mg93108 Samba Member
Posted: Tue Apr 30, 2019 9:00 am Post subject: What years are BEST to buy, what years to AVOID? (common issues) |
Hi
I've owned a number of Vanagon Westfalia's but I'd like to buy a Eurovan Camper.
Can you wonderful "Sambaneers" provide me with some info about what are the BEST years and which (if any) should be avoided?
I've heard something about transmission issues but I really don't know.
I'm sure that ANY older vehicle has their issue (certainly Vanagon's do) but I'm just wondering if there are any really significant things to be concerned about.
Just to be clear....I'm not looking for a totally restored van. I'm looking for something that I can do body and paint, interior, cosmetics but want to ensure that I get a good mechanical unit.
If you were looking for a Eurovan, what year would you buy...or doesn't it really matter?
THANKS EVERYONE!! |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Tue Apr 30, 2019 10:02 am Post subject: Re: What years are BEST to buy, what years to AVOID? (common issues) |
IMO,
I would prioritize: 1) mileage; 2) vehicle/service history; 3) age.
1) These vehicles are 16-25+ years old at this point, so the amount it has been driven will give you a fairly good indication of impending service (suspension, drivetrain, etc)...try to find as low of mileage vehicle as you can afford.
2) There aren't many mileage-unicorns out there, despite the ridiculous prices in the used Eurovan market. Try to find a vehicle with a complete service history with regular oil and transmission-fluid changes; and, mileage-appropriate service, such as replacement of timing chains, suspension and steering components (bushings, ball-joints, etc), etc. If a major transmission service, rebuild or replacement has been performed, receipts and reputation are of consideration.
If there is no service history, then it is a total crap-shoot whether the van was maintained, cared for or abused, or if a major repair is looming on the horizon. In which case, a 'screaming deal' can likely cost as much as the median market price of a well-maintained van when all repairs are said and done.
3) Older vehicles will likely have more issues with interior components, mainly plastics. Remember, it's a VW, not a Mercedes: 90's era VW plastic trim is fragile, and the plastic in older vehicles will potentially be more prone to cracking. This may further be compounded by region and owner history (SE or SW, stored outside under hot summer-time temps, vs. NE or NW and/or stored inside; etc). Likewise, newer vans have a more powerful VR6 and may be better suited to modern interstate driving (75+ mph). If you want a manual transmission, or are considering a diesel swap at some point, you might want an earlier van.
And obviously, drive it...preferably as long as the seller is comfortable allowing you to do. Transmission problems can't hide from an extended drive...it should shift smoothly without any RPM flares or hard engagements into each gear. Engines should idle smooth, accelerate smooth, not have any valvetrain/timing chain rattle, etc. Don't assume a problem you discover on a test drive is going to go away (it won't); and, if you are not skilled to identify, diagnose and/or repair said problem, then be wary of what any potential problem is worth in the discount of the asking price (i.e. the repair may be more costly than you anticipate). _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Tue Apr 30, 2019 10:29 am Post subject: Re: What years are BEST to buy, what years to AVOID? (common issues) |
Stripped66 wrote: |
IMO,
And obviously, drive it...preferably as long as the seller is comfortable allowing you to do. Transmission problems can't hide from an extended drive...it should shift smoothly without any RPM flares or hard engagements into each gear. Engines should idle smooth, accelerate smooth, not have any valvetrain/timing chain rattle, etc. Don't assume a problem you discover on a test drive is going to go away (it won't); and, if you are not skilled to identify, diagnose and/or repair said problem, then be wary of what any potential problem is worth in the discount of the asking price (i.e. the repair may be more costly than you anticipate). |
Yes, I do know all of this. I've owned over 50 vintage vehicles. My question is not "how to find a good used vehicle" but rather, which years are extra problematic. For example...1983 Vanagon's have lots of variable being that it was a aircooled to watercooled. Also, 1980-1982 Vanagon's are aircooled which are not very desirable.
Which years in particular are problematic (if any)?
What are specific "known issues" that somewhat common to look for? |
Posted: Tue Apr 30, 2019 10:41 am Post subject: Re: What years are BEST to buy, what years to AVOID? (common issues) |
Sorry, I didn't understand what knowledge you're bringing into this search.
There isn't a stand-out year out of the bunch, and no year seems to elicit any more problems than any other from what I've seen. The automatic transmission "issues" are largely dependent on mileage, abuse and service history (or lack thereof), and 01-03 VR6's are known to have cam sprockets that wear their teeth down to nubs (again, typically maintenance history will have addressed this...if there's no maintenance history, plan to replace this ASAP).
So, to directly answer your question, 'all years should be avoided'...that's pretty much what I tell anybody who has a glimmer in their eye after looking over my van.
Good luck! _________________
66brm wrote: |
Bodacious wrote: |
Posted: Tue Apr 30, 2019 10:47 am Post subject: Re: What years are BEST to buy, what years to AVOID? (common issues) |
Stripped66 wrote: |
Good luck! |
I literally was laughing out loud when I read this!!
