SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Tue May 21, 2019 9:03 am Post subject: Why do my rear brakes appear to work great but squeal so bad? |
I rebuilt my rear brakes about 12k miles ago, new drums, shoes, cylinders, and all the springs. After that, the driver's side would squeal loudly juuuust before the van would come to a complete stop. I thought maybe they needed to break-in but it didn't go away. After a while I put a little more high-temp grease on the backing plate contact points but that didn't help anything.
Last weekend I swapped the shoes out with new set of ATE brand shoes. The new shoes visually appear to match the curve of the drum perfectly. I noticed one of the old shoes on the driver's side had a cracked lining and the brake internals were covered in brake dust while the passenger side brake looked almost as clean as the day I rehabbed it. I figured that must have been my problem.
Nope, the driver's side still squeals! The van stops great, pedal feels good, E-brake holds at 3 clicks, van holds a straight line braking with the pedal or the E-brake.
What in the world could be making the squeal? _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
SCM Samba Member
Posted: Wed May 22, 2019 7:33 am Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
Just one bump before I leave on the first Westy trip of the year! _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Wed May 22, 2019 7:36 am Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
possible rubbing on the backing plate? _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
SCM Samba Member
Posted: Wed May 22, 2019 8:55 am Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
dobryan wrote: |
Slap a new drum on the driver side and see if that makes a difference? |
That's a good idea and I just happen to have a new drum I could use (one of the two I ordered was damaged in shipping but I didn't notice it until they sat on a shelf for a while). _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
SCM Samba Member
Posted: Tue May 28, 2019 9:50 am Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
Hmmm, the plot thickens. Not only does that brake squeal but it's heating up a lot more than the others. I need to verify this but I think it only heats up after stopping from a high speed (i.e. highway off ramp) and not from just driving around.
I'm wondering if the non-squealing rear brake isn't engaging and that's allowing the other to get overworked and overheated.
Does that brake proportioning valve under the van control front/rear bias or does it have an effect on right/left function? _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9939 Location: Orbiting San Diego
Posted: Tue May 28, 2019 10:07 am Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
The rear brakes connect to a TEE near the tranny nose. Only 1 line from the front feeds both, via the tee.
I would consider replacing both rear rubber hoses as that is a known cause of problems and expected to need periodic replacement. They don't cost much and are not hard to replace unless you have a rusty setup.
Mark |
SCM Samba Member
Posted: Tue May 28, 2019 11:45 am Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
crazyvwvanman wrote: |
I would consider replacing both rear rubber hoses |
I forgot to mention that all the rubber hoses were replaced when I did the other brake work, including flushing the old brake fluid.
Crappy new parts is something to consider though. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Igeo Samba Member
Joined: September 25, 2018 Posts: 888 Location: Oakland, CA
Posted: Tue May 28, 2019 12:02 pm Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
Squealing drum brakes are usually glazed linings or a polished drum friction surface. If it were me, I would pull the off the offending drum, then with some 150 grit emery cloth, give the linings a good de-glazing. Do the same to the drum to knock the polish off. This will not affect your adjustment. No greasy or oily finger marks allowed! _________________ 1987 Westfalia 2.1 WBX Manual |
SCM Samba Member
Posted: Tue May 28, 2019 12:10 pm Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
Igeo wrote: |
Squealing drum brakes are usually glazed linings or a polished drum friction surface. If it were me, I would pull the off the offending drum, then with some 150 grit emery cloth, give the linings a good de-glazing. Do the same to the drum to knock the polish off. This will not affect your adjustment. No greasy or oily finger marks allowed! |
It would be awesome if that works but how would that explain the extra heat?
For perspective, I measured all my drums with an IR thermometer and the squealing one was around 170F when the quite one was only 70F. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Igeo Samba Member
Posted: Tue May 28, 2019 12:20 pm Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
Unequal adjustment may be your issue.
A 70 degree temp reading after a hard stop sounds low. That's ambient.
