Connorwaddell Samba Member
Joined: January 17, 2019 Posts: 58 Location: Bellevue wa
Posted: Wed May 15, 2019 11:14 pm Post subject: Best 40hp big bore kit? |
My original 63 40hp has barely any compression because of worn out rings and I was thinking of just going to a big bore kit but I’m not sure which kit to get. What kit have you all had luck with? Thanks! |
anthracitedub Samba Member
Posted: Thu May 16, 2019 2:03 am Post subject: Re: Best 40hp big bore kit? |
I think there is some discussion over in the vintage speed section... most people are going with the AA offerings. Like most parts, always check fitment... people have found minor clearance issues with the piston skirts.
Also, I would recommend reconditioning the cylinder heads while you have it tore down... it’s likely they need refreshed. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu May 16, 2019 12:42 pm Post subject: Re: Best 40hp big bore kit? |
If the main bearings are well worn, most likely they will give out all too soon when you put the extra pressure of new P&Cs in. _________________ In Stereo, Where Available! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Thu May 16, 2019 12:56 pm Post subject: Re: Best 40hp big bore kit? |
If you are rebuilding, consider adding a doghouse fan/shroud/cooler kit. Original parts are best. I did this on my 1200/1384 conversion, and it really made a huge difference in cooling, and general running when warmed up. It is pretty much a bolt-in setup if you have all the pieces. Otherwise a 1384 can run too hot in traffic or on the freeway. |
