Troytempest69 Samba Member
Posted: Sun Apr 21, 2019 1:34 am Post subject: Torsion arm to link pin bolt. Why is one shorter? |
Just about to rebuild my front beam and noticed one of my 4 bolts is shorter, but no idea on which torsion arm it should go, or if it even matters. The parts manual lists 3 x n104511 and 1 x n104451 - the difference being 50mm bolt v 45mm bolt. The shorter bolt I have has no cotter pin, so guessing it’s been replaced at some point, so unsure whether to just buy a 50mm bolt or look for a shorter 45mm bolt. Thanks. Pete |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sun Apr 21, 2019 8:57 am Post subject: Re: Torsion arm to link pin bolt. Why is one shorter? |
The short one goes on the top on the right side with the nut side facing down. The other three the nuts are facing up....... I think. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sun Apr 21, 2019 11:34 am Post subject: Re: Torsion arm to link pin bolt. Why is one shorter? |
^^^ that's why.
right side:
left side:
_________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Sun Apr 21, 2019 2:30 pm Post subject: Re: Torsion arm to link pin bolt. Why is one shorter? |
Brilliant, thank you. Interestingly the parts manual calls for 4 cotter pins, but doesn’t look like the shorter pin should have one fitted...which makes me think the bolt I have is the original. |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Sun Apr 21, 2019 2:59 pm Post subject: Re: Torsion arm to link pin bolt. Why is one shorter? |
For the record, the earlier April ‘58 manual calls for (4) at 50mm and (4) pins, nothing about one being 45mm. Anyone have any input as to why and when that one was reduced to 45mm? And did the spindles change at the same time?
I haven’t pulled my Progressive Refinements from the shelf yet, but I figured I’d try and build upon an existing thread to address the topic. Here is the link to the earlier manual: https://www.thesamba.com/vw/archives/manuals/April...s_List.pdf _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Posted: Mon Apr 22, 2019 6:21 am Post subject: Re: Torsion arm to link pin bolt. Why is one shorter? |
Interestingly, just been reading my Bentley manual and it references cotter pins in the bottom bolts only. How strange. |
don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2830 Location: West Palm Beach, FL
Posted: Sat Jan 09, 2021 1:56 pm Post subject: Re: Torsion arm to link pin bolt. Why is one shorter? |
Maybe cotter pins are for where bolts are upside down.
If nut falls off on the top down bolts, they are less likely to fall out.
My thoughts... _________________
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
