Posted: Sat Apr 27, 2019 6:58 am Post subject: Servicing CV joints made easier |
I needed to replace the boots on my CV joints while in dusty Arizona. Don't have a decent workshop here and everything thing is coated with dust, so coming up with a good place to do the work was a challenge. Decide to use a nasty steel bench with a dust impregnated hardboard top which sits outside as it had the needed vise, not the best but better than a piece of plyboard on the floor would have been. I had an old embossed four panel door that would clean up better than the hardboard top of the bench so decided to throw that on top of the bench, and then I decided to take a clean bath towel and cover the door and use that as my clean surface.
This resulted in a great work place for doing the boot replacement. The embossed face of the door, combined with the soft irregular surface of the towel meant the balls would not roll off the bench, while the towel absorbed grease and kept the dust at bay.
This ended up being the easiest place I have ever done CV work. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sat Apr 27, 2019 9:15 am Post subject: Re: Servicing CV joints made easier |
Wildthings wrote: |
Good idea. Better than that concrete armco barrier I used in Virginia by far.
Colin _________________ www.itinerant-air-cooled.com |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12686 Location: on a bike ride somewhere
Posted: Sat Apr 27, 2019 3:18 pm Post subject: Re: Servicing CV joints made easier |
One of those gems that people with nice shops will never understand.
www.airschooled.com |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat Apr 27, 2019 3:23 pm Post subject: Re: Servicing CV joints made easier |
I’ve used a pipe vice on a tripod for years. Pipe vice legs unscrew from the vice for storage... it’s something I used in my side business for many years. The working height is waist level.
Abscate Samba Member
Joined: October 05, 2014 Posts: 22566 Location: NYC/Upstate/ROW
Posted: Sun Apr 28, 2019 7:41 am Post subject: Re: Servicing CV joints made easier |
Awesome on the pipe Vice.
I’ve got about 75 feet of pipe to lay for a NG refit, so I need to buy one, and now have another use for it? _________________ .ssS! |
Posted: Tue Apr 30, 2019 8:26 pm Post subject: Re: Servicing CV joints made easier |
Abscate wrote: |
I’ve got about 75 feet of pipe to lay for a NG refit, so I need to buy one, and now have another use for it? |
Yep!
While you’re at it, fab up a small deck to mount a regular vice to. Under that deck, weld on two lugs sandwiching a 1 1/2 or 2 inch Sch. 40 or heavier pipe. Make the length of that pipe long enough to mount it into the pipe vice. Now you have a tripod with a pipe vice, but the add-on regular vice for other flat work. |
