dubsteez79 Samba Member
Joined: November 22, 2017 Posts: 194 Location: star nc
Posted: Mon Jun 10, 2019 10:32 am Post subject: Re: 74 Standard Beetle restoration |
Stetoppingphoto wrote: |
Glenn wrote: |
Pruneman99 wrote: |
Some purists won't like it though |
But it does look nice. |
I didn't think it really mattered about keeping the later Beetles original, I get it on pre 65 but the later ones...
Car looks beautiful! |
Thanks!
I like originals and customs of all cars honestly. I have a mk1 GTI and caddy that are, for all intents and purposes, going to be left stockish or in a position that I can make them stock again. Id love to have an original late model standard for a driver just because I am a car hoarder and know that it would be halfway comfortable compared to some of my other, more custom vehicles.
And as far as market price goes for them, you will almost always get more money from an unmolested car than one that has been customized. The perception being, " I wonder what the PO has screwed up to make it this way". Hell I dont even buy cars to restore that have been messed with. They may be rusty piles of shit, but havent been modified lol.
Back to my earlier topic today. What electric fuel pumps are you guys running ? I would like something that doesnt sound like a hornets nest inside a helmet and would also like to leave the FPR under the gas tank as well as the pump. How much pressure drop has anyone experienced from a fpr up front to the carbs in the back? And if no one has checked, would this be valuable information for the vw community? I may set up and experiment to try it out. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Jun 10, 2019 10:40 am Post subject: Re: 74 Standard Beetle restoration |
dubsteez79 wrote: |
I have a mk1 GTI and caddy that are, for all intents and purposes, going to be left stockish or in a position that I can make them stock again |
Now I would love to drop a 2.0l 16v into a early GTi. Just need the Scirocco intake with throttle body on the other side. And of course some 3 piece BBS wheels.... or Ronal R10 Turbos.
dubsteez79 wrote: |
What electric fuel pumps are you guys running ? I |
I run a stock mechanical.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Jun 10, 2019 11:49 am Post subject: Re: 74 Standard Beetle restoration |
Glenn wrote: |
dubsteez79 wrote: |
dubsteez79 wrote: |
I hear that. Even an 8v ABA 2.0L is a burnout machine in A1's! My buddy is working on a 1.8L 16v swap in his mk1 GTI right now so that should be fun whenever its completed. Ive just done some mild engine work on my 1.8 8v but its a noticeable improvement. G grind cam, ported intake, big bore TB, AC delete, 4-2-1 manifold and 2-1/4 exhaust really woke it up from factory.
Glenn, do you run non-ethanol gas in your bug? I have had 3 fuel pump diaphragms fail in 6 months of just sitting. I know ethanol can make rubber parts brittle and its a PITA when I go to move it and get no fuel. If you use some kind of additive, that would be nice to know as well. Thanks |
Glenn Mr. 010
Posted: Mon Jun 10, 2019 11:54 am Post subject: Re: 74 Standard Beetle restoration |
The pump is a Bocar that was first installed in 2006, so it's been in use for 13 years. I use Sunoco 93 which is E10. Since I don't put a lot of miles on it I add some Stabil when I fill up. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Jun 10, 2019 12:02 pm Post subject: Re: 74 Standard Beetle restoration |
Glenn wrote: |
The pump is a Bocar that was first installed in 2006, so it's been in use for 13 years. I use Sunoco 93 which is E10. Since I don't put a lot of miles on it I add some Stabil when I fill up. |
Awesome. Thanks. I figured that buying cheap pumps is my main issue there. If i stay mechanical, Ill probably just buy a Bocar. |
Posted: Tue Jun 11, 2019 7:21 pm Post subject: Re: 74 Standard Beetle restoration |
I drove it today! It starts up and idles ok. It's a dog at low rpm but clears up as the revs build and pulls pretty decent after that. It sounds like it's missing when pulling away from a stop until it gets revved up. Timing is set at 10btdc at idle and about 32 at full advance. carbs are stock empi 34 duals and have been synchronized. Could my 009 not be advancing quickly enough or something? I've checked my valves recently and coil, condenser is new. |
Glenn Mr. 010
Posted: Tue Jun 11, 2019 7:24 pm Post subject: Re: 74 Standard Beetle restoration |
dubsteez79 wrote: |
Could my 009 not be advancing quickly enough or something? |
Is it Bosch or aftermarket?
Personally a 019 mechanical would be better but there's no guarantee. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Jun 11, 2019 7:59 pm Post subject: Re: 74 Standard Beetle restoration |
Glenn wrote: |
dubsteez79 wrote: |
Personally a 019 mechanical would be better but there's no guarantee. |
It is aftermarket. It was bought at a time when I had less money to work with.
