Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Thu Apr 25, 2019 2:38 pm Post subject: Raising a 2000 lb trailer axle |
I have a little utility trail ... 1-ton. It's a 4'x4'x8' box with a single leaf-spring axle under it. The axle is too short and the wheels are under the box ... making the whole thing kind of high and tippy.
So I got a longer axle that will place the wheels outboard of the box and some fenders. The axle is already situated on top of the leaf spring and I want to lower the box by raising the axle. I'll make some blocks and I'll need longer u-bolts.
The biggest u-bolts I can find for a 1-3/4" axle are 4-1/4" long. Looks like I might only be able to do a one inch drop with those bolts.
If I wanted longer bolts where would I find them? No luck with my searches so far.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Apr 25, 2019 3:07 pm Post subject: Re: Raising a 2000 lb trailer axle |
A local trailer supply store? Boise area has at least 12- but we're in far country.
Start with rod-stock and bend/thread your own?
See if (gulp) all-thread rod could do the trick? I have no idea what happens when it's bent.. _________________
EverettB wrote: |
FU#5 |
minger Samba Member
Joined: November 03, 2003 Posts: 238 Location: Cleveland Ohio
Posted: Thu Apr 25, 2019 3:10 pm Post subject: Re: Raising a 2000 lb trailer axle |
I went to a semi repair place here in Cleveland and they bent shackles to whatever size needed. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51118 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Apr 25, 2019 4:30 pm Post subject: Re: Raising a 2000 lb trailer axle |
Nearly every town has a spring shop where semi trucks go for suspension work, they can manufacture new U bolts in any size you want while you wait. My son had some made for his Toyota for ~ $10 per U last year. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20264 Location: Sandpoint, ID
Posted: Fri Apr 26, 2019 7:58 pm Post subject: Re: Raising a 2000 lb trailer axle |
busdaddy wrote: |
Nearly every town has a spring shop where semi trucks go for suspension work, they can manufacture new U bolts in any size you want while you wait. My son had some made for his Toyota for ~ $10 per U last year. |
Yep. I live in a small town and the local truck maintenance place has made me custom u-bolts more than once. Cheap, and they did while I waited. _________________ nothing |
Onceler Samba Member
Posted: Sat Apr 27, 2019 11:11 am Post subject: Re: Raising a 2000 lb trailer axle |
I’ve bought u bolts at autozone and the farm store before (around here it’s TSC oor Rural King) _________________ 1972 Karmann Ghia |
Posted: Sat Apr 27, 2019 7:05 pm Post subject: Re: Raising a 2000 lb trailer axle |
The autozone (no pep boys in my town) carried that lowering block kit you linked to with the long u bolts at least 10 years ago since i checked. The aluminum blocks usually cracked but the bolts seemed fine. _________________ 1972 Karmann Ghia |
Posted: Sat Apr 27, 2019 7:19 pm Post subject: Re: Raising a 2000 lb trailer axle |
Max Welton wrote: |
Yeah, we have a TSC here but they only have standard size u-bolts. I haven't had a chance to hit pep Boyz yet..
Max |
Did you ask if they could make a custom set for you? Many places can.
I would make my own blocks from Oak or maple. _________________ nothing |
Posted: Sat Apr 27, 2019 9:56 pm Post subject: Re: Raising a 2000 lb trailer axle |
Of course I did. They can't.
Not only that, but I was also looking for fresh tires for my John Deere 317 (1982) and they not only didn't have those, but referred me to the local Big-O to order them. Big-O was able to get the tires BTW.
The TSC in Monument CO was remarkably unhelpful for a place called Tractor Supply Company. I guess Monument isn't the same market it once was. More urban and less rural.
nsracing Samba Member
Posted: Mon Apr 29, 2019 5:50 am Post subject: Re: Raising a 2000 lb trailer axle |
I put 10,000 lb axles in mine. I got the kits from a supplier in MI. I forget the place now been years.
But they have drop axles so you don't have to mount under the springs.
Those prices are too much. The U-bolts and parts were all USA made from that place. Look some shops up online. They should be all over the place.
Are you doing single or double axles? They have kits for those too. Gotta do welding though. I used a Lincoln 250 MIG to do mine. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Sun Jun 02, 2019 11:35 am Post subject: Re: Raising a 2000 lb trailer axle |
I’ve maintained six trailers over the years with these guys
https://www.championtrailers.com _________________ .ssS! |
