MikeyM73 Samba Member
Joined: December 06, 2016 Posts: 506 Location: Napa Valley, CA
Posted: Fri May 31, 2019 6:57 am Post subject: Re: Ignition switch crapped out? But it was so young! |
Hey, I was close _________________ '73 Pop-top Westy, found sitting in a field for 10+ years, cleaned up, rebuilt furniture, reloved. Original 1.7 block/fully polished crank, 93mm 1.8L balanced AA pistons & cylinders, new 1.8L balanced rods, HAM 42/36 heads, Scat C25 cam & lubalobe lifters, Dual HPMX40s, R2C filters w/ Outerwears pre-filters, functioning thermostat & flaps, Pertronix Flamethrower III, 4-1 exhaust w/ Cherry Bomb 2" turbo muffler & OEM heater boxes, averages about 19-22ish on the highway.
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Fri May 31, 2019 8:23 am Post subject: Re: Ignition switch crapped out? But it was so young! |
SGKent wrote: |
MikeyM73 wrote: |
OH... I know, I know!! Pick me! Pick me!
Crappy Chinese ignition switch (like I'm replacing) that closed contacts itself by the sneeze of a fly??
no - hot start relay shorted internally. |
I had that happen. It was my fault. Poor mounting location allowed it to get wet. It drove into the neighbors Honda, glanced off and into their apple tree in their front yard. You meet the nicest people in a Honda. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Fri May 31, 2019 8:37 am Post subject: Re: Ignition switch crapped out? But it was so young! |
telford dorr wrote: |
I bet it was the cube style... |
and mounted upside down under the Bus so it could fill with water....
I guess all the relays in my new Toyota will fail in a week and cause it to drive off.... But it won't because they use quality parts installed and protected correctly. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Fri May 31, 2019 10:36 am Post subject: Re: Ignition switch crapped out? But it was so young! |
When my OG starter switch failed I stripped it down and found the wiping contact had a huge blackened groove in it lined up with the contact post on the rear of the switch body.
Sanded it down, bent what I coukd, tried a wrong repkacement switch, then located the runaway ball bearing from the OG switch in the dark on the road surface ..
Worked for a couple more weeks. Fitted an exchange starter and another cheap switch as the fault started being switch sometimes and starter other times.
All been good for 40000 miles or so since.
The other day I measured the cranking current and found that the solenoid drew 16 amps and the starter was happily cranking a 1641 and drawing 50 amps ( not including solenoid, the current probe was on the starter feed.) _________________ Ancient vehicles and vessels
airkooledchris Samba Member
Posted: Fri May 31, 2019 11:40 am Post subject: Re: Ignition switch crapped out? But it was so young! |
Push button start is the route I went. The relays are an OK (at best) option, but you really need to route the wiring up into the engine compartment to keep them away from the elements.
The starter switches available now are just pure crap. I turn the key and push the button - love it.
As a bonus I can crank the engine to build oil pressure before turning the key whenever I want. |
Posted: Mon Jun 03, 2019 4:49 pm Post subject: Re: Ignition switch crapped out? But it was so young! UPDATE |
Hey all,
Here's an update as of this past Saturday. After replacing the switch, which I was SOOO sure was the issue (30 min job) it would start only intermittently. Weak! BUT, again when touching the red and/red black wires together under the dash, going to the switch and bypassing it, it would crank 100% of the time. So, figuring there was a bunch of resistance along the current path, I got underneath to the starter and found pretty green corrosion along with some flakey termination work / broken strands, etc. at each wire/terminal connected to the starter. So.. per the sage advice here, I disco'd everything, sanded terminal rings that needed it, replaced terminal rings (and shrink wrapped them with silicon, internally) that needed it and re-terminated the ignition switch spade. Guess what... it's worked ever since. Why? He asks.
Is this because of the overall cumulative amount of resistance that had maybe built up with the corrosion, combined with the resistance of the superior hi-quality (not), 20 dollar, Chinese made ignition switch that was (hopefully) failing and on it's way out? That's the only thing I can think of. Really, as you guys suggested... clean and replace terminals giving all 4 wires to the starter (+batt, alternator, ignition switch, and one more I don't know what it does yet) fresh metal to touch. Along with a new (cheap) switch.
