Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Tue May 28, 2019 8:43 pm Post subject: Aluminum straight cut gears |
Ok folks I was going around vw websites today just looking for parts and seeing who was selling the parts i was looking for "deals" and I happend to come across these👉 https://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-5401
Have any of you guys tried these or are they just another junk product. I'm just thinking of buying them to see what's up.. any one try them on there 36hp or 40hp engines in light me... |
Danwvw Samba Member
Posted: Tue May 28, 2019 9:17 pm Post subject: Re: Aluminum straight cut gears |
Danwvw wrote: |
Well I wonder if the 1600 and the 36 horse can use the same cam gear if sreight cut? Really? I don't know. Says here that the stock gears are different between those engines. Need help with camshaft part numbers. |
The 1600 straight cut gears will fit in the 36hp case ...i was just wondering if any one use these aluminum ones.. I have seen steel on steel straight cut gears but not aluminum ones ...
Last edited by [email protected] on Tue May 28, 2019 9:43 pm; edited 1 time in total |
Danwvw Samba Member
Posted: Tue May 28, 2019 9:36 pm Post subject: Re: Aluminum straight cut gears |
I put an aluminum gear in one of my 1600 based engines but it's Stock Pitch. Aluminum is stronger than magnesium but softer. I usually just stick with the old gears they are almost always good. I don't know maybe not with dual valve springs or something. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 977 Location: Las Vegas, NV
Posted: Tue May 28, 2019 10:05 pm Post subject: Re: Aluminum straight cut gears |
[email protected] wrote: |
I had an aluminum cam gear in my 1776 before I rebuilt it. A few teeth were chipped off but it still ran fine. I put a steel straight cut gear set in so I don't have to worry about that happening again. _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Fri May 31, 2019 9:56 am Post subject: Re: Aluminum straight cut gears |
It's hard to beat stock 36hp/Porsche 356 gears. These have reduced helix from 40hp & later gears, yet aren't noisy like straight-cut. The only time straight-cuts are "needed" are when valve spring pressures are extremely high. JMHO _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
