Bought an over priced tow bar today
brooksinc1976
brooksinc1976 is offline
PostPosted: Wed May 15, 2019 7:31 pm    Post subject: Bought an over priced tow bar today Reply with quote
So that money burnt a hole right in my pocket... and I also ended up with this rail. Does anyone know what type of frame this is or what type it’s suppose to copy? My last one was a one off homemade. This actually has a tag and was it led in Utah as a dune buggy ATV. We don’t have that option in Texas. Looks like the wiring needs a lot of help but is looks pretty good for the price. Thx
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Wed May 15, 2019 8:05 pm    Post subject: Re: Bought an over priced tow bar today Reply with quote
Hi-Jumper Sand Sprite 1 with some modification of cage area.
I would say it is a early version without the 1in diagonal brace that goes between the front crossbar and upper crossbar where steering shaft bearing is mounted.
Usually the between the two hoops that are the cage have to connecting bars where in picture there is only one. And the bars between the front hoop and upper frame rail are not on a standard Sand Sprite.
They are great looking buggies. I am on my second Sand Sprite and 3rd Hi-Jumper frame. First one was a Ascot frame from around 1974.
Have fun with it.
My first one
My third one. Found it unbuilt back in 2010. It has a bolt on A-arm front suspension.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
brooksinc1976
PostPosted: Thu May 16, 2019 5:25 am    Post subject: Re: Bought an over priced tow bar today Reply with quote
Thx for the info, yea I was wondering if that single brace was stock or kustom. With the Texas drama on rails I’m hoping I can get it street legal... but other than going through it I’m just wanting to get some lights on it and look for a body for it.
KingCarGuyZ
KingCarGuyZ is offline
PostPosted: Sat May 25, 2019 7:43 pm    Post subject: Re: Bought an over priced tow bar today Reply with quote
You could always try to do the thing that the Ford hot rodders used to do and steal a hunk of iron with a vin on it from the junk yard, weld it to the tube frame and boom, then it can be a “F-150” or a “Nissan Altima” or whatever’s cheap to Insure. But who knows with what’s going with the Texas laws right now.
Vanapplebomb
Vanapplebomb is offline
PostPosted: Sun May 26, 2019 12:30 pm    Post subject: Re: Bought an over priced tow bar today Reply with quote
Key phrase “used to do” because you could get away with it back then. That’s a BIG no no now.
1800 Type 4 Berrien 295
ConcreteAce
ConcreteAce is offline
PostPosted: Sun May 26, 2019 1:17 pm    Post subject: Re: Bought an over priced tow bar today Reply with quote
Looks like a good start, I saw that for sale when we were looking for my son's project.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build
brooksinc1976
PostPosted: Sun May 26, 2019 4:07 pm    Post subject: Re: Bought an over priced tow bar today Reply with quote
Big no no if you’re caught🤑 hopefully it’ll be a “bug” soon.
What’d you end up fining up in spring?
