1979vwcamper Samba Member
Posted: Wed May 22, 2019 2:39 pm Post subject: Paint code |
Hello, can someone guide me in the right direction? I have a 65 deluxe and trying to unravel the paint code. These are the numbers on the m-plate.
524300. I have looked at the chart on the site and I don’t see the numbers.
What am I doing wrong?
Thank you. |
EmpiGT Samba Member
Posted: Wed May 22, 2019 3:29 pm Post subject: Re: Paint code |
That is one ordered in a special color. 5 the model year 24 the model and 300 the special paint code. Not sure what the 300 is. Do you have any original paint on it anywhere that you can tell what it is? Most likely a solid single color. Most deluxes in special ordered paint are 1 solid color.
Edit looking at the color chart. The 300 range looks to be the reds. So in guessing maybe solid sealing wax red? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed May 22, 2019 3:40 pm Post subject: Re: Paint code |
First off you posted this question twice. Be good if you would get to the other same post and delete it before someone posts there also and locks it from being deleted.
Did a search of the forum for "paint code 300" and got this among a few others.
https://www.thesamba.com/vw/forum/viewtopic.php?t=657137&highlight=paint+code+300 _________________ In Stereo, Where Available! |
EmpiGT Samba Member
Posted: Wed May 22, 2019 3:48 pm Post subject: Re: Paint code |
If that's the case. Fire red needs to be added to the special paint codes. |
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 902 Location: Las Vegas, NV
Posted: Wed May 22, 2019 4:31 pm Post subject: Re: Paint code |
EmpiGT wrote: |
It is in there is you scroll down one more section to the Public Service SO codes in the paint section. _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Wed May 22, 2019 5:59 pm Post subject: Re: Paint code |
ronjonlasvegas wrote: |
EmpiGT wrote: |
It is in there is you scroll down one more section to the Public Service SO codes in the paint section. |
makes sense considering that RAL 3000 is fire red, or Feuer Rot in German _________________ regards
Uli
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed May 22, 2019 6:07 pm Post subject: Re: Paint code |
1979vwcamper- I just scoured your gallery- where's a picture of this rare red bird? _________________
EverettB wrote: |
FU#5 |
Posted: Wed May 22, 2019 6:26 pm Post subject: Re: Paint code |
Thanks guys. It is a crusty mess, but it is mine. HAHA. Here are some picts.
Posted: Wed May 22, 2019 7:21 pm Post subject: Re: Paint code |
Well do start a thread on it, or convert this one into that! _________________ In Stereo, Where Available! |
Posted: Mon Jun 03, 2019 10:16 am Post subject: Re: Paint code rare solid color??? |
Ok folks here are the new pictures as i got it home today. It looks like it was painted again at one point. it is red looking at the gas door. Here is the code for the year. Is it a 65 or a 66? Any input would be helpful!! Tying to see if it is worth restoring or not. Thanks again dudes!!!
Posted: Mon Jun 03, 2019 11:10 am Post subject: Re: Paint code |
Looks like AUG65 build. Post image of data plate on the RH side of the fresh air box. _________________ In Stereo, Where Available! |
EmpiGT Samba Member
Posted: Mon Jun 03, 2019 12:07 pm Post subject: Re: Paint code |
Eric&Barb wrote: |
Looks like AUG65 build. Post image of data plate on the RH side of the fresh air box. |
You mean Sept? 8 is August. 9 is Sept. This is a 66 model year built 9/2/1965. |
Posted: Mon Jun 03, 2019 1:16 pm Post subject: Re: Paint code |
EmpiGT wrote: |
Eric&Barb wrote: |
The below from the VIN/Chassi Numbers page available above thru the "Technical" button on right above. Chassi numbers are in that list are end of month. The "6020051" chassi number would come just before the end of month chassi number.
Quote: |
Aug 216 020 494 (engine) H0 023 158
Aug. 2 - 1966 model year, 1500cc engine |
Have heard that if one ordered a deluxe without sun roof, it delayed the manufacturing of it a bit. They had to take it off the deluxe manufacturing line and work it into the standard roof manufacturing line to have the no holes roof and upholstery installed.
9/2/1965 was a Thursday, so the bus could have been started to be built on Tuesday or even possibly Monday. _________________ In Stereo, Where Available! |
Posted: Mon Jun 03, 2019 1:19 pm Post subject: Re: Paint code |
Thank you!!! So it is a 66 Deluxe in a solid red? |
Posted: Mon Jun 03, 2019 1:29 pm Post subject: Re: Paint code |
1979vwcamper wrote: |
As it says in the quote in the last post about model year.... _________________ In Stereo, Where Available! |
Posted: Mon Jun 03, 2019 1:31 pm Post subject: Re: Paint code |
As for the model it will be on the fresh air vent.
Right now guessing it is a stock deluxe, and not a standard bus with the most rearward side window and dash clock hole hacked in. _________________ In Stereo, Where Available! |
Posted: Mon Jun 03, 2019 1:41 pm Post subject: Re: Paint code |
The 25 makes it a deluxe? |
EmpiGT Samba Member
Posted: Mon Jun 03, 2019 1:45 pm Post subject: Re: Paint code |
Model off of the m code plate "25" is a true deluxe
So the vin number will have 25 before the rest of the vin off of the mcode.
Edit. Never mind you just posted a pic of the vin plate |
Posted: Mon Jun 03, 2019 1:51 pm Post subject: Re: Paint code |
Thank you all for your help! Now, just have to decide to fix it or not. |
