Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sun May 26, 2019 11:55 pm Post subject: Cam gear sizes |
My aftermarket CB cam gear seems to a bit small for my case so I looked in my stash to see if I had a +1 gear I could have milled. Unfortunately I don't, but I did find a gear that I'm not sure what it is.
I have:
-1
+5
0
00
What is the difference between a 0 and a 00? |
Posted: Thu May 30, 2019 12:34 pm Post subject: Re: Cam gear sizes |
I thought this would be an easy answer for someone.
Anyone know the size difference between a 0 and a 00 OG cam gear?? |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Thu May 30, 2019 1:04 pm Post subject: Re: Cam gear sizes |
Zero is zero. Mount them up and check the backlash. |
modok Samba Member
Posted: Thu May 30, 2019 5:19 pm Post subject: Re: Cam gear sizes |
Maybe the guy whos job it was to stamp the number, got distracted and he stamped it twice.
Or maybe he thought that was a good idea.... to distinguish the size mark from the alignment mark.
Check the gear backlash and put your own numbers on it. |
Posted: Thu May 30, 2019 6:09 pm Post subject: Re: Cam gear sizes |
I guess I'll just lay them in the case when I tear it back down for the N-th time. I thought maybe the 0 and the 00 might mean something to someone.
If I find a better fit than the CB gear I have now I'll grind the rivets and find someone to machine it to fit the aftermarket cam I'm using. |
Xevin Samba Member
Posted: Thu May 30, 2019 8:05 pm Post subject: Re: Cam gear sizes |
Do you need help finding a +1 ? FYI should you need a bolt on +2 I have. I ended up using a +1 Brazilian bolt on cam gear. I’m sure I have an old VW +1 rivet style too. Let me know. I’m also hitting a swap meet Saturday and could keep an eye for a bolt on style.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...58d8616250 _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Fri May 31, 2019 1:14 pm Post subject: Re: Cam gear sizes |
Xevin wrote: |
https://www.thesamba.com/vw/forum/viewtopic.php?t=...58d8616250 |
Thx for the offer. I might tear the short block down tonight if I have the energy. Been a rough few weeks at work..
I'll measure my CB gear backlash, then lay the OG cams I have in there and see what I get. |
StefansBus Samba Member
Joined: November 20, 2015 Posts: 242 Location: Germany
Posted: Fri May 31, 2019 1:25 pm Post subject: Re: Cam gear sizes |
During my build the CB alu cam gear didn't work so my builder got me a good used stock VW cam gear that did fit, drilled it out and bolted it to my cam. Problem solved. |
Posted: Fri May 31, 2019 1:34 pm Post subject: Re: Cam gear sizes |
StefansBus wrote: |
Yeah, I'm pretty sure that's the direction I'm headed. This build as been a slow pain in the @rse. |
