67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Thu May 09, 2019 7:54 pm Post subject: A link worth checking out-for my fellow vw peeps! |
I’m in no way affiliated with the author but the info is great.
I’m currently reading this and thought I would share with you guys. Absolutely fascinating information!!!
If you’ve already read it, I apologize in advance!
But if you haven’t......take a little time to read it over and be prepared to be educated on things you may have never known.
Just trying to help out other “ameteur” builders.
http://haysvwrepair.com/rebuilding-an-air-cooled-vw-engine-non-lego-toy-style/ |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Thu May 09, 2019 8:38 pm Post subject: Re: A link worth checking out-for my fellow vw peeps! |
That’s advice from a repairman.
Builders will likely disagree on many of these points. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Fri May 10, 2019 5:29 am Post subject: Re: A link worth checking out-for my fellow vw peeps! |
I liked how he went into the physics of the motor. But I do think that 40 ft lbs is a bit high for torquing the heads down!!!?
I thought it was very well written and made many good points.
Well.....I liked it. What is there to disagree with? |
Zundfolge1432 Samba Member
Posted: Fri May 10, 2019 10:54 am Post subject: Re: A link worth checking out-for my fellow vw peeps! |
I’ve never seen a broken stud that I couldn’t extract nor have I scrapped one because of that. |
busey Samba Member
Joined: October 19, 2016 Posts: 420 Location: Sun City Arizona
Posted: Fri May 10, 2019 11:38 am Post subject: Re: A link worth checking out-for my fellow vw peeps! |
Zundfolge1432 wrote: |
Advice Needed;, removing my exhaust headers off of my t-1 the other day, i broke one of the studs that screws to each side of the exhaust ports. it obviously must get VERY HOT around those ports. About 3/16 of the stud is all that is protruding from the exhaust port head section. Zundfolge what would you try?? _________________ No turning back now, "Its Blow thru or No thru" baby! |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2506 Location: Santa Cruz, CA
Posted: Fri May 10, 2019 12:21 pm Post subject: Re: A link worth checking out-for my fellow vw peeps! |
busey wrote: |
i broke one of the studs...what would you try?? |
Weld a nut onto the remaining piece of stud, soak repeatedly with PB Blaster or equiv, then remove with a wrench. Applying heat with a propane torch to the area around the stud will help too. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Dauz Samba Member
Posted: Fri May 10, 2019 2:00 pm Post subject: Re: A link worth checking out-for my fellow vw peeps! |
heh.. I just pulled an exhaust stud out and the threads came with it. Took me ten minutes to repair with a 8 x 1.25 time sert kit. |
Posted: Fri May 10, 2019 8:52 pm Post subject: Re: A link worth checking out-for my fellow vw peeps! |
I disagree guys. Scroll farther down into the write-up where he is talking about engine building. There is some VERY interesting points he makes.
He has a different way of explaining things and I can understand easier.
Check it out. |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Fri May 10, 2019 10:35 pm Post subject: Re: A link worth checking out-for my fellow vw peeps! |
Weld a blob on it, hit with hammer directly twice.
Peen the head around the outside of the bolthole.
vise grip the blob and wiggle back and forth.
2 out of 3 you can get but some you just can't
https://www.thesamba.com/vw/forum/viewtopic.php?t=462182 |
