greek_tony Samba Member
Joined: February 12, 2013 Posts: 243 Location: Athens, Greece
Posted: Sun Apr 28, 2019 5:35 am Post subject: Air filter for speedwell supercharger |
Just fitted my supercharger. Car goes great once a few teething problems where fixed.
With the 26 solex carb there is no room for a filter. Tried a real low small offset pancake, a small 50cc moped filter, and no luck.
Any ideas? What have you guys with the supercharger done?
_________________ 1963 Karmann Ghia - Sold
May 53 Ragtop - Resto started
October 65 Fastback - Almost there. |
sled Samba Member
Posted: Sun Apr 28, 2019 9:02 am Post subject: Re: Air filter for speedweel supercharger |
_________________ drive your split. |
Posted: Sun Apr 28, 2019 12:49 pm Post subject: Re: Air filter for speedweel supercharger |
Thanks!! Unfortunately my carb is much taller than any of those _________________ 1963 Karmann Ghia - Sold
56samba Samba Member
Posted: Mon Apr 29, 2019 8:55 am Post subject: Re: Air filter for speedwell supercharger |
What's the reason for using this 26 carb instead of the normally used 28 PCI? I see you have a 25hp era car, so probably to keep things date correct? I kinda like that idea, although you might miss the acceleration pump.
There were some very flat mushroom air cleaners made by Knecht. They look similar to the typical mushroom air cleaner, just flatter and used on German motorcycles. This could work...
Last solution would be shortening the original manifold and I would prefer this solution rather than driving without any filter.
Back in the early 50's, they used to cut holes in the deck lid, but that's just too radical
Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Tue Apr 30, 2019 12:49 pm Post subject: Re: Air filter for speedwell supercharger |
What everybody don't know is that original pepco didn't use any vw carbs it used a 23mm amal carburetor but the amal carb used a different float bowl not the side draft float bowl ... |
Posted: Mon May 13, 2019 12:40 am Post subject: Re: Air filter for speedwell supercharger |
Thanks everyone for the help.
The 26 was a combination of factors:
25hp era car
Amazingly clean and unworn 26 was available
Hearsay that it was the better carb.
Anyway, we managed to fit a Solex 28. Warning, it's not at all straightforward. Had to mess around with the linkages, use a different screw to bolt the carb to the mounting plate etc...
Result? Damn!!! The car really woke up with the bigger carb!!! And I can finally fit a filter _________________ 1963 Karmann Ghia - Sold
sinclair Samba Member
Joined: July 01, 2004 Posts: 398 Location: New Forest UK
Posted: Tue Jul 07, 2020 12:08 am Post subject: Re: Air filter for speedwell supercharger |
Posted: Tue Jul 07, 2020 2:10 am Post subject: Re: Air filter for speedwell supercharger |
Nice!! (Although I preferred it with the airplane scoop )
Love your Ghia... having a really bad Ghia itch at the mo... might need to sell the oval. _________________ 1963 Karmann Ghia - Sold
Posted: Tue Jul 07, 2020 3:56 am Post subject: Re: Air filter for speedwell supercharger |
greek_tony wrote: |
Love your Ghia... having a really bad Ghia itch at the mo... might need to sell the oval. |
Cheers. Unfortunately that scoop sat virtually on top of the open carb. So it really woke up once it was removed. I’m having a new scoop made 👍 |
Posted: Tue Jul 07, 2020 6:33 am Post subject: Re: Air filter for speedwell supercharger |
sinclair wrote: |
greek_tony wrote: |
Awesome. Can't wait to see what you come up with. _________________ 1963 Karmann Ghia - Sold
Posted: Tue Jul 07, 2020 11:20 am Post subject: Re: Air filter for speedwell supercharger |
Have any of you thought about using a Judson scoop .
I notice there for ghias but I was wondering what if one can modify there decklid for there type1 ....👇👇👇
https://www.thesamba.com/vw/classifieds/detail.php?id=2119464 |
Carrozzino Samba Member
Joined: December 26, 2010 Posts: 8 Location: Aurora Colorado
Posted: Sat Jan 21, 2023 2:25 pm Post subject: Re: Air filter for speedweel supercharger |
I wanted to see if anyone knows who makes the bottom pulley that is on the bottom pictures. It looks to have triangle shapes milled out. I’m looking for a pepco/speedwell crank pulley. I hope to hear back as this is an older thread.
Thanks in advance.
greek_tony wrote: |
Thanks!! Unfortunately my carb is much taller than any of those |
Posted: Sat Jan 21, 2023 2:32 pm Post subject: Re: Air filter for speedweel supercharger |
Carrozzino wrote: |
Thanks in advance.
greek_tony wrote: |
The lower pulley from the picture your talking about was a custom pulley they were testing a larger pulleys for the pepco/ speedwell supercharger to see if it helped make more power with little effect they got some after market vw pulleys welded them to another pulley the cutouts you see is just the crank the front pulleys centers were cut out if you zoom in to the pulley you can see where the belts are you can see the welds... there use to be a guy here in the classifieds who use to sell stock pepco lower pulleys ... |
Tall Bloke Samba Member
Joined: October 07, 2005 Posts: 233 Location: UK>Ohio>UK
Posted: Wed Jan 25, 2023 7:53 am Post subject: Re: Air filter for speedwell supercharger |
Do you have room to use the early Ghia/Type 2 oil bath/air filter neck ?
Image borrowed from gallery. _________________ -------------------
All of 30 horses ! |
