jimmytwowheels Samba Member
Posted: Sun May 05, 2019 11:31 am Post subject: sunroof cables! help! |
Hey there! I have an '87 syncro sunroof I'm restoring, and I just pulled the sunroof. Both cables are busted on the cast ends. Question is, are these the same as bay sunroof cables? They look like it in the pics, but wondering if the lengths are the same?
Any help would be most appreciated!
PN's are 241 877 305 and 253 877 305 for the bay and vanagon respectively. So close...
Thank you. |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1868 Location: Pittsburgh PA (ish)
Posted: Sun May 05, 2019 12:44 pm Post subject: Re: sunroof cables! help! |
Any chance you have that contact info?!
Thank you for your input. |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Sun May 05, 2019 5:11 pm Post subject: Re: sunroof cables! help! |
BusDepot can make those kind of gaffs unless you really drill it home with them the difference.
But call Ron Salmon, owner of BusDepot, and he should be able to get or already has what you need.
My sunroof vanagon is an '87 too.
And I also bought some cables long ago from him but still in storage.
For all I know they may be Bay cables |
Posted: Sun May 19, 2019 7:26 am Post subject: Re: sunroof cables! help! |
I've resigned myself to fabricating my own, after modeling each left and right in CAD. I'll machine them from billet aluminum. The trick will be carefully removing the cable ends, and then re-attaching new ones once the guides are installed...
More to follow... |
syncrodemaya Samba Member
Joined: February 24, 2017 Posts: 106 Location: Vancouver
Posted: Mon Apr 17, 2023 4:14 pm Post subject: Re: sunroof cables! help! |
I'll revive this thread, anyone have a source for sunroof cables? _________________ '88 Sunroof Syncro 2.1L |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Tue Apr 18, 2023 12:00 am Post subject: Re: sunroof cables! help! |
ALIKA T3 wrote: |
syncrodemaya wrote: |
I'll revive this thread, anyone have a source for sunroof cables? |
Ha! You didn't buy the stuff from El? |
El didn't offer an answer, believe me, I asked! _________________ '88 Sunroof Syncro 2.1L |
Posted: Tue Apr 18, 2023 12:52 pm Post subject: Re: sunroof cables! help! |
ALIKA T3 wrote: |
El didn't offer an answer, believe me, I asked! |
Corner her at SyncroFest _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
TIVGhia Samba Member
Posted: Sat Apr 06, 2024 4:46 am Post subject: Re: sunroof cables! help! |
syncrodemaya - did you find a good source for cables?
Has anyone found a source for the cables only?
The castings and mechanisms are good enough on my end so if I could find those and crimp em up I'd be set too. |
CHARLIE-DONT-SURF Samba Member
Joined: November 16, 2007 Posts: 332 Location: Cow County, UK
Posted: Mon Apr 08, 2024 7:02 am Post subject: Re: sunroof cables! help! |
Thanks CHARLIE-DONT-SURF - I'll keep an eye out
Thanks Alika - I wrote the seller of the ones in HI and was too late, they are still up but sold.... |
Posted: Fri Apr 12, 2024 5:19 am Post subject: Re: sunroof cables! help! |
This place confirmed looks promising to replace the cables. So this should help out folks, like me, where the lifter mechanisms are in good shape. Unfortunately, they don't have the cable ends / crimp caps. Anyone have a source for those by chance?
https://www.brossautoparts.com/product/bsr594-sunr...meter-5-mm |
Posted: Sat Apr 13, 2024 11:38 pm Post subject: Re: sunroof cables! help! |
TIVGhia wrote: |
My friend bought them, she'll write to you at some point to offload the extras. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Wed Apr 17, 2024 7:26 am Post subject: Re: sunroof cables! help! |
I've found these cable end caps which I think are to go on throttle cable tubes for go-karts with the hole for the cable to come out. Not sure they are robust enough though. Might get them and see if they'll work.
https://fastech-racing.com/motion-pro-housing-ends-5mm-cap-10-pack.html
Does anyone have a cable set out so they could take close up pics of the cable ends?
I'd be interested to see how they are constructed and overall OD and length dimensions. |
