1971 Volkswagen westfalia spare tire well rusted out
Catsaysrawr
Catsaysrawr is offline
PostPosted: Tue Apr 30, 2019 9:27 am    Post subject: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
Hi everyone my spare tire well Is rusted through i cant seem to find the metal pre cut like they have for the beetle? Can someone link me one? Or is there anything else I can do for it?
SGKent Premium Member
SGKent is offline
PostPosted: Tue Apr 30, 2019 9:33 am    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
cut it out, weld a plate over it and stick the tire on the nose. Otherwise drill the spot welds and put one in from a donor.
American Standard Snorkeling Terrier
Bring the American Hostages home alive.
Thanks to all who served:
Angus II
Angus II is offline
PostPosted: Tue Apr 30, 2019 9:46 am    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
Hello.
Yes, do it right. Try the classifieds for a piece from a donor bus..... There are sellers on this site that are in your neck of the woods.
Catsaysrawr
PostPosted: Tue Apr 30, 2019 4:46 pm    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
In new here sorry I'm only seeing for the beetle in classifieds.... or type 3
Angus II
Angus II is offline
PostPosted: Tue Apr 30, 2019 5:27 pm    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
Hello,
Hit Classifieds, go down the list to Parts catogory, select Type 2/Bus Bay window 1968-79. Once on the Parts Bay window page, use the "search this section" search box(Top left above pictures). Type in what you are looking for, then hit search.
I just typed in "spare tire" and found one in FL. Also search "Parting out" as your term. "Donor buses" show up that someone may sell you that piece.
Hope this helps.
You will not find a new replacement piece of sheetmetal, just used from a donor bus... Unless the guys over the pond make one????.
Abscate Premium Member
Abscate is offline
PostPosted: Tue Apr 30, 2019 10:31 pm    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
How did s spare tIre well rust like that?
.ssS!
rustbus
rustbus is offline
PostPosted: Wed May 01, 2019 12:35 am    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
is this a full resto bus? cause if its just for fun, that spots' a good candidate for a simple fibreglass patch, and it won't cause the next guy much trouble if he wants to do it right some day
yeah yeah I know
May of '72 Deluxe. Red Bay Bus 2.0L L-Jet CS & 091 trans conversion
my Bus thread
alman72
alman72 is offline
PostPosted: Wed May 01, 2019 3:33 am    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
I had a bus 2 years ago that had a leak in the rear (side) window that pooled water in the tire well
Angus II
Angus II is offline
PostPosted: Wed May 01, 2019 7:14 am    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
Hello,
That little rubber drain plug not working....
Spike0180
Spike0180 is offline
PostPosted: Wed May 01, 2019 9:44 am    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
If you aren't doing a resto, cut a piece of thin plywood to the size of the back "floor" and just cover it over.
Or just take a piece of sheet metal from HD and hammer it to something resembling that and place that in there to re-enforce it.
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
Catsaysrawr
PostPosted: Wed May 01, 2019 12:06 pm    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
It's for me just wanting to make usable and makesure it isnt gonna cause more damage thanks everyone(:
Spike0180
PostPosted: Thu May 02, 2019 5:34 am    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
Then Ospho/por/grease/whatever you want to prevent the rust and cover it with something non-permanent so you can check on it from time to time. Honestly, it looks like it'd still hold a tire fine.
danfromsyr
danfromsyr is offline
PostPosted: Thu May 02, 2019 6:34 am    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
cut it out and mount a diesel heater on the underside there..
win win
Abscate is offline
PostPosted: Thu May 02, 2019 12:31 pm    Post subject: Re: 1971 Volkswagen westfalia spare tire well rusted out Reply with quote
Cut a radial in half and then use it to rubber line it.
.ssS!
