PSquare Samba Member
Posted: Tue Jan 22, 2008 9:54 am Post subject: Driver's side Grab handle |
Hi,
We just got a grab handle to install in the driver's side pillar.
But we are missing the "wedges" to be able to install it properly.
Go Westy mentions that we need both the upper and lower wedge.
http://www.gowesty.com/ec_view_details.php?id=2284...amp;start=
However the lower wedge is out of stock!
Can't find it anywhere online
Do any of you know where can I get one? or do you have an idea how to install the handle without this part? |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Tue Jan 22, 2008 9:58 am Post subject: |
These "wedges" are plastic pieces that snap into the door, that the phillips screws thread into, holding the handle on.
Someone should have an "extra" lying around. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Tue Jan 22, 2008 10:23 am Post subject: |
Did you try your local VW dealer? They can be pretty reasonable on parts like that, sometimes even cheaper. |
90Doka_Guy Samba Member
Joined: April 08, 2007 Posts: 548 Location: South Jersey
Posted: Tue Jan 22, 2008 10:47 am Post subject: |
check in the classifieds for someone parting out a van _________________ -'87 Westy
-'90 Tintop
-'90 DOKA |
Posted: Tue Jan 22, 2008 11:15 am Post subject: |
I looked in the classifieds for "wedges" and "grab handle"
Could not find anything.
I will be looking for someone parting out a Van ... That is a good idea.
I also got a list of VW Used part dealer ship from Go Westy. I am posting it here in case it helps others:
USED PARTS SUPPLIERS
AFFORDABLE GERMAN - 602.253.8889 (Arizona - All VW Models)
BW AUTO DISMANTLERS 1.800.327.0888 (California - All VW Models)
RUSS' RECYCLING - 626.303.4366 (California - All VW Models)
FAST INC. - 626-357-3361(California - All Watercooled VW Models)
DICKS AUTO HAUS - 410.827.6501 (Maryland - All VW Models)
CAMPBELL NELSON - 888.337.7757 (Washington - All VW Models)
GERMAN PARTS WAREHAUS - 916.635.6469 (California - All VW Models)
INTERSTATE USED PARTS 760.736.8515 (California - 1968-79 Type II, NO Vanagon)
DISCOUNT AUTO PARTS 800.748.1537 (New Mexico - All VW Models)
SMALL CAR CONNECTION 760.244.3446 (California - Aircooled, some Watercooled) |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Tue Jan 22, 2008 11:35 am Post subject: |
Please don't post parts requests in the Forums.
It's the first rule in posting on the forums.
http://www.thesamba.com/vw/forum/viewtopic.php?t=4
Post a free wanted ad in the classifieds if you can't locate something.
Everyone complains about how many useless returns you get when you do a search, parts requests are one of the reasons for this. |
Posted: Tue Jan 22, 2008 7:16 pm Post subject: |
sorry about that.
I though it was really hard to find that part and was looking for a way to install the handle without it. |
greebly Samba Member
Joined: August 27, 2009 Posts: 966 Location: Here and now
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Sat Jun 09, 2018 10:10 am Post subject: Re: Driver's side Grab handle |
Edit: Just realized I quoted a long dead post! Oops.
PSquare wrote: |
Hi,
I got a set through BusDepot. http://www.busdepot.com/25586719501c
I haven’t installed them yet, and the pillar on my Doka seems to be contoured slightly different then the mount pads but I think easily fitted.
Mark _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
Posted: Sat Jun 09, 2018 10:54 am Post subject: Re: Driver's side Grab handle |
The reason they do not fit your A pillar post is because the mounts being sold by the Bus Depot are for the pillar next to the sliding door the A post mounts are not identical, they are mirror images. The OEM part numbers are
Passenger side top, driver side bottom, marked #1: VW # 251 857 615
Passenger side bottom, driver side top, marked #2: VW # 251 857 616
the curvature is different from the D pillar mounts which Bus Depot is selling part number 25586719501C
Refer to MSINABOTTLE's post in this thread. https://www.thesamba.com/vw/forum/posting.php?mode=quote&p=4591661 |
ALstew Samba Member
Posted: Sun Jan 06, 2019 2:02 am Post subject: Re: Driver's side Grab handle |
I just wanted to bump this thread because I purchase the template and spacers from shapeways. After you drill the holes you don't need rivnuts? You just drill the holes and install the spacers and bolt the handle in? |
Posted: Sun Jan 06, 2019 4:03 am Post subject: Re: Driver's side Grab handle |
No rivnuts needed, follow the instructions here, use a 7/16" drill bit to make the final holes and do not wallow the hole out. Start with smaller bits and work up to the 7/16. Put some electrical tape on your bit
as a guide to not drill too deep.
https://imgur.com/a/kHp3TL4 |
Timwhy Samba Member
Posted: Sun Jan 06, 2019 5:01 am Post subject: Re: Driver's side Grab handle |
greebly wrote: |
The reason they do not fit your A pillar post is because the mounts being sold by the Bus Depot are for the pillar next to the sliding door er side bottom, driver side top, marked #2: VW # 251 857 616
You mean B?
Actually you can mount this B column grab handle directly too the Sliding door.
_________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1038 Location: san diego
Posted: Sun Jan 06, 2019 9:16 am Post subject: Re: Driver's side Grab handle |
i have added additional handles to the sliding doors, it makes them much easier to close when sitting in the back.
Timwhy wrote: |
You mean B?
_________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Jan 06, 2019 11:58 am Post subject: Re: Driver's side Grab handle |
I've enjoyed the added handles to both the DS front & slider door as pictured...both in my top 10 favorite mods...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Zeitgeist 13 Samba Member
Posted: Sun Jan 06, 2019 12:42 pm Post subject: Re: Driver's side Grab handle |
I have a Passat handle up in the ceiling near the dome light, and a handle on the slider. Both are great additions. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9936 Location: Orbiting San Diego
Posted: Sun Jan 06, 2019 1:25 pm Post subject: Re: Driver's side Grab handle |
I mounted the handle on the slider but much farther back and turned horizontal just below the window.
This lets the slider be pulled shut while you are on the bed/bench and doesn't rely as much on the velocity of the door to completely close it. So it is easier and quieter, important at night or in close quarters. The handle needs to be mounted angled up so it doesn't rub when the door is opened. Once she tried it on one van my wife wants it on all of them.
Mark |
4mymalamute Samba Member
Posted: Sun Jan 06, 2019 4:17 pm Post subject: Re: Driver's side Grab handle |
crazyvwvanman wrote: |
Mark |
Hi Mark, do you have any pics you could post of this? Sounds like a great idea. |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Mon Jan 07, 2019 8:55 am Post subject: Re: Driver's side Grab handle |
Mark |
Interesting for I've been thinking of doing this. Last year installed one on the driver pillar and has been one of the best mods I've done so far. So much easier to pull myself up onto the seat. Here's a pic:
_________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
Posted: Mon Jan 07, 2019 9:15 am Post subject: Re: Driver's side Grab handle |
I'll take a photo of my sliding door mounted handle today.
Mark |
