Jake1984 Samba Member
Posted: Sun May 19, 2019 2:45 pm Post subject: High oil pressure |
My 1991 Jetta 1.8l keeps blowing the oil filter gasket does anyone know what would cause this |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Sun May 19, 2019 4:22 pm Post subject: Re: High oil pressure |
What filter are you using? The over pressure valve is in the oil pump. If that is stuck, that certainly could cause the filter to blow.
I suggest you purchase a Mann filter. If they do not have one at your parts department, you are shopping at the wrong place. |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Sun May 19, 2019 4:54 pm Post subject: Re: High oil pressure |
Butcher wrote: |
X2! The metal on cheap ass oil filters is too thin & will distort to the point that they will blow the seals. Squeeze the filter by hand, if you can dent it or feel it yield, throw it away. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun May 19, 2019 6:34 pm Post subject: Re: High oil pressure |
I put a wix filter on it, I cleaned out the oil filter adapter now everything is working perfect. Thank you |
Das67bus Samba Member
Joined: April 06, 2008 Posts: 242 Location: Prescott, AZ
Posted: Sun May 19, 2019 7:54 pm Post subject: Re: High oil pressure |
Jake1984 wrote: |
Perfect! _________________ SLOW RIDE........TAKE IT EASY!!!
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd |
