runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sat May 04, 2019 6:07 am Post subject: Motor Mount Changing |
I need to change all of my urethane motor mounts including the broken rear ones Took the engine out and disconnected the shifter rod, loosened the clutch cable. The question I have, do I have to disconnect the CV joints to get the transaxle to move enough to the rear to replace the front mount with a stock one?
Testimonial: Never put urethane motor mounts on your VW! _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sat May 04, 2019 6:21 am Post subject: Re: Motor Mount Changing |
I'm under the impression that you can pry the transmission enough rearward to replace that front mount without disconnecting the CV/driveshafts at one end. But I've never tried that, replaced the front mount in my 1970 last year while the transmission was out (and the factory front mount was still OK, unless I replaced that in the early 1980s and just forgot !!!). _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
