The Big Cheese Samba Member
Joined: May 04, 2019 Posts: 72 Location: Annapolis, MD
Posted: Tue May 21, 2019 7:35 am Post subject: 16 inch wheels on Ivory Vanagon |
I'm debating between purchasing the following wheels for my ivory Vanagon:
16 inch Van Cafe Mefro steel wheels
16 inch GoWesty Steel wheels (Black)
16 inch GoWesty Steel wheels (White but painting them ivory). See https://bringatrailer.com/listing/1991-volkswagen-vanagon-westfalia-2/ for a reference
I'm curious to see how these wheels look. Anyone out there have these wheels on an Ivory Vanagon or wheels other than stock? |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
geoffraynak Samba Member
Posted: Tue May 21, 2019 10:00 am Post subject: Re: 16 inch wheels on Ivory Vanagon |
welllllllllllll
that BaT van now belongs to me!!!
we've named it 'Butters'
and yes ... those wheels just 100% bring the whole van together
you will not regret it!
cheers
geoff |
danfromsyr Samba Member
Posted: Tue May 21, 2019 11:42 am Post subject: Re: 16 inch wheels on Ivory Vanagon |
Might want to change that trans ground strap Geoff
https://cdn.bringatrailer.com/wp-content/uploads/2018/05/152770085061f4f8f0f5558IMG_3907.JPG.jpeg
geoffraynak wrote: |
welllllllllllll
cheers
geoff |
Abscate wrote: |
These are the reasons we have words like wanker |
Posted: Tue May 21, 2019 12:12 pm Post subject: Re: 16 inch wheels on Ivory Vanagon |
Big Cheese: i love the mefros ... but the painted-to-match are pretty sweet ...
and ... Dan: yes ... it has been replaced already with the GW strap...
along with ninety (90!) other action items ...
only 35 things to go ... until another 35 pop up! |
jimf909 Samba Member
Posted: Tue May 21, 2019 7:54 pm Post subject: Re: 16 inch wheels on Ivory Vanagon |
FWIW, I much prefer the Van Cafe metro hole pattern. I think the GW wheels need more holes. YMMV. _________________ - Jim
Abscate wrote: |
Posted: Thu Jun 06, 2019 11:17 am Post subject: Re: 16 inch wheels on Ivory Vanagon |
I've decided to go with the 16 inch Mefros and a 1.5 lift. Does anyone recommend a tire? |
E1 Samba Member
Joined: January 21, 2013 Posts: 6572 Location: Westfalia, Earth
Posted: Thu Jun 06, 2019 11:22 am Post subject: Re: 16 inch wheels on Ivory Vanagon |
BFG KO2... if you want an off-road tire that is great on pavement, too. _________________ 84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
Colin Chapman |
Posted: Thu Jun 06, 2019 11:33 am Post subject: Re: 16 inch wheels on Ivory Vanagon |
E1 wrote: |
BFG KO2... if you want an off-road tire that is great on pavement, too. |
Thanks! I don't think I need a off-road tire as I'm probably rarely going to take the van truly off road.
I was thinking about getting a 215/65/16 tire.
For the BFG tires, don't you need to calibrate your speedometer ? |
elizer Samba Member
Joined: May 02, 2016 Posts: 1466 Location: Northern Virginia
Posted: Thu Jun 06, 2019 11:41 am Post subject: Re: 16 inch wheels on Ivory Vanagon |
I have bfg ko2 215/65/16 my speedo is off by around 3-4 mph. Any taller than stock tire will make it be off by a little. But I use GPS to get a more accurate speed.
I will be looking at the nokian wr c3 van line tires for my next go around. |
E1 Samba Member
Posted: Thu Jun 06, 2019 11:48 am Post subject: Re: 16 inch wheels on Ivory Vanagon |
With our 14s and 195/75s, if we showed 55 we were maybe doing 52 (as designed).
With the BFGs, when showing 55 we're doing about 56.
(both according to "Your Speed is" signs) _________________ 84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
Colin Chapman |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Thu Jun 06, 2019 11:51 am Post subject: Re: 16 inch wheels on Ivory Vanagon |
Congrats on the new van! I saw that van in person with its previous owners in Baja a few years back. Gorgeous.
_________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
creative native Samba Member
Posted: Thu Jun 06, 2019 10:53 pm Post subject: Re: 16 inch wheels on Ivory Vanagon |
I recently bought the GoWesty 16" black steel wheels and chose the Nitto Crosstek 2 215/70R16 and am very happy with this upgrade. THIS is how a Vanagon should have been from the factory. Admittedly, the larger tires did rob some of the power, but ultimately, I have no regrets, especially considering the improved ride and performance. |
Posted: Fri Jun 07, 2019 10:38 am Post subject: Re: 16 inch wheels on Ivory Vanagon |
creative native wrote: |
Those look great. Do you have a stock lift? |
Posted: Fri Jun 07, 2019 5:16 pm Post subject: Re: 16 inch wheels on Ivory Vanagon |
Thank you, The Big Cheese. I opted for the GoWesty 1.5" lift springs. I meant to mention that. I'm very happy with this set up. |
Posted: Fri Jun 14, 2019 3:36 am Post subject: Re: 16 inch wheels on Ivory Vanagon |
Sweet! I ended up purchasing the Schwenk springs from Van Cafe (https://www.vancafe.com/2WDSprings-p/2wdsp.htm)
I didn't end up getting the GW 1.5 springs since I'm not purchasing tires larger than 215/65/16.
My understanding is that the Schwenk springs should give the van a slight increase in height (0.5 + fix whatever sag my van has) -- which should be fine. |
Marshj Samba Member
Posted: Fri Jun 14, 2019 7:54 am Post subject: Re: 16 inch wheels on Ivory Vanagon |
16 7 spoke Passat wheels from a 2005 Passat Wagon.
Suspension is stock 86 which sits high:
Suspension from center of hub to bottom of fender:
Pass Rear 17
Drive rear 16.5
Drive front 16.33
Pass Front 16.33
I now have the second set of Michelin Defender 215/65/16 tires on it. I drive 98% paved roads and like these tires. Ok in snow, not great. Excellent in rain and everything else this van usually sees from March-Nov in the northeast
215/65/R16
Michelin Defender T + H 98H 1653 lb loadboth are m+s
Posted: Fri Jul 19, 2019 6:54 am Post subject: Re: 16 inch wheels on Ivory Vanagon |
Here we go!
