shizam Samba Member
Joined: December 26, 2018 Posts: 82 Location: Oakland, CA
Posted: Mon May 06, 2019 5:58 pm Post subject: Inner headlights not working, outer might be odd too '91 |
Hey again!
Trying to figure out what the deal is w/my headlights, the inner headlights don't come on no matter what (no power to connectors) and the outer lights seem really dim. Here are some photos w/the light arm/switch in the two different positions. This is on a '91 Syncro Camper
A: Does that look correct for the outer lights?
B: What are some obvious spots to check for the inner lights, I checked fuses and they're fine, I currently have the whole fuse box pulled out to look around as well.
Position 1
Position 2
Mikesarge Samba Member
Posted: Mon May 06, 2019 6:15 pm Post subject: Re: Inner headlights not working, outer might be odd too '91 |
by “Position 1” and “2” do you mean the switch on the dash or are you toggling the brights with the stalk? The inner lights are your brights, so if you’re not turning those on that could be your problem
With regard to the brightness issue, are your lights on a separate relay or are they still stock? If they’re stock, search for “headlight relay kit” here and put that in, it’ll make a big difference. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
shizam Samba Member
Posted: Mon May 06, 2019 6:21 pm Post subject: Re: Inner headlights not working, outer might be odd too '91 |
By position 1 & 2 I mean I'm toggling the brights with the stalk, I don't see a switch on the dash (but I'm new to this so may be missing it).
I just installed a relay kit for the lights which is why the fusebox is out and the lights behaved the same before installing the relay though they may be slightly brighter than they used to (next step is to install actually brighter lights).
I checked the voltage at the connectors for the inner lights and don’t see any voltage regardless of which position I toggle the stalk to. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Tue May 07, 2019 5:21 am Post subject: Re: Inner headlights not working, outer might be odd too '91 |
As you go draw out an electrical diagram (schematic), of how you find this has been wired.
This will give you an update for your records and also something you can show us so that the problems can be identified. _________________ This free advice is worth exactly what you paid for it.
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Tue May 07, 2019 5:14 pm Post subject: Re: Inner headlights not working, outer might be odd too '91 |
Have the headlights ever worked correctly since you have owned the van?
Did you wire the South African Grill headlights, or did someone else?
Are you running my relays, or someone else's?
Without seeing the wiring to the lights, it's basically just guess work. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
DuncanS Samba Member
Posted: Tue May 07, 2019 6:42 pm Post subject: Re: Inner headlights not working, outer might be odd too '91 |
I'm not thinking ground as both high and lows share a common ground. It would seem that if the outer dual filament bulbs work at all, then there must be a ground, even if it's in poor condition.
thatvwbusguy wrote: |
Without seeing the wiring to the lights, it's basically just guess work. |
These are the pertinent questions. Smells like a botch wiring job. Possible that the stalk switch isn't working properly. Stick the pin in the white wire and toggle the switching see if you get power. If not, stick a pin in the red/yellow wire at the stalk switch and see if there is power. If yes on the red/yellow, but not on the white--bad switch. If no on the red/yellow, then fix that first. |
shizam Samba Member
Posted: Tue May 07, 2019 9:52 pm Post subject: Re: Inner headlights not working, outer might be odd too '91 |
Mystery solved, it was anti-climactic:
On the back of the fuse panel the "P" post I plugged the high-beam relay into had no power to it. I moved the high-beam relay to a different "P" post and voila, the lights work.
On the one hand I wish I had a better story to tell but on the other I'm glad it was an easy fix
Postscript:
@thatvwbusguy: I didn't install the lights or grille but I did install the relay myself, on the plus side I understand the fusebox _way_ better now
@DuncanS: that is exactly what I did, I checked for power on the back of the low-beam relay at the yellow cable and got 12v; toggled the switch; checked for power on the back of the high-beam relay at the white cable and got 0v. So I poked the multimeter into the the red cable for both (connected to the "P" tab) and found 12v for the low-beam relay and 0v for the high-beam. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9940 Location: Orbiting San Diego
Posted: Tue May 07, 2019 11:06 pm Post subject: Re: Inner headlights not working, outer might be odd too '91 |
Perhaps not quite solved. The way the lights were behaving it seems something else is wrong, not just power for the white wire relay plugged into a dead P spade. Unless some sort of DRL setup is involved.
Mark |
Posted: Wed May 08, 2019 6:46 am Post subject: Re: Inner headlights not working, outer might be odd too '91 |
I agree. Why were the low beams so dim? |
shizam Samba Member
Posted: Wed May 08, 2019 10:01 am Post subject: Re: Inner headlights not working, outer might be odd too '91 |
I think "Position 1" was the high-beams but they were getting no power so all you saw were the "parking lights", "Position 2" was the low-beams and they're just not that bright. Here are the fixed lights now:
"Position 1" high-beam:
"Position 2" low-beam:
Now that I have the relays in I'm going to install some 80/100 lights so my low-beam will be brighter _________________ `91 Syncro Camper |
Posted: Wed May 08, 2019 7:23 pm Post subject: Re: Inner headlights not working, outer might be odd too '91 |
They don't look bright enough to me. Could they somehow be wired in series? |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Wed May 08, 2019 7:36 pm Post subject: Re: Inner headlights not working, outer might be odd too '91 |
DuncanS wrote: |
Off-axis and daylight - they're about right. Our headlights are switched and wired so they're always on with the engine running - and yes, they are feak and weeble (tm). _________________ Jim Crowther
Vespa GTS 300 |
Posted: Fri May 10, 2019 4:03 pm Post subject: Re: Inner headlights not working, outer might be odd too '91 |
Sorry not to reply earlier, but phone camera needed R &R.
Still worried about this issue. Here are pics of my headlights-not Hellas, just Sylvania sealed beams from FLAPS.
First photo is high beam wired in series which are my DRL's.
Second is low beam only.
Third is high beams. Note how much brighter mine are. Yes, they are not 28 year old sandblasted OG lenses and they are relayed. but..... And camera angle is almost identical as the OP.
All of these except my DRL's seem brighter than shizam's. Also notice the color temperature of his lights. Much lower and almost the same as my series wired. I'm convinced something is amiss here.
Duncan |