170 is more like it. I would back off both sides untill there is no drag. Put a dab of white lithium grease under the shoes where they contact the friction pads on the backing plate so they are free to pivot nicely. Just a dab. Then adjust the brake on one side until it's essentially locked up, and you can't rotate the drum. Then, back off on the adjustment until you can rotate easily with the wheel on, but to a point where you can still hear and feel drag. Confirm that your e brake is still working at 3-4 clicks and you should be good.
Also- You might have to bleed both sides. If there is air in one side, that side will be ineffective. _________________ 1987 Westfalia 2.1 WBX Manual |
SCM Samba Member
Posted: Tue May 28, 2019 12:27 pm Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
Those all sound like good ideas guys. Thanks. I'll report back once I get around to checking those things.
First I need to catch up on my day job and also post a trip report! _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
E1 Samba Member
Joined: January 21, 2013 Posts: 6572 Location: Westfalia, Earth
Posted: Tue May 28, 2019 12:35 pm Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
Unlikely being that you've "gone back in there," but......
We once had the same symptoms in our Jetta. It was a tiny piece of gravel floating around, then re-embedded.
Ten-Second Test:
Back up the bus (literally, Haha) at a decent clip, and stomp the brakes.
Again, may not apply, but worth a try!
(rhyme unintentional, apologies) _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
handjammer Samba Member
Posted: Tue May 28, 2019 1:55 pm Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
Did you buy the cheaper rear drums? Check if they are round.
I had similar issues with my rear brakes after I did a full rebuild with GoWesty parts using the less expensive, non-finned drums. One of the drums got so hot it caused the rubber in the cylinder to melt, eventually leaking.
Took a while to find the problem, even had a few shops look at them. Finally discovered that the new drums were way out of round. Learned my lesson the hard way, don't buy cheap parts! _________________ '87 tintop syncro w/ EJ22 |
E1 Samba Member
Posted: Tue May 28, 2019 2:02 pm Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
Wouldn't that be obvious in pedal pulse, plus make inconsistent sounds? _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Abscate Samba Member
Posted: Tue May 28, 2019 2:13 pm Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
E1 wrote: |
Wouldn't that be obvious in pedal pulse, plus make inconsistent sounds? |
No, in my experience. _________________ .ssS! |
E1 Samba Member
Posted: Tue May 28, 2019 2:16 pm Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
Thanks, and curious... Because the shoes adjust to the egg shape quickly enough to not wobble, nor screech just once per rotation? _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu May 30, 2019 8:20 am Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
E1 wrote: |
Pull up on the handbrake a little while driving and you'll feel if the drums are round - or not! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
SCM Samba Member
Posted: Sat Jun 08, 2019 12:55 pm Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
Man, this is puzzling.
I drove the van today for the first time since our 1500 mile trip and noticed that the E-brake is now not holding at 3 clicks, more like 6, and the pedal travel has increased a bit.
I confirmed that the driver's rear brake heats up much more than the passenger side during braking - not just driving around.
I pulled the drum and found that the front brake shoe, replaced just 1500 miles ago, is worn down to about 30% of it's orginal thickness. The rear shoe looks like new, which it is.
The drum spins freely after pumping the pedal and actuating the E-brake so it seems doubtful that anything is dragging while driving.
Both brakes were adjusted per the Bentley when I first did the job (spaced 1.5 mm less than the drum ID) and brakes felt great so I don't know what would be going on there. The passenger side brake engages with the pedal and E-brake so it's not like that isn't working at all.
If I somehow botched the adjustment making the passenger side drum engage later than the driver's side, would that cause this? It seems unlikely to me that that would cause the one brake shoe to wear so quickly but maybe I'm wrong? _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Sat Jun 08, 2019 1:27 pm Post subject: Re: Why do my rear brakes appear to work great but squeal so bad? |
You probably have hydraulic issues o the cold side
Plugged lines
Rusted. Wheel cylinder _________________ .ssS! |
