baltik Samba Member
Posted: Sat May 11, 2019 11:15 am Post subject: Anyone with real world experience with VHB tape for solar panels |
I know a lot of people had success taping panels in the RV community, but I'm a big concerned given the surface texture of our fiberglass roofs, would love to hear feedback from others since I absolutely hate the idea of creating permanent holes. I would prefer to use 2 Renogy slim panels as opposed to the flexible ones.
I've seen a number of approaches to this from taping directly to using mounts such as these:
Obviously some aluminum angle iron could be used as well |
E1 Samba Member
Joined: January 21, 2013 Posts: 6563 Location: Westfalia, Earth
Posted: Sat May 11, 2019 12:43 pm Post subject: Re: Anyone with real world experience with VHB tape for solar panels |
No "real world," sorry, but curvature of the roof and latitudinal channels are working hard in aero terms to create flight.
An RV roof is typically dead flat, level, slick, and I suspect has less wind buffeting for creating a higher airstream "hole," if you will.
I'm sure people have done this but for others' safety I determined it an unnecessary risk. I also decided I'd rather fill a few holes later over prepping out the original finish with a big glue patch when the panel configuration could well change later.
Just my $.02, and hopefully worth $.03.
Not intended to be a threadkill and maybe others have indeed successfully done this. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
newerwesty1987 Samba Member
Posted: Sat May 11, 2019 4:58 pm Post subject: Re: Anyone with real world experience with VHB tape for solar panels |
I just took this stuff off recently, off a metal dash where I had a radio mounted, and I couldn't get it off after an hour of trying and prying! I actually pulled on the mount with my entire body weight and still nothing. It got to the point that I thought I was about to bend the dash metal. I ended up inching my way to success by prying with a plastic bar. When the mount finally came off, it took another 30min to get the remaining tape off.
I'd say it would work. I'm always a fan of hardware until I used this 3M stuff. It's amazing. |
baltik Samba Member
Posted: Sat May 11, 2019 5:13 pm Post subject: Re: Anyone with real world experience with VHB tape for solar panels |
I don't think there's a question that the tape is more than strong enough to hold, I believe this is the same tape used to fuse aerospace pieces together, it has tremendous tenstile strength. The tape is rated for Dynamic Overlap Shear: 80 pounds per square inch. But that all assumes optimal bonding, the question is whether optimal bonding can be achieved with our roofs.... |
uberaudi Samba Member
Joined: June 24, 2013 Posts: 503 Location: Hi-top Country
Posted: Sat May 11, 2019 11:21 pm Post subject: Re: Anyone with real world experience with VHB tape for solar panels |
I've put a few thousand miles on this setup and nothing has changed. I ended up using 80 inches of the 1x vhb on the two 40" rails, which are pressed down onto the original paint Adventurewagen fiberglass top. I'm satisfied with the results for sure.
