40Grit Samba Member
Joined: October 07, 2015 Posts: 7 Location: Rock Island
Posted: Thu May 09, 2019 7:03 am Post subject: CB Performance disc brakes |
Just installed the CB performance disc brake conversion for Things. Very, very happy with the result. Conversion was for the front only and stops are quick and precise with a great pedal feel. CB advertises this kit as a bolt in and go; not quite that in my case. I had to to a little clearancing on the right caliper to prevent dragging on the the rotor, not a big deal. I also had to call CB for a question on the caliper mount as they are left/right specific and can be installed on either side, but only one way is correct. Customer service was great and on the ball. It did widen the tract by 1 and 5/8 inch; not a problem on my 73. And yes, 15" rims are required. I was already running 15" rims, so again, no problem. If anyone's interested, I could post photos. Really a great upgrade. |
74 Thing Samba Member
Posted: Thu May 09, 2019 7:13 am Post subject: Re: CB Performance disc brakes |
Yes, please post photos.
Is that correct 1 5/8" wider on each side or is that a typo.
How did you distinguish which mount went on which side, and can you post photos of what you had to grind as well?
How long did installation take? Did you get the black drilled rotors? |
40Grit Samba Member
Posted: Fri May 10, 2019 5:53 am Post subject: Re: CB Performance disc brakes |
1 and 5/8 total, both sides added together. So total front track increased 1 and 5/8 overall. I measured it and it and my figures are not exact.
One positive of this is i'm running larger than stock tires (Hankook Dyna Pro MT LT235/75R15) and it eliminated a little dragging on wheel lock.
I will post pictures this weekend. Thanks for the interest. |