Thanks so much
I appreciate this advice |
Zeitgeist 13 Samba Member
Posted: Tue Apr 30, 2019 11:45 am Post subject: Re: What years are BEST to buy, what years to AVOID? (common issues) |
I thought the 12v engines were more prone to nubbing the sprockets. The five cylinder manual trans vans are probably the most robust EVs, but lots of us really like the '01-'03 vans due to more power, bigger brakes and swaybars, etc. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Tue Apr 30, 2019 12:09 pm Post subject: Re: What years are BEST to buy, what years to AVOID? (common issues) |
Zeitgeist 13 wrote: |
I thought the 12v engines were more prone to nubbing the sprockets. |
My recollection is from pics Cole has posted of AXF and BDF 24v intermediate sprockets. Maybe I spoke too soon in assuming this is a 24v problem? (though, my high-mileage 12v showed no such wear...) _________________
66brm wrote: |
Bodacious wrote: |
IdeaNerd Samba Member
Joined: May 24, 2016 Posts: 598 Location: Central California
Posted: Tue Apr 30, 2019 12:13 pm Post subject: Re: What years are BEST to buy, what years to AVOID? (common issues) |
The five cylinder manual trans vans are probably the most robust EVs, but lots of us really like the '01-'03 vans due to more power, bigger brakes and swaybars, etc. |
I've heard this too re: 5-cyl and manual trans being robust... and we have '01-'03 Weekenders for the reasons noted above (plus I think the long-nose vans are prettier ).
I've heard allusions (mostly from folks connected to German Transaxle) that the 1997 EVCs are more problematic on the transmission front. I think the owner even comments on the warranty implications of that somewhere on here (a thread he was active on).
The years I'm not clear on (and I'm interested as well), are the 1999-2000 EVCs. Anyone know how they compare to the 2001-2003s? (Are they 12V vs. 24V? -- I'm not even sure of that much). Also, there are no 1998s in the U.S., right? (I don't think I've ever seen a 1998 EV for sale here, regardless of specific model.) |
Posted: Tue Apr 30, 2019 12:34 pm Post subject: Re: What years are BEST to buy, what years to AVOID? (common issues) |
The 24v engines are just in the '01-'03. _________________ Casey--
y u rune klassik? |
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
Dana Champion Samba Member
Joined: July 06, 2012 Posts: 633 Location: Ventura County, CA
Posted: Tue Apr 30, 2019 9:17 pm Post subject: Re: What years are BEST to buy, what years to AVOID? (common issues) |
I've had type 2s for years. I currently have a '70, and an '88 auto, both Westfalias.
I had planned on getting a EVC. I prefer the Vanagon lower bed ; Nice and flat.
I like the '01-03. Drove one at Pop top Heaven. Nice power, braking, traction control was
available, I believe.
In mid year '99 they changed the upholstery (final offering), lost the drawer under the mirror
(now a cupholder), new dash with cool blue lighting, and new steering wheel.
I personally thought I wanted a 2000. The 140 hp 12v motor seems to have enough power
for me. The later models mostly all came with the high altitude fridge vent. Two side vents.
I would also choose the single middle seat, if possible.
Look at the different offerings in the classifieds. Compare them visually to see the visual
differences, and compare the mechanicals. See what you like. I borrowed a friends '95
manual. Liked the five speed. Shift bushing went out on 1st gear. Prefer later interior
Read the forums. Familiarize yourself with EVC's.
Drive one or more, if possible.
All the best with your quest !
Find the one that works for you.
Dana |
thallihan Samba Member
Joined: November 19, 2018 Posts: 3 Location: Corona, California
Posted: Thu May 16, 2019 9:54 am Post subject: Re: What years are BEST to buy, what years to AVOID? (common issues) |
The most sought after version is the 01-03 due to its 200hp and brakes. however the downside is the 24valve puts a lot of stress on the timing gears. If the oil wasnt changed frequently with high quality full synth then the ''soft'' metal gears are easily worn down. This can cause noise issues at first as a warning, but eventually will cause internal damage if not caught.
the 97-00 had 140hp, but doesnt not have the common timing gear/chain issues.
93-95 *AUTO* versions stay away from. the Auto trans in the 5cyl version are no good and problematic. 5-speed 93-95 is slow but reliable.
To summarize: try to obtain a well maintained 01-03 WITH service docs showing the tranmission was replaced and timing gear/timing chain replaced. |
RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Fri May 17, 2019 2:04 pm Post subject: Re: What years are BEST to buy, what years to AVOID? (common issues) |
The '97-99 VR6 12V may have only 140 hp, but it has almost as much torque as the 24V. As we all know, torque is what gets you up the hill. Horsepower develops with high rpms. _________________ Rich |
