Spongy brake pedal
Forum Index -> Water-cooled VW Share: Facebook Twitter
Beeble1
Beeble1 is offline
PostPosted: Wed May 15, 2019 2:26 pm    Post subject: Spongy brake pedal Reply with quote
Hello all, normally I hang out in the late model/super beetle forum but Iíve been having some brake problems with my 2013 beetle recently.
When you come to a stop, say at a stop sign or traffic light, I can push the brake pedal all the way to the floor. If I pump up the brakes 3-4 times, the pedal does firm up, but it wonít hold any pressure. It slowly sinks back to the floor.
If you pump up the brakes when the car is off, the pedal holds pressure just fine. But as soon as you start the car, the pedal sinks to the floor.
I took it in Monday to my VW dealer and they said the master cylinder had an internal leak. So they replaced the master and bled all the brakes. Picked it up yesterday and I have the same problem, no improvement at all. Took it back to the dealer this morning and after they had it all day, they said that it is Ďnormalí for the pedal to be like this. I am going back tomorrow morning to talk with them again.
Iíve had this car since new and the brake pedal was never like this until recently. Any ideas? Iím thinking it might be a brake booster leak but Iím not sure. Hooked up my code reader and thereís no ABS codes.
Iíve also spent almost $1000 on this and needless to say Iím NOT happy that the problem is still not fixed.
Jonathon
Beeble1, Ď73 Super (o\_|_/o) 1600cc w/ Dealer A/C
Beeble2, Ď13 Beetle 2.5l daily driver
Bishop-Wayne Volkswagen Kankakee, IL items wanted!
Turner Volkswagen Kankakee, IL items wanted!
View user's profile Send private message Send e-mail Twitter Gallery Classifieds Feedback
Butcher
Butcher is offline
PostPosted: Thu May 16, 2019 6:16 am    Post subject: Re: Spongy brake pedal Reply with quote
This is a classic way a dealership works. I know, I spent 30 years with 2 dealerships.
If it is normal, then why did they replace the master cylinder? If they did replace a good master cylinder, they were stealing from you.
Some of the symptoms you mention are normal. If the engine is off and and you pump the brakes, you are dumping the vacuum that was stored for power assist. Once the booster is empty, the pedal gets hard. If you then start the engine, the vacuum will build and the pedal will drop. That happens with all vacuum boosted brakes.
If you have owned the car since new, then you know there is a difference and that is the biggest asset you have. I suspect that there are other Beetles in the lot so see if you can check those cars to see if the symptoms are the same/different than yours.
Do not leave until you are able to show a foreman/manager the issue and insist you would like to check other Beetles in their inventory.
Beeble1
Beeble1 is offline
PostPosted: Thu May 16, 2019 11:22 am    Post subject: Re: Spongy brake pedal Reply with quote
Went back to the dealer today, and the assured me that the car is fine and that nothing is wrong. They re-bled the brakes again and test drove the car and were Ďunable to duplicate the problemí. So I have the car back. I guess I will just monitor it and see what happens.
[email protected]
Samba Peckerhead
PostPosted: Sun May 19, 2019 3:38 pm    Post subject: Re: Spongy brake pedal Reply with quote
could have an internal leak in the ABS unit. if you are not good with brake fluid flushes the ABS unit can bleed back pressure.
fuck that dealer. go get your $$ back....or make them fix it, free of charge
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
