Gauche1968 Samba Member
Posted: Wed May 08, 2019 5:18 pm Post subject: Broken Sliding Door Cable? |
What are we doing to replace the sliding door cables (1984) when they break these days as they are no longer available? The adjustment nut has mysteriously come off the end and won't thread back on. _________________ 1984 Vanagon GL
1984 Vanagon Westy |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Wed May 08, 2019 6:01 pm Post subject: Re: Broken Sliding Door Cable? |
Can it be soldered back on with a plumbing torch? Make sure you have the end twisted the right way. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Posted: Thu May 09, 2019 7:19 am Post subject: Re: Broken Sliding Door Cable? |
Probably couldn't solder it as the adjustment nut needs to be able to move on the threads. Its not clear to me why it backed off the threads, but it doesn't look like that nut can be replaced without destroying the cable. _________________ 1984 Vanagon GL
danfromsyr Samba Member
Posted: Thu May 09, 2019 7:23 am Post subject: Re: Broken Sliding Door Cable? |
I may be able to get you one but it'll be june when I have access to it. _________________
Abscate wrote: |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Thu May 09, 2019 8:38 am Post subject: Re: Broken Sliding Door Cable? |
Available in the classified section _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Thu May 09, 2019 4:09 pm Post subject: Re: Broken Sliding Door Cable? |
I fixed it. Used a thread repair tool on the end of the adjustment bolt and got the nut to thread on finally. Still not sure why it backed off, so I put some thread locker on the nut. _________________ 1984 Vanagon GL
