DanHoug Samba Member
Joined: December 05, 2016 Posts: 4798 Location: Bemidji, MN
Posted: Fri Apr 26, 2019 9:10 am Post subject: hard paint for door roller track? |
anyone have success with a type of paint for the bottom roller track under the sliding door? seems like it would be a brutal test of any coating. _________________ -dan
www.thefixitworkshop.com |
jlrftype7 Samba Member
Posted: Fri Apr 26, 2019 9:45 am Post subject: Re: hard paint for door roller track? |
Great Question... I’ve wondered this myself...All I can think of is a 2 part Epoxy Paint type thing. Good Luck buying a small inexpensive quantity for what we need with our VWs, no matter what it is
I need to address my slider in that area once I coax the Track Cover screws out of their rusted holes( they’re shy and don’t want to see the light of day)....
So this is a timely question for me too. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Fri Apr 26, 2019 9:54 am Post subject: Re: hard paint for door roller track? |
Why not use regular paint and then cover with a strong tape? I used this kind of stuff on the roller tracks, it has held up nicely after a year of use, and helps reduce the metallic noise.
https://www.amazon.ca/gp/product/B000REGUE4/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
This particular tape might only last a couple years, but maybe another stronger type could last several years.
edit: added the link to the UHMW tape _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Fri Apr 26, 2019 1:16 pm Post subject: Re: hard paint for door roller track? |
I put HDPE tape on the roller track just for experimentation, what a mistake. There is no material that can take the pressure under the bearing wheel. Get used to bare steel and oil it down as needed. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Fri Apr 26, 2019 7:08 pm Post subject: Re: hard paint for door roller track? |
Was it Du Ponts Imron that I’m thinking was the old 2 part paint that dried pretty hard.
What we really need is the new film finishes that have been developed for engineered flooring material. Those clear coats are supposed to be really hard and even normal flooring sanding abrasives don’t remove them easily _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
jimf909 Samba Member
Posted: Fri Apr 26, 2019 7:37 pm Post subject: Re: hard paint for door roller track? |
jlrftype7 wrote: |
What we really need is the new film finishes that have been developed for engineered flooring material. Those clear coats are supposed to be really hard and even normal flooring sanding abrasives don’t remove them easily |
Imron is a two part paint that’s pretty sturdy. I painted a motorcycle frame with it 25 years ago and it’s held up but still has chipped and worn.
Terry Kay used to tout its praises although I’m not sure it would be up to this task. _________________ - Jim
Abscate wrote: |
E1 Samba Member
Joined: January 21, 2013 Posts: 6565 Location: Westfalia, Earth
Posted: Fri Apr 26, 2019 10:39 pm Post subject: Re: hard paint for door roller track? |
For clarification, "two-stage" implies a basecoat-clearcoat process where the paint must have clear atop the color.
The distinction here, as quoted, is Imron is "two-part;" meaning one mixes paint and a separate hardener with the thinner. "Two-part" does not imply using a clearcoat.
Imron is thus single-stage -- though I believe they make a clear for it if more depth is desired. It's good paint made by a great company, the first poly on the market if memory serves.
I suspect it'd be more durable than stock paint, but I don't know how one gets a gun to paint the slider channel. Our new van needs this attended to asap.
So far as removing the step rail, our screws are also locked on so I plan to drill them out to install a new rail some of us bought as a group buy (Thanks Again, Brandon!). Ours was intended for our first van so it'll be good to finally use it. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sat Apr 27, 2019 4:24 am Post subject: Re: hard paint for door roller track? |
E1 wrote: |
So far as removing the step rail, our screws are also locked on so I plan to drill them out to install a new rail some of us bought as a group buy (Thanks Again, Brandon!). Ours was intended for our first van so it'll be good to finally use it. |
. I painted Industrial Conveyors years ago with a 2 PART paint from Du Pont years ago. It was not a regular paint in the fact that you had to add the activator to it, mix it thoroughly, then you could Spray it.
I thought it was Imron, but that was the middle 80s,,,, so time has gone by.
I don’t remember mentioning 2 stage in my post, but as you noted , that’s a different thing altogether. Perhaps you were confused by the Flooring Finish remark.
That comes as a bit of a joke , I’ll need to explain . The newest prefinished flooring for high end or HD commercial usage has been touted by the manf. Reps at trade shows from what I’m hearing as practically unsandable by normal
Floor refinishing Abrasives. I don’t see a lot of Wisdom in that brag since if it’s possible to ‘outpace’ the very people your industry is relying on to keep the product looking good, but supposedly the new clears are just that tough.
Besides, you probably would have to wear a Hazmat suit and full respirator just to dab some on your sliding door parts with a brush ....
My cover will need to come off for me to see how good , or bad, my rail is. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Sat Apr 27, 2019 2:00 pm Post subject: Re: hard paint for door roller track? |
. I remember reading about this saga....I had forgotten the ‘helpful’ yellow circle of missed rust and paint.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
