pupjoint Samba Member
Posted: Mon May 27, 2019 10:50 am Post subject: DRLA leaking pump diaphragm |
took out my DRLA 40s for cleaning and maintainence , old diaphragms a little hard so i put new ones in. the new ones appear to be a little thin compared to the old ones.
having some leaks after i put new ones in and new springs.
is this a common issue? do i need to sand the cover flat to fix this?
or has this got to do with poor quality aftermarket diaphragms |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Mon May 27, 2019 11:22 am Post subject: Re: DRLA leaking pump diaphragm |
I get OEM quality DRLA parts from Dellorto.Uk. I have not had any issues with leaking pump diaphragms.
Make sure to tighten the screws on a cross pattern. So the pump cover is tight the same at all four corners.
Where did you source your parts from?
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Mon May 27, 2019 11:49 am Post subject: Re: DRLA leaking pump diaphragm |
Thanks. I can’t recall where to be honest been keeping them for a few years now, but still soft.
Will try to get new ones from Dellorto UK |
mcdragracer Samba Member
Posted: Mon May 27, 2019 1:19 pm Post subject: Re: DRLA leaking pump diaphragm |
It's very unusual for the dellorro carb to leak at the diaphragm area,
even if the gaskets a little hard or brittle, can you share pics of that area and also you can check for flatness of the cover on a piece of glass.
And fyi I stock the pump diaphragms. |
Posted: Mon May 27, 2019 1:22 pm Post subject: Re: DRLA leaking pump diaphragm |
mcdragracer wrote: |
No photos unfortunately, it’s not dripping kinda leak, just some seepage after a few hours . It wasn’t leaking with the old hardened diaphragms |
Posted: Mon May 27, 2019 2:48 pm Post subject: Re: DRLA leaking pump diaphragm |
Are they both leaking? It's also really easy twofold the edges of the diaphragm n-word as your tightening down the screws because the diaphragm is so thin, just make sure that it's not full David in word on any corners |
