Door handle size mystery
epowell
epowell is offline
PostPosted: Thu May 16, 2019 5:55 am    Post subject: Door handle size mystery Reply with quote
So weird, I ordered 2 door handles, and they both arrived in boxes with the exact same part numbers on them - each handle was identical except that one of them was 6 or 7mm shorter than the other. The shorter one would not fit on the van.
I took the short one back to my parts guy, and he looked it up and told me that the product description states that this handle is good for all years of T3s frm '79 - to '92 (or whatever). My first thought had been that, like the slider door handle, there is a later version which is 6mm shorter??? But it seems not? ...or is there?
The handle only cost $7 (!) and for this money my parts guy doesn't want to bother with a 'return'... so we will just order another one and hope > but I am curious what the explanation for this might be.
www.edwardpowell.com
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Thu May 16, 2019 7:30 am    Post subject: Re: Door handle size mystery Reply with quote
Does the part number on the box match the part number on the actual handle? As I recall, it's cast into the hidden back side of the handle.
Camp Westfalia
Camping Tips Newsletter Cool Campervan Apparel
www.CampWestfalia.com
crazyvwvanman
crazyvwvanman is offline
PostPosted: Thu May 16, 2019 7:45 am    Post subject: Re: Door handle size mystery Reply with quote
There are 2 sizes of SLIDER DOOR handle, depending on model year.
80-84 longer
85-92 shorter
The tip on the later shorter handle can contact the door when fitted to the earlier vans.
I think the length difference is greater than 6 or 7 mm but haven't measured.
Mark
epowell
epowell is offline
PostPosted: Thu May 16, 2019 9:09 am    Post subject: Re: Door handle size mystery Reply with quote
crazyvwvanman wrote:
There are 2 sizes of handle, depending on model year.
80-84 longer
85-92 shorter
Mark
I was sure that must be the answer... it seems obvious that in 85 they shortened all the door handles. It is weird that they list it as one size which fits all years > then they make 2 sizes but give them both the same part number.
Does anyone know if the part number actually changed when they shortened the handles in '85?
MarkWard
MarkWard is online now
PostPosted: Thu May 16, 2019 9:15 am    Post subject: Re: Door handle size mystery Reply with quote
Are you asking about the front door outer handles? I though only the sliding door handle was shortened up. Ive swapped front door handles and must have been lucky to have matching versions. I learn something new about every day here.
1982 Vanagon Camper with ALH TDI.
1990 Vanagon Camper Syncro.
In Car https://youtu.be/5hbfdUJR88Q
crazyvwvanman
PostPosted: Thu May 16, 2019 9:20 am    Post subject: Re: Door handle size mystery Reply with quote
Sorry, I was talking about slider handles, not front door handles.
Mark
epowell
epowell is offline
PostPosted: Thu May 16, 2019 9:26 am    Post subject: Re: Door handle size mystery Reply with quote
huh!? So how can it be that I was given 2 handles - same number on the boxes - identical in all ways but one is 6 or 7mm shorter than it should be?
ZsZ
ZsZ is offline
PostPosted: Thu May 16, 2019 9:30 am    Post subject: Re: Door handle size mystery Reply with quote
front door handles were the same all year.
probably the manufacturer (in china) put golf/rabbit handle in T3/Vanagon packaging.
Take your current with you and choose the one that matches yours. I assume the loger ones are the good
Zoltan
1.9 MTdi Multivan (ex Caravelle)
Van since 2006, engine since 2008
epowell
epowell is offline
PostPosted: Thu May 16, 2019 9:47 am    Post subject: Re: Door handle size mystery Reply with quote
Yes my guess was that they put a Golf or Jetta handle into the wrong box... my parts guy is too busy to do the paperwork required for a "return", so when the new one comes tomorrow, if it is the correct size, I will just buy it and swallow the $8 for the short one... but if it is another short one I will refuse it. Fair enough Smile
jimf909 Premium Member
jimf909 is offline
PostPosted: Thu May 16, 2019 9:48 am    Post subject: Re: Door handle size mystery Reply with quote
That's what I was thinking. Or a subsequent purchaser did a swap and return to stock which is also likely.
$7??? Does that include a lock core and key???
$7 but out of stock...
https://www.hansautoparts.com/251837205DoorHandle.aspx
$39 and in stock...
https://www.gowesty.com/product/handles-trim/2228/front-door-handle-with-keys-
Current: 1990 Westy Camper - Bostig RG4, 2wd, manual trans w/Peloquin, NAHT high-top, Flash Silver, seam rust, bondo, etc., etc.
epowell
epowell is offline
PostPosted: Thu May 16, 2019 9:51 am    Post subject: Re: Door handle size mystery Reply with quote
yep $7.... all inclusive. High quality I'd say. They seem to have plenty in stock >
vanis13
vanis13 is offline
PostPosted: Thu May 16, 2019 10:08 am    Post subject: Re: Door handle size mystery Reply with quote
Prosim, kde?
My old CZ trying to come out - "Please, where?" .....are you finding this handle source? I need a long slider handle.
Ondrej in New Mexico
epowell
epowell is offline
PostPosted: Thu May 16, 2019 10:12 am    Post subject: Re: Door handle size mystery Reply with quote
vanis13 wrote:
Prosim, kde?
Nazdar Ondrej... I have no idea, my parts guy orders them. If you want I can order you one or 50, but then there is shipping....