I found a couple OEM / NOS / used German switches, one of which I'll be buying in the next couple days to replace this newly installed Chinese switch but I'm kindof at a loss as to why it was intermittent after the new switch - unless my resistance rant is accurate.
If SG is listening in - in addition to all my blabbering above about resistance, I would imagine that if the solenoid grease is old and starting to stick, that would only add to the resistance and problem.
Thanks for reading,
Mikey _________________ '73 Pop-top Westy, found sitting in a field for 10+ years, cleaned up, rebuilt furniture, reloved. Original 1.7 block/fully polished crank, 93mm 1.8L balanced AA pistons & cylinders, new 1.8L balanced rods, HAM 42/36 heads, Scat C25 cam & lubalobe lifters, Dual HPMX40s, R2C filters w/ Outerwears pre-filters, functioning thermostat & flaps, Pertronix Flamethrower III, 4-1 exhaust w/ Cherry Bomb 2" turbo muffler & OEM heater boxes, averages about 19-22ish on the highway. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3552 Location: San Diego (Encinitas)
Posted: Mon Jun 03, 2019 7:59 pm Post subject: Re: Ignition switch crapped out? But it was so young! |
You're correct. At the current levels that the solenoid requires, ANY extra resistance is significant! To work reliably, every connection in the chain from battery to dash back to starter solenoid has to be in tip-top condition (e.g., like new, or better). Takes a lot of work to get there. Add crap parts into the mix, and failure is just around the corner... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Tue Jun 04, 2019 7:44 am Post subject: Re: Ignition switch crapped out? But it was so young! |
Thanks for the reply. So why do you think that VW decided not to include a starter relay If it were a pretty standard way of wiring by this time?? I would’ve thought it a safer, more reliable way to go but at the same time I can understand them not including the starter relay assuming all connections were/are in proper condition. Also, they most likely did not give thought to the fact that many of these vehicles would be resurrected from the dead and brought back to life and into service with all of those issues surrounding that aspect as well. Certainly no fault of their’s.
Thanks again… Don’t mean to beat a dead horse with this but I find it interesting. _________________ '73 Pop-top Westy, found sitting in a field for 10+ years, cleaned up, rebuilt furniture, reloved. Original 1.7 block/fully polished crank, 93mm 1.8L balanced AA pistons & cylinders, new 1.8L balanced rods, HAM 42/36 heads, Scat C25 cam & lubalobe lifters, Dual HPMX40s, R2C filters w/ Outerwears pre-filters, functioning thermostat & flaps, Pertronix Flamethrower III, 4-1 exhaust w/ Cherry Bomb 2" turbo muffler & OEM heater boxes, averages about 19-22ish on the highway. |
SGKent Samba Member
Posted: Tue Jun 04, 2019 8:09 am Post subject: Re: Ignition switch crapped out? But it was so young! |
they did include a starter relay. That is what the solenoid is. What folks are suggesting is adding a second one to power the first one, the idea being that a small relay takes less current than a big solenoid. The Bosch starter uses the solenoid to also push out the drive gear where on starters like a Ford starter centrifugal force spins it out in what is called a Bendix drive. Our Bosch starter uses a fork powered by the solenoid to drive the gear out. In my book adding a second one is another point of failure however some folks seem to have really bad luck with finding high quality ignition switches. The junk ones crack and that causes all sorts of problems. I guess if they used a poor quality conductor internally that would cause heating issues. All I know is that if someone takes the time to go thru their entire wiring system like you did, and clean and grease the solenoid, 99% of the problems go away.
Also the problems can be anywhere. We've had people here where the inside of the battery cable rotted away but it looked normal on the outside. Chase that one down without a volt meter (which is your friend when troubleshooting ignition or wiring issues. Find a voltage drop where there should not be one and there will be corrosion there. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
