tue Apr 23, 2019 9:54 pm Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
Was that the one you drove up Manhattan Beach Blvd on that clutch-smoking grade from the pier?
Posted: Tue Apr 23, 2019 10:54 pm Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
For the OP and keeping on topic. The more knobs the better and while we are on a little side note. Apologies to the OP. Purchasing a Syncro from Europe is a good way to get into a triple knob for less money. The front diff option was not available in the US market. Yet it was somewhat common in Europe. Yes that Reimo is the one I brought over. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Wed Apr 24, 2019 4:16 am Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
Less we forget.
kguarnotta wrote: |
I don't anticipate doing any hardcore off-road adventures (but that could be fun!). |
Knowing people in the hardcore Jeep world in Mass., their hard core off-roading is on private land, so playing, (four wheeling for the sake of 4 wheeling fun), vs. the west and using 4WD to get somewhere.
So for snow on paved roads, a locking diff for is not necessary, or even desired for that matter - least I've never longed for one in my 4WD.
In fact, I've never taken my 4WD off-road in New England. I fly to Wyoming, where a friend sets me up for off-road in WY, MT to Utah. Maybe because of those experiences out there, I have no desire to "off road" here? Don't know.
There may be some viable places in Quebec - but then I need at least a week's vacation to pursue.
I know there is the "green lane" stuff going on Vermont, but all those places are easily hiked or biked to. But if you aspire to do that, then a rear locker might be handy.
Of course, if you can't get enough salt on the van in the winter, you could get a beach permit and hit the beaches.... _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
danfromsyr Samba Member
Posted: Wed Apr 24, 2019 8:28 am Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
in the north east everywhere I've driven off road
i've encountered a corolla or a camry
in a Syncro
the 1st knob is the rear differential and can be handy from time to time, but not as often as you'd think. you'll use it more to keep it 'exercised' and ready than in actual operation/use. yet 85%+ of north american market syncro come with a rear diff lock.
the middle knob is to enter 2wd mode and only useful for when you have mis matched spare tire.
the 3rd knob is for the front diff, and well it's nearly never used, thought of or practical.
all AWD/4WD are capable of getting stuck far enough from a main road to cost much more when you have to call in a 4wd tow/recovery.
I don't subscribe to the take it out and bash it like it's a jeep mentality. that's what jeeps are made for, rugged disposable fun. _________________
Abscate wrote: |
Syncro Jael Samba Member
Posted: Wed Apr 24, 2019 9:40 am Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
vanagonjr wrote: |
Of course, if you can't get enough salt on the van in the winter, you could get a beach permit and hit the beaches.... |
Or come out to Utah, salt is free!
_________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
flomulgator Samba Member
Joined: March 07, 2013 Posts: 950 Location: Leavenworth, WA
Posted: Wed Apr 24, 2019 10:54 am Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
Everyone salts now. Washington State, formerly a salt-free paradise, salts the passes all winter long and the city of the Seattle looks like the Utah salt flats half the winter. Most of the west already followed suit, I think OR is the only holdout. Midwest/NE is more continuous salt coverage than the West, but salt everywhere is the new reality; I say its better to adjust than avoid. Wash the underside of your syncro at least monthly during the winter (which is easy with a wand due to the ride height) and do one of those treatments in the summer. I had your exact car (a 2008 328xi wagon, 6MT) that lived in the midwest before I owned it and it had fist-sized clumps of re-precipitated salt behind the plastic underbody panels because it was never cared for. It's all in the maintenance!
For snow you don't need knobs, they only help if you're not moving. Above about 20 mph a locked rear in the snow becomes a liability. You can fake a rear locker if you are truly stuck by just pulling on the e-brake handle. I have done this on my syncro stuck in the snow with a frozen rear locker and it worked about as good as if the locker had worked.
As others have said, the ultimate setup for snow is either LSDs or peloquins front and rear. That would be the traction equivalent of a Subaru STI.
As an aside: I hear you on the BMW wagon. Even doing my own maintenance with non-OEM parts from Pelican Parts, etc..., it was still pricey and not a very reliable vehicle. Kinda like a Syncro! It was a beast in the snow though, better than a Subie Outback.....Kinda like a Syncro! _________________ She's built like a steakhouse, but she handles like a bistro! |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Wed Apr 24, 2019 11:22 am Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
Oregon has a long history of follow the leader rather than thinking for itself so to that extent it pretty much salts certain mtn. passes now, uses lots of chemicals elsewhere, and we are gravitating toward a total salt environment in parallel to Cali and Wash.
Portland in particular 'sneaks' in their salt and metal feasting chemicals all winter to handle those two or three days of one inch snowfalls that paralyze the city. Over time this has largely been due to huge migrations of people from elsewhere where salting was the norm hence their perpetual complaining about the absence thereof until more recently. Truckers in particular complained about coming down through the Columbia Gorge without salt which is now 'kinda' in use.
I crossed the pass between Cali & Ore on I-5 many years ago where we were plowing through some slush with lots of brown stuff in it. Later I noticed my westy undercarriage was beginning to look a little rough (rusty). |
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Fri Apr 26, 2019 3:40 pm Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
Beautiful pictures Syncro Jael.
Am I correct in the idea that the knobs actuate the locking mechanisms through pneumatics?
A few responses here make me think the peloquin differential is installed in the front, but when I was first reading about them- I assumed all the references were for installing them in the rear. Did I misunderstand something? _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Sodo Samba Member
Posted: Fri Apr 26, 2019 4:52 pm Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
kguarnotta wrote: |
A few responses here make me think the peloquin differential is installed in the front, but when I was first reading about them- I assumed all the references were for installing them in the rear. Did I misunderstand something? |
Im sure most Peloquins are installed in the rear. “Peloquin in the front” is an anomaly being discussed. People have them in the front but them fellers ain’t posting.
The VW system uses engine vacuum to actuate the lockers. The knobs are actually vacuum valves. The lights are lit by sensors on the trans that confirm that actuation has occurred. Syncros have all the wiring & connectors in place waiting for “3 knob”. That’s another reason Syncro owners are compelled to go 3knob. You “might as well” spend $4,000 bucks if the wiring for the indicator lights is already there. I don’t know if non-locker Syncros have the locker indicator wiring.
Most other lockers use positive air pressure from an on-board compressor (ARB for example), and modern trucks (Ford) use electric actuators. _________________
Posted: Sat Apr 27, 2019 5:13 am Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
Thanks Sodo.
Is this correct - all syncros from the factory have the set up prepped for a 3-knobs (ie wiring and sensors) to add a knob(ie locker, decoupler etc) you need to then add a physical component or change the transaxle, right? Is that what you mean by spend the $4,000 to add the capabilities of the multiple knobs. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Sat Apr 27, 2019 9:06 am Post subject: Re: Syncro - 1 knob, 2 knobs or 3? |
Incorrect.
Some syncros were sold without any lockers, these lack the wiring, vacuum plumbing, and dash panel altogether. These syncros, just like the “knobbed” locker syncros, would benefit from the installation of mechanical LSDs/TBDs in the front and rear, but if you want to “add a locker” you would have to add-in all of the stuff mentioned above. For this reason, lockerless syncros are often cheaper as they are not as popular with the crowd that buys syncros for off-rod purposes. Which you may benefit from if you don’t need lockers. _________________ She's built like a steakhouse, but she handles like a bistro! |
