tomsbuggered Samba Member
Joined: October 16, 2014 Posts: 417 Location: Calgary, AB Canada
Posted: Thu May 23, 2019 8:57 am Post subject: tar board substitute? |
I pulled the engine out of my '59 Beetle last night to check the starter bushing and replace the flywheel seal. While it is out I am wondering whether to replace/remove the tarboards ? They are unsightly, curled up after only two years. Would it be better to just remove them or is there a better replacement out there? I see Empi has a S/S set but they don't look like they fit like the stock tarboard. Any suggestions would be appreciated.
Also, what is best method to remove/replace starter bushing ? I have read using an easy out or thread tap works. Can they be drifted out ? The starter has a tendency drag sometimes.
Thanks in advance. _________________ June 1956 VW Oval Beetle |
jason Samba Member
Posted: Thu May 23, 2019 9:06 am Post subject: Re: tar board substitute? |
If engine is out use a drift. A piece of wood would also work. I think the SS ones are for looks only. |
cyclehobby Samba Member
Joined: August 29, 2013 Posts: 156 Location: North Jersey
Posted: Thu May 23, 2019 9:53 am Post subject: Re: tar board substitute? |
I replaced my old, original and sagging engine tarboards with new ones from Chris Vallone at ClassicVWBugs.com. They're heavy rubber material and they look both correct and very nice when installed. _________________ 1967 Beetle
Northern NJ |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2940 Location: Fresno, Ca.
Posted: Thu May 23, 2019 11:24 am Post subject: Re: tar board substitute? |
Leave the fake chrome stuff in the 80`s where it belongs. Try Wolfsburg West for tarboards. They are very nice. But like anything, will require some trimming to fit right. _________________ If you`re going to do something, do it right. |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2504 Location: Santa Cruz, CA
Posted: Thu May 23, 2019 5:04 pm Post subject: Re: tar board substitute? |
Bryan67 wrote: |
Try Wolfsburg West for tarboards. |
Yes, WW's tarboards are very good quality and have the look and texture of the originals. They do require a bit of trimming though. They're the smooth type, not the waffle pattern seen in some cars. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
my59 Samba Member
Joined: August 13, 2003 Posts: 3791 Location: connecting the dots
Posted: Thu May 23, 2019 5:53 pm Post subject: Re: tar board substitute? |
jason wrote: |
I carved a wood dowel to fit the bushing to put a new one in, helps keep everything aligned, and no load on bushing diameter. Also makes you work more gently tapping things in or out. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Thu May 23, 2019 6:07 pm Post subject: Re: tar board substitute? |
West Coast Metric tar boards are a more flexible waffle pattern material. That is all I am using anymore. Easy to work with and look good. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Thu May 23, 2019 7:53 pm Post subject: Re: tar board substitute? |
Thanks for all the replies. I would like to stay with the tarboard; shipping from either WW or WCM or Chris Vallone; may dirve the cost too high. I did buy a set from a local suplier but they look to be poorer quality. The saga continues. _________________ June 1956 VW Oval Beetle |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Thu May 23, 2019 9:54 pm Post subject: Re: tar board substitute? |
There is an old thread in the ovals forum where a prominent samba user made his own tar boards to get as close to factory match as he could. I’ll hunt it down for you, and you can consider making yourself some high quality and authentic functioning tar board. _________________ Plate of shrimp |
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1266 Location: Beautiful New Zealand
Posted: Thu May 23, 2019 9:55 pm Post subject: Re: tar board substitute? |
I replaced mine and came to regret it in short order; have learned to love the bare look instead... If you must use them, don't cheap out.
_________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
Posted: Thu May 23, 2019 10:04 pm Post subject: Re: tar board substitute? |
I was partly right... it’s John S Henry. He has a great website that details ALOT of VW stuff, but also his 57 resto. I can’t copy anything in here as he has protections, but here is a link.
https://www.thebugshop.org/goresto.htm _________________ Plate of shrimp |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Fri May 24, 2019 5:19 am Post subject: Re: tar board substitute? |
tomsbuggered wrote: |
Thanks for all the replies. I would like to stay with the tarboard; shipping from either WW or WCM or Chris Vallone; may dirve the cost too high. I did buy a set from a local suplier but they look to be poorer quality. The saga continues. |
What amount would make the cost too high for you? Think of it this way.... Would you rather spend a few hundred dollars now, or a few thousand later? I’ve worked on dozens of cars with home brewed, or poor quality tar boards that have had the material droop over the intake of the fanshroud. Some instances, the overheating was caught early, and it simply shortened the life of the engine. Other instances had the cam gears being the only reusable parts out of the longblock. |
Rick Anderson Samba Member
Joined: September 28, 2016 Posts: 20 Location: Napa, California
Posted: Tue May 28, 2019 7:48 am Post subject: Re: tar board substitute? |
Sure looks like the WCM stuff.....Just sayin' _________________ D-Dubya Manx clone - 63 Short pan,1914.
aa390392 Samba Member
Posted: Tue May 28, 2019 8:57 am Post subject: Re: tar board substitute? |
I have made 2 sets using the J.H. method, out of doubled up " tar paper" both pairs have enduranced time, and still look great. Buy the paper at most home improvement stores.
Cheers Thomas _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Wed May 29, 2019 10:05 pm Post subject: Re: tar board substitute? |
Cip1.ca has German-made tarboards on sale til month-end for $69 CDN. If you can add $30 more to the order, you'll get free shipping. Their boards a very good quality. Ordering inside Canada will save you the 30% exchange on the dollars, and excess shipping costs ... _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Sat Jun 22, 2019 8:01 pm Post subject: Re: tar board substitute? |
Well I ended up making some engine compartment "liners" out of light gauge steel and then coated them with "rock guard" product. They look good and no fear of them ever warping or sagging. I may post pics if and when I solve my dragging starter issue. _________________ June 1956 VW Oval Beetle |
Posted: Sun Jun 23, 2019 5:07 am Post subject: Re: tar board substitute? |
Something VERY important is using OE style that has a fabric on the one side. The fabric goes againts the firewall - not on the engine side. Just replaced it on a car that the fabric was coming loose and it wold eventually get into the fan. _________________ D-Dubya Manx clone - 63 Short pan,1914.
chrisklinger Samba Member
Posted: Wed Jul 28, 2021 8:07 pm Post subject: Re: tar board substitute? |
Just as an addendum, on my Ghia, the front (crap aftermarket the PO put in, before the bondo I'm guessing) tarboard managed to come loose, and wiggle its way between the front tin and the firewall.
And sat on the J-pipe
And caught fire.
Only engine fire I've ever had, in about 40 years of VWs.
Lemme tell, that shit is not easy to put out, once it lights. And once out, it relights itself. Over. and. over. again.
I was DAMNED GLAD I had a full, large halon extinguisher.
RAMVA forever. |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
