Meiang Samba Member
Joined: September 27, 2016 Posts: 656 Location: Perth, Western Australia
Posted: Sun Apr 21, 2019 10:17 pm Post subject: Original Engine |
I wonder what % of cars are running with the original case, ie engine number.
My 1968 1500 is running with the original case (H0916032) after 500K+ miles. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Sun Apr 21, 2019 10:38 pm Post subject: Re: Original Engine |
Meiang wrote: |
I have the original 1600cc DP engine from my 1971 VW Convertible; however that engine powers my 1970 sedan right now, and the 1971 Convertible runs 1835cc DP. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Danwvw Samba Member
Posted: Sun Apr 21, 2019 10:45 pm Post subject: Re: Original Engine |
You will see quite a few single port's! I think I may have found the original 36 horse which is still running with 92K on it in a 1960 bug I just bought. But if your rebuilding a 1300 or 1500 as a single port It would be a better engine in the long run if you used a dual port case and just make it a 1679cc. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Meiang Samba Member
Posted: Sun Apr 21, 2019 11:17 pm Post subject: Re: Original Engine |
I keep on hereing that the H series case is a weak point of the vehicle. Why would you change (apart from adding case savers) to another. The H series case has served me well. |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1216 Location: IRELAND
Posted: Sun Apr 21, 2019 11:32 pm Post subject: Re: Original Engine |
Og B code 1600 sp in my 70 running like a champ, 86k miles |
Maddel Samba Member
Posted: Mon Apr 22, 2019 1:08 am Post subject: Re: Original Engine |
1302 S Super Beetle.
Built on: 17 AUG 1970
Left factory on: 21 AUG 1970
Destination: Berlin
Engine-ID: AD 012 613
It's the original engine verified by AutoMuseum Volkswagen "birth certificate". |
markj60616 Samba Member
Posted: Mon Apr 22, 2019 4:34 am Post subject: Re: Original Engine |
My 1970 still has its original B code single port 1600 engine...just turned 116,000 miles yesterday. _________________ 1970 Type 1
original paint
original interior
original engine
1978 Type 2 Panel Bus
original engine 2.0L FI
2014 Beetle 2.5L |
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1606 Location: Central Pennsylvania
Posted: Mon Apr 22, 2019 6:54 am Post subject: Re: Original Engine |
Meiang wrote: |
I wonder what % of cars are running with the original case, ie engine number. |
Although everyone likes to show off the fact that their car has the original case, my *guess* is that 10% or less of the VW's from the late 60's still run with their original case. Replacement cases were cheap throughout the 80's, 90's, and 00's. They are expensive now.
My '70 came with a later dual port 1600 case (AK). I was hung up on this issue for a while, then I got over it. The doghouse shroud is the preferred tech, and I'm happy to have it. _________________ '91 Vanagon Westfalia
'70 Beetle Convertible
'71 Super Beetle Semi-Automatic: https://www.thesamba.com/vw/forum/viewtopic.php?t=714131&highlight=
'65 Ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=762478&highlight= |
gt1953 Samba Member
Posted: Mon Apr 22, 2019 7:01 am Post subject: Re: Original Engine |
Currently the 68 does have the original numbers matching H case single port engine in it. Yes it was rebuilt, no line bore either, case savers yes and it is now a 1600cc up fro 1500. Here it is on a dyno. 48 HP to the wheels.
_________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
sb001 Samba Member
Posted: Mon Apr 22, 2019 7:14 am Post subject: Re: Original Engine |
Soemtimes I wish my 69 autostick still had the original 1500cc case.
At least when it went, it went in a blaze of glory. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Cusser Samba Member
Posted: Mon Apr 22, 2019 7:27 am Post subject: Re: Original Engine |
Tom K. wrote: |
my *guess* is that 10% or less of the VW's from the late 60's still run with their original case. |
I would "guess" less than 10%. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Ricksurfin Samba Member
Joined: September 02, 2017 Posts: 295 Location: Huntington Beach, CA
Posted: Mon Apr 22, 2019 7:44 am Post subject: Re: Original Engine |
A little newer, but my 1974 standard has the original motor and transmission. Never been rebuilt, and runs like a champ. Daily driver. |
wayne1230cars Samba Member
Posted: Mon Apr 22, 2019 9:22 am Post subject: Re: Original Engine |
A small minority for sure. My ‘70 is on it’s third engine. My ‘60 has its original factory installed 36hp coming up on 80,000 miles (rebuild @ 70,000). _________________ 1960 beetle
1970 beetle convertible |
Zundfolge1432 Samba Member
Posted: Mon Apr 22, 2019 10:40 am Post subject: Re: Original Engine |
Contrary to what the experts here say numbers matching all original cars with known history and documentation/ provenance will always be worth more to serious buyers. |
Danwvw Samba Member
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Mon Apr 22, 2019 11:20 am Post subject: Re: Original Engine |
Original AF00025x engine in my 71 1302LS. Still has original barrels and dished pistons . 110K kms.
_________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Mon Apr 22, 2019 2:54 pm Post subject: Re: Original Engine |
Cusser wrote: |
Tom K. wrote: |
I would "guess" less than 10%. |
10%... maybe if you reverse those digits it might be closer. _________________ Andy T.
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Mon Apr 22, 2019 3:37 pm Post subject: Re: Original Engine |
Meiang wrote: |
My 1968 1500 is running with the original case (H0928xxx) after 83K = miles. But the body is off it getting rid of the rust. In the family since new and close engine number to yours. VIN 118570xxx. German made I believe, Oz delivery. |
73SlowBug Samba Member
Joined: November 28, 2017 Posts: 439 Location: PENNSYLVANIA
Posted: Fri Apr 26, 2019 7:48 pm Post subject: Re: Original Engine |
My 73 has the original engine and original transmission. But the engine's been rebuilt at least once. And the transmission will need to be rebuilt soon. Also have some original rusted out to go with it. When i hit the lottery... _________________ Daily driven....Slowly. |
wcfvw69 Samba Purist
Posted: Fri Apr 26, 2019 8:26 pm Post subject: Re: Original Engine |
Original, matching number engine case. It's been rebuilt at least twice. Best guess at original mileage is 200k on the case. _________________ Contact me at [email protected]
The Samba member since 2004.
