DaVonZip Samba Member
Joined: February 15, 2007 Posts: 734 Location: Fort Myers Florida
Posted: Tue May 21, 2019 11:29 am Post subject: 70 bug engine look wired up correctly? |
New rebuilt engine, 30 Pic 1 carb (my choice).. But using existing wires, seem correct? Thanks, there's a red wire coming out next to the wiring harness it seems to go to the dash somewhere?
_________________ -No, the point is, it's your frickin car. Drive it. park it, light the bitch on fire-- it's not for us to say. (samba member)
-For once in my life, i'd like to get up in the morning and be as happy as my pennis is... (samba member) |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Tue May 21, 2019 11:36 am Post subject: Re: 70 bug engine look wired up correctly? |
This one appears to be OK
This too
That leaves a wire to go to the oil pressure sending unit. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue May 21, 2019 11:44 am Post subject: Re: 70 bug engine look wired up correctly? |
Thanks cusser, look at first Pic again, I have a wire piggybacked to the spring on carb,can I make one also to oil sending unit using same wire? _________________ -No, the point is, it's your frickin car. Drive it. park it, light the bitch on fire-- it's not for us to say. (samba member)
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Tue May 21, 2019 12:37 pm Post subject: Re: 70 bug engine look wired up correctly? |
DaVonZip wrote: |
Thanks cusser, look at first Pic again, I have a wire piggybacked to the spring on carb,can I make one also to oil sending unit using same wire? |
NO, the wire going to the carb is providing 12V. The wire going to the oil pressure sending unit is a ground wire. When the oil sending unit has oil pressure pushing on it, it actually opens or turns the switch off. When there is no oil pressure, the switch in the sending unit closes, and provides a ground for the oil idiot light. I have looked at this picture:
There is a blue wire connected to the positive side of the coil. From the factory, the oil sending unit wire is blue. So, unless the wiring has been hacked up, I "believe" that wire should go to the oil pressure sending unit. However, you will have to trace it to make sure. Do you have an ohm meter, or continuity checker? It will make your life a whole lot easier if you do. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
mukluk Samba Member
Posted: Tue May 21, 2019 1:04 pm Post subject: Re: 70 bug engine look wired up correctly? |
DaVonZip wrote: |
there's a red wire coming out next to the wiring harness it seems to go to the dash somewhere? |
If the car has or had a tachometer, the red wire is most likely the signal wire for it. _________________ 1960 Ragtop w/Semaphores "Inga" |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Tue May 21, 2019 2:01 pm Post subject: Re: 70 bug engine look wired up correctly? |
This simplified diagram from Speedy Jim's site shows everything downstream from the single black #15 wire coming out of the harness and going to the #15 (+) terminal of the ignition coil.
It does NOT show the blue/green wire from the OIL indicator lamp in the speedo. This additional wire comes out from the harness and connects to the terminal on the oil pressure switch below the distributor.
_________________ AshMan40
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sun May 16, 2021 5:05 pm Post subject: Re: 70 bug engine look wired up correctly? |
Hi guys. i searched. but couldnt find an engine diagram. i need a wiring diagram for a 1600 with a generator. Does anyone know where i could find one?
Thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
busdaddy Samba Member
Posted: Sun May 16, 2021 5:27 pm Post subject: Re: 70 bug engine look wired up correctly? |
Thanks. I think the issue was I was looking for an engine only diagram but this will work. Thanks again. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