I have the original vacuum distributor that I'm considering giving a shot tomorrow. The vac advance mechanism and diaphragm works well. How do the vac advance and centrifugal compare for street car purposes? |
Glenn Mr. 010
Posted: Wed Jun 12, 2019 3:18 am Post subject: Re: 74 Standard Beetle restoration |
dubsteez79 wrote: |
They work well when mated to the original carb. Mixing and matching carb/distributor generally doesn't work. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Jun 12, 2019 5:45 am Post subject: Re: 74 Standard Beetle restoration |
This is my original vacuum distributor.
When I free rev it with a timing light it advances to 32 BTDC from 9 or 10 at idle so I think that the distributor is working properly but am always open to suggestions or verification methods. Im really excited to get this on the road but dont want to drive it while its running weird. Ive spent too much money and time on it to blow it up in the first few weeks that its done lol. |
Posted: Wed Jun 12, 2019 9:35 am Post subject: Re: 74 Standard Beetle restoration |
Ive got the fuel pressure cranked up to 3.5# on my regulator as that seemed to cure the "running the bowls dry" symptom. Is it possible that the idle setting is too lean and the excessive pressure is making it leak into the throat, causing it to seem like it needs that much pressure? Is it a government conspiracy?!?! |
Posted: Thu Jun 13, 2019 5:41 am Post subject: Re: 74 Standard Beetle restoration |
Did not have all the parts to my vacuum distributor so I just set the floats correctly yesterday. Didnt fix the problem but Im glad the floats are in spec now. Video of it running is at link below. You can hear it bog/stop accelerating at a specific throttle position. Im assuming going lean on 2 cylinders based on my exhaust manifold temp readings. Temp readings after running for a few minutes are also below. Will a crossover tube between the intakes help this inadequate fuel distribution? Does it matter which intake runners are connected with the crossover tube?
https://www.instagram.com/p/ByoZqnHj_XN/?utm_source=ig_web_button_share_sheet
Posted: Thu Jun 20, 2019 7:30 am Post subject: Re: 74 Standard Beetle restoration |
So a weak/broken valve spring on #4 intake was at least part of my problem.
On another note, What would be the best SVDA dizzy to pair with my setup? I would like a bosch restored one if at all possible. The one I have is missing parts but I dont know if its worth restoring or not. The vacuum canister I have doesnt seem to fit this particular dist. either which is my reasoning for not restoring myself. I saw the prices of the NOS bosch cans and decided against it lol. |
Posted: Sun Jun 23, 2019 6:31 pm Post subject: Re: 74 Standard Beetle restoration |
After changing all the broken valve springs and rejetting the carbs, i took the bug to it's first fill up in many years. I took the crossover hose off as well because the fitting was interfering with the spark plug. I'm happy to say that it runs really good. Idle is smooth and consistent. I've got to change my fpr very soon and may go to electric pump at the same time to clean the engine bay up a bit.
Glenn Mr. 010
Posted: Sun Jun 23, 2019 8:00 pm Post subject: Re: 74 Standard Beetle restoration |
That muffler sure is close to the ground. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Jun 24, 2019 6:04 am Post subject: Re: 74 Standard Beetle restoration |
Glenn wrote: |
That muffler sure is close to the ground. |
Lol yep. Didnt drag it yet but im sure itll happen. If it does, ill take the whole exhaust off so I can add an o2 sensor bung and use my wideband to fine tune everything. I doubt ill ever raise it up any higher though because im stubborn and like how it sits. |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Fri Jun 28, 2019 7:40 pm Post subject: Re: 74 Standard Beetle restoration |
Rebuilt my original 043 905 205 svda distributor to replace the aftermarket 009 that's in there. really just cleaned it and replaced the fiber washers, cap, rotor, condenser and points. Hope to see an improvement in "cruisability". Pictures to come. |
Posted: Mon Jul 01, 2019 7:06 pm Post subject: Re: 74 Standard Beetle restoration |
Got my fuel pressure regulator in. Had to use a bunch of fittings to make the pressure gauges work out but I'll tidy that up later. Got the Carter pump mounted and double isolated on the pan, under the tank. Got my used but good thermostat delivered and hope to put that on tomorrow as well as hooking the fuel pump up. Also ordered a block off plate for the mech. pump, and phenolic spacers for the carbs to help with the heat soak. It's running well though. I've put about 50 or 60 miles on it and am happy with the overall feel of the car. Steering box is kinda sloppy even after adjustment so I may have to replace or rebuild it at some point if I can get hard parts. Are there any aftermarket or oe steering boxes for these with a better, tighter feel?
Posted: Wed Jul 03, 2019 5:53 pm Post subject: Re: 74 Standard Beetle restoration |
My sound system for the bug lol. These things are actually really loud and the sound is clean maxed out. It'll do for this car.
